Old Sep 11, 2014, 06:23 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Extreme 50mm Video....164 avg, 182 fastest pass on 8s and 1.7kw, post #134
I've decided to go completely over the top with my new Screamer airframe. I'm changing it to a top, imbeded pod style airframe and adding a custom fan that willdo aprox 1kw on 6s and 1.5kw on 7s. I'll be adding some initial pictures soon, so log on if you are interested in seeing my insanity become reality.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Sep 11, 2014, 09:15 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Here are a few pics of the fan. The shroud/rotor are Hayoe 51mm parts. The motor will have to be mounted in standoff mode of course, but is only 1mm larger than the od of the motor tube so airflow through the fan will be good.
Old Sep 11, 2014, 09:18 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Come on Lee, where's those digital calipers???
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Sep 11, 2014, 10:11 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Battery's dead. As usual.
Old Sep 13, 2014, 01:08 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Putting the fan together.....my basic "large motor standoff " method. It hits 1500w on 7s (60a) without an intake ring. When I get a ring made, I'll check bench power and thrust numbers before installing it in the airframe.
I balanced the rotor assembly dynamically before installing it in the shroud. Then after assembly it only took a little clocking to get it back in balance.
Old Sep 13, 2014, 01:55 PM
corsair nut is offline
Find More Posts by corsair nut
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
i thought i was cool when i did a 600w 50mm lol you are nuts lee! im exited to see thrust and efflux numbers
corsair nut is offline Find More Posts by corsair nut
Old Sep 13, 2014, 03:54 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I have to say, Yes, and me too. Hey, if it's not over powered, then it must be underpowered.😜
Old Sep 13, 2014, 03:58 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I loved the way my last Screamer flew at about 800w, but the motor was not up to the task. I shouldn't have that problem with this one. 1000w easily, and 1500w with some care.
Old Sep 19, 2014, 08:41 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
3.5lbs Thrust at 1.4kw, how's that for an extreme 50mm?
Finally got around to doing a quick thrust measurement on 7s. Adapted an intake ring from a 70mm fan. This is with no thrust tube and just holding it over a good gram scale........at about 1400w, it blows 1600g against the scale. That's 3.5lbs of thrust. The batteries were freshly charged.
How about that? Measuring a 50mm in kilowatts.
Old Sep 19, 2014, 09:55 PM
ksqm is offline
Find More Posts by ksqm
Hampton, VA
Joined Mar 2009
Sick Puppy!!! But I LOVE IT!
Ksqm
ksqm is offline Find More Posts by ksqm
Old Sep 20, 2014, 10:37 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Well the puppy just took a turn for the worse. 8s numbers......1800 w, 4.4lbs, 290mph efflux speed. Motor windings seem quite happy at this level. 150F.
Should make some airframe progress this weekend.
Old Sep 20, 2014, 10:54 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
A little number crunching. The total weight of the power system, inc lipos is 1.9lbs. So I expect the AUW of the jet to be in the 2.5-2.75lb range. Don't think hand launching will be an issue. Sherlock would be pleased. Too bad he's gone to turbines. LOL
Old Sep 20, 2014, 05:19 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
Joined Nov 1999
4.4lbs from a 50mm... I am speechless.
What batteries are you using for the 8s setup?
Eric B.
AirX is offline Find More Posts by AirX
Old Sep 20, 2014, 05:25 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Hi Eric, I'm using a pair of 4s 2200 Nano A Spec 65c. They handle the 60a pretty well. Of course at 30c drain, that's a 2 min flight + power management time. But at this level it's going to be for one thing. High Speed passes.
Yeah, 2000g on the scale surprised the heck out of me too. I guess at 75k rpm (estimated ) good things start to happen in that little air pump.
Wanted 30cc Aeroworks, 3DHS or Extreme Flight gas airframe harttvboy Aircraft - Fuel - Airplanes (FS/W) 7 Nov 06, 2013 10:30 PM
Sold Extreme Power Analyzer - Watt Meter 6L6Amp Aircraft - Electric - Power Systems (FS/W) 1 Oct 29, 2013 01:12 PM
Sold Extreme flight 78" Extra 300(airframe, eflite motor, castle Ice hv2 120 Esc only) Ducati Mechanic Aircraft - Electric - Airplanes (FS/W) 11 Sep 20, 2013 06:43 PM
Wanted 3d hobby shop or extreme flight 30cc airframe near CT harttvboy Aircraft - Fuel - Airplanes (FS/W) 0 Sep 20, 2013 10:38 AM
Video SA Stik kit Bash Biplane RCTyp Electric Plane Talk 0 Jul 30, 2006 07:03 PM
