Old Dec 29, 2014, 03:13 PM
Hlaalu11 is offline
Find More Posts by Hlaalu11
Joined Sep 2014
JLT_GTI, sorry for asking, but why keeping the transmitter's antenna like that?
Of course at 50 m you should have more than 30 even without an antenna probably (!), but just for experiment, try moving it vertically and see whether the values change.
Hlaalu11 is offline Find More Posts by Hlaalu11
Old Dec 29, 2014, 03:17 PM
Hlaalu11 is offline
Joined Sep 2014
Thank you renatoa. I definitely should do this to set my alarms in a more systematic way.
Originally Posted by renatoa View Post
Setting an alarm over 50dB is cannibalizing your range at all, and fly almost permanently in a concert of beeps.
Uhm actually no, with the actual configuration I am not having this problem (and I don't do FPV): sure I'd have changed the values if I had had that issue.
Old Dec 29, 2014, 03:27 PM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Probably you fly LOS then, rarely going under 60 when flying LOS.
Maybe you are fooled by the logarithmic nature of the units, distance double for every 6dB. If you are at 500m and read 60, this means at 1km you should read 54 60 is not as low as you could believe, and be afraid
Actually, just purely theoretical, for two stationary, not moving systems, the db values reading should evolve as this table:
1m - 110
2m - 104
4m - 98
8m - 92
16m - 86
32m - 80
64m - 74
128 - 68
256 - 62
512 - 56
1024 - 50
2048 - 44
4096 - 38, and failsafe
When moving, the above changes a lot ! antennas misaligned by 45 degrees (plane banking) led to 3dB loss, i.e distance diminished suddenly at 70%.
Weather has also a lot of influence, GHz is eaten by moisture... if here is sun and at 2km over the hill is fog, don't be surprised to see an abrupt link break, without any warn.
renatoa is offline Find More Posts by renatoa
Old Dec 29, 2014, 03:36 PM
Hlaalu11 is offline
Joined Sep 2014
Maybe you are fooled by the logarithmic nature of the units, if you are at 500m and read 60, this means at 1km you should read 54 60 is not as low as you could believe, and be afraid
Yes I was definitely not aware of such things. Thank you indeed.
Anyway thank you for the clear explanation, now I suddenly understand FrSky's default values.
Old Dec 29, 2014, 04:59 PM
JLT_GTI is offline
Find More Posts by JLT_GTI
JLT_GTI's Avatar
Spain, Principado de Asturias, Oviedo
Joined Jun 2010
What annoys me is that one day it was just like this... no reason for it to fail and FrSky has not answered any of my querys about the issue...
JLT_GTI is offline Find More Posts by JLT_GTI
Old Dec 29, 2014, 10:09 PM
Aries321 is offline
Find More Posts by Aries321
Southern Az
Joined May 2010
Finished the CP setup of plane and Tx.. 8dbi LHCP patch on the Tx (w/ 3W booster) and LHCP SPW on the receiver. Going to test the range on New Year's Eve afternoon!
Aries321 is offline Find More Posts by Aries321
Old Dec 30, 2014, 12:56 PM
ecworks is offline
Find More Posts by ecworks
Marshall Islands, Enewetak Atoll
Joined Sep 2011
Pushed out to 3+ miles yesterday with the L9R on my Kunai:
FrSky L9R rx
250mw vid tx w/Circular Wireless cloverleaf
7 turn 5.8 helical vid rx antenna
No booster
http://youtu.be/sRLldoqbB0A?list=UUK...w5p1a2ANd0K_JQ
ecworks is offline Find More Posts by ecworks
Old Jan 04, 2015, 09:40 PM
Hlaalu11 is offline
Joined Sep 2014
This might not be stricly limited to FrSky, but anyway:
is it normal that the receiver loses the signal after a slight bump?
I had a flight with a micro foamie (wingspan 40cm) that flipped over in the final part of landing, and when I took the plane back in my hands I noticed the receiver had entered failsafe.
I had the TX close, so it must have been a 'fake' failsafe, and I had to power it (the rx) off and on again to make it work normally.
Now, the bump was very very light (and it happens quite often that such small foamies flip over after landing, especially on grass), but I still wonder whether it is normal that bumps, in general, make the receiver behaving this way.
Old Feb 22, 2015, 12:09 PM
GTiDonavan is offline
Find More Posts by GTiDonavan
Joined Jan 2012
This is not normal and completely off topic
GTiDonavan is offline Find More Posts by GTiDonavan
Old Feb 22, 2015, 01:49 PM
Scottfils is offline
Find More Posts by Scottfils
United States, AZ, Cottonwood
Joined Jul 2014
1.3 miles futaba 8uap FRSKY DFT module 8dbi patch panel antenna 450 sized quad D8R-XP rx
antennas pointed down in a v under the quad. video 5.8 boscam ts832 Ibcrazy ultra blue beam 3 lobe antenna. No telemetry beep at 1.3 miles was not sure it was still working. only about 3/8 mile range with stock antenna before telemetry beep.
Scottfils is offline Find More Posts by Scottfils
Discussion What's the craziest / most creative thing you've done with your heli? S9coldfire Electric Heli Talk 32 Aug 12, 2011 11:38 AM
Poll What's in Your Trick bag? bakon 3D Flying 61 May 08, 2011 04:26 PM
Discussion What EDF's do you currently have in the que, building, flying, and on your wishlist? Jetnfast Electric Ducted Fan Jet Talk 21 Apr 18, 2011 10:34 PM
Discussion What's in your crash kit/spares box? Essex2visuvesi Beginner Training Area (Heli-Electric) 17 Mar 25, 2011 01:55 PM
What's your range check range thanhTran Micro Helis 13 Jun 07, 2005 03:07 PM
