Old Jun 19, 2013, 10:27 AM
Heli Freak64 is offline
Find More Posts by Heli Freak64
Joined Jun 2013
Help!
My Heli turning on its own.
Hi, I am a total newbie, I don't know anything about RC helicopters, I never new that it was so complicated to fly a RC Heli.
I bought a Helicopter this morning it says Gyro on it's box. Just after it lifts off the ground the plane skids off to the back or sometimes to the left, and if I take off slowly it starts to spin counter clockwise slowly. I live in Pakistan, shop keepers here sometimes play with the Helis and pack it back as if they were new and then sell it, maybe they broke it, I am not sure. Is this normal? if not, how should I fix it?
Help will be appreciated,
Heli Freak64
Heli Freak64 is offline Find More Posts by Heli Freak64
Old Jun 19, 2013, 11:10 AM
arrowshooter is offline
Find More Posts by arrowshooter
United States, CA, Modesto
Joined Aug 2012
Welcome! Let's start with what helicopter you bought. That way folks with experience with that bird can help.
arrowshooter is offline Find More Posts by arrowshooter
Old Jun 19, 2013, 11:14 AM
Hajile is online now
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
Can you post a picture?
Hajile is online now Find More Posts by Hajile
Old Jun 20, 2013, 01:21 PM
Joined Jun 2013
Thank you for the Welcome message. I don't really know the name of the helicopter, there is no name on the heli itself and it only says V-Max on the box. China sells low quality stuff here in Pakistan, they don't care if there is a name or not.
This one looks just like my heli, but it is not mine:
I noticed that sometimes the heli never lifts of the ground. When I push my throttle the heli skids to one direction sometimes left sometimes right, backwards etc. Or sometimes it does lift off the ground but moves to a different direction and crashes, and it is also rotating clockwise on its own.
Is it broken?, should I get it repaired?
Old Jun 20, 2013, 02:17 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Take off more quickly. You can't do anything with those helicopters while they are blocked by the ground. The gyro doesn't work properly until the helicopter is free to move in the air. That's why the behavior seems random - because it is. If you had a trim problem, the thing would always go off the same direction. Also check everything for little hairs - they get into the tail rotors and cause it to move slowly.
jasmine2501 is offline Find More Posts by jasmine2501
Old Jun 20, 2013, 07:53 PM
Joined Jul 2012
Ah, a coaxial. Give it enough throttle to get it at least two feet off the ground asap, they don't like ground turbulence. Once it's in the air, it'll self stabilize if you give it enough room to settle down.
Once that's done, you use the trims to stop the heli from spinning.
Note that the flybar is attached to the upper rotor, making it heavier so the load on the motors are always uneven. You may have to keep adjusting the trims as the battery winds down.
Old Jun 20, 2013, 09:04 PM
Tail Wheel is offline
Find More Posts by Tail Wheel
Tail Wheel's Avatar
Houston
Joined Oct 2006
Here, we call those (shopping) mall copters.. 3.5 channels is their category of rotary birds. Don't fly worth a darn in any kind of wind, but inside, or no wind, they should hover with no input provided they are balanced.. The tail rotor either blows down to lift the tail and make it fly forward or up to make it fly backwards.. They turn by slowing down one of the two main rotor motors and speeding up the other.. I flew one.. Once.. Ugh.. Horrible..
No swash plate what so ever to control cyclic pitch.
Should have a rotary knob on the front of the radio that controls the yaw trim to keep the heli from rotating left, or right and keep it pointing in one direction..
Tail Wheel is offline Find More Posts by Tail Wheel
Old Jun 21, 2013, 02:17 AM
Joined Jun 2013
okay, I think I have to buy a new heli. Can anyone suggest a helicopter for me?, and remember I am a newbie.
Old Jun 21, 2013, 03:08 AM
Joined Jul 2012
A micro quad like a v929 will be fine, it's mechanically simpler and perfectly symmetrical so you're less likely to have the rudder and aileron idiosyncrasies commonly found in helicopters.
Old Jun 21, 2013, 04:56 AM
Joined Jun 2013
No, I don't want a Quadcopter I want a Heli.
Old Jun 21, 2013, 05:08 AM
Joined Jul 2012
v911 then. It's how i learned to fly a helicopter. If you've ever been frustrated because your coaxial keeps getting sucked into the walls, having ailerons would be a godsend. It'll still have the same eccentricities of a larger heli but toned down to beginner manageable levels.
V911 HOVER with a brand NEW 145mAh battery.wmv (10 min 15 sec)
The advantage of having a working swashplate/cyclic.
Discussion Turnigy 9x throttle creeping on its own seatux Radios 1 May 28, 2013 11:11 PM
Discussion DX6i servo reversing on its own jrjr Radios 3 May 28, 2013 07:11 PM
Discussion Dji NAZA Problem- Changed Controls on its own. CCkiter Multirotor Talk 5 Feb 05, 2013 07:07 PM
Discussion Will the US military turn its guns on it's own people? jumpinjo Life, The Universe, and Politics 105 Feb 12, 2009 08:21 AM
My honey Bee 2 decides to make its own movements and turns... Lino Micro Helis 23 Jan 07, 2005 09:09 PM
