Old Feb 16, 2011, 05:04 PM
mcrotor is offline
Find More Posts by mcrotor
New Berlin, WI
Joined Oct 2006
Like a Y6 - featuring more lights and sound!!!!
Ready to try my new Hoverfly Y6. Just need the weather to cooperate.
Rusty rev7 frame
carbon booms
Rctimer 2836-11 750 kv motors
APC 12-3.8 props
Turnigy nano-tech 3s 25-50c 4000mah battery
DPCAV power supply filter
"c" shaped wiring harness
50 disk size CD cake box for board protection
foam filter on altitude sensor
Hitec Aurora 9 radio with Optima 9 channel receiver
Motor to motor distance is 25"
Center to motor distance is 14.75"
I mounted the Hoverfly board using the anti-vibration grommets and also used servo grommets on the plate that the board mounts to. So I have twice the anti-vibration protection.
Two of my motors make a little bit of noise so I ordered several more and when they arrive I will remove the noisy motors, pull out the bearings and see if boca bearings has some quality bearings that will fit and if so I will replace the bearings in all six motors.
I will also replace all the prop adapters with the E-flite ones. My local hobby shop only had one in stock. I gave it a try and it runs nice and true so I ordered 5 more.
I would try it as is (without new bearings and prop adapters) if the weather lets up a bit. Windy and rainy.
Until then?
mcrotor
mcrotor is offline Find More Posts by mcrotor
Old Feb 16, 2011, 06:30 PM
S11D336B is offline
Find More Posts by S11D336B
S11D336B's Avatar
USA, FL, Winter Springs
Joined Apr 2006
Cool, looking good.
Rusty rev7 frame
carbon booms
APC 12-3.8 props
Until then?
mcrotor
S11D336B is offline Find More Posts by S11D336B
Site Sponsor
Old Feb 17, 2011, 03:22 PM
Carlos230023 is offline
Find More Posts by Carlos230023
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
Here here! Looking very tasty!
CJ
Carlos230023 is offline Find More Posts by Carlos230023
Old Feb 17, 2011, 03:31 PM
mcrotor is offline
New Berlin, WI
Joined Oct 2006
Thanks guys
Old Feb 18, 2011, 06:10 PM
Triskelion is offline
Find More Posts by Triskelion
Stacey Ducharme
Triskelion's Avatar
Joined Jan 2011
Like a Y6... I love it, and the pics!
Triskelion is offline Find More Posts by Triskelion
Old Feb 22, 2011, 07:36 PM
workshop is offline
Find More Posts by workshop
Tesla's Workshop
workshop's Avatar
USA, CA, Torrance
Joined Nov 2004
That is so sweet... Would you mind if I copied your build?... I've decided on a Y6 almost exacally as you've chosen to do... Nice work!
Jeff
p.s. Did you have much trouble getting the HF Pro board to fit?
workshop is offline Find More Posts by workshop
Old Feb 23, 2011, 03:10 PM
mcrotor is offline
New Berlin, WI
Joined Oct 2006
Jeff
Copy away!!!! No trouble fitting the board to Rusty's frame. He has a set of holes just for the Hoverfly board. I did have to reduce the outer diameter of the central frame disks to get the cd cover to fit over them.
Marty
Old Feb 25, 2011, 09:55 PM
mcrotor is offline
New Berlin, WI
Joined Oct 2006
Like a Y6 cyborg!
Y6 with some lighting added.
http://www.youtube.com/watch?v=nm00SlgUIEA
Old Feb 26, 2011, 07:53 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
Got to have some lights!
Just got some 1W leds to go on mine for nav beacons. Can't leave them on because of current draw so will have to pulse them.
I like the color you picked.
pug398 is offline Find More Posts by pug398
Old Feb 27, 2011, 09:55 AM
mcrotor is offline
New Berlin, WI
Joined Oct 2006
actually they are white led's. Just look colored on the video.
Old Mar 03, 2011, 05:10 PM
mcrotor is offline
New Berlin, WI
Joined Oct 2006
Check out the new lights and sound!!!!!
http://www.youtube.com/watch?v=siowWBXKhB0
Old Mar 03, 2011, 07:06 PM
workshop is offline
Tesla's Workshop
workshop's Avatar
USA, CA, Torrance
Joined Nov 2004
This is so much fun!!! Mine is coming along too. I found some INSANELY bright (180,000 - 280,000mcd) 10mm LEDs that fit perfectly inside the 12mm booms. I glued a red, green and white in the left, right and aft boom and a blue one will illuminate the CD box (oh how I love that CD box idea)...
I'm using KDA20-22L motors with APC 10x4.5 SF props. The ESCs are coming from China and haven't floated this far yet... I may give up and buy locally.
I'll take photos when I have something to show... Nice work!
Jeff
Old Mar 03, 2011, 08:24 PM
JET MAN TWO is offline
Find More Posts by JET MAN TWO
United States, PA, Erie
Joined Dec 2006
Hey, workshop, You will love the kda 20-22L They are my favorite. Just cut the shift off and run the screws in adapters with the nuts . You will never have a prop fly off.
JET MAN TWO is offline Find More Posts by JET MAN TWO
Old Mar 03, 2011, 09:09 PM
mcrotor is offline
New Berlin, WI
Joined Oct 2006
Thanks Jeff.
Having a ball myself. Looking forward to your photos. Now if only the weather would break here.
Marty
Jeff
Old Mar 04, 2011, 10:22 AM
FixedWing172 is offline
Find More Posts by FixedWing172
FixedWing172's Avatar
NJ
Joined Oct 2007
Hey I like your new ride, very neat. What did you use to get the LEDs to alternate like that?
FixedWing172 is offline Find More Posts by FixedWing172
Discussion First Flight with the prototype "WOV-Y6 500 Copter" WOV-Y6-Copter Multirotor Talk 37 Mar 28, 2011 10:30 PM
Discussion Y6 or Hexa? X8 or Octa Canadian Geek Multirotor Talk 25 Jan 10, 2011 06:38 PM
Discussion Your Dream Y6 (coax-tri) or X8 (coax-quad) setup Mactadpole Multirotor Talk 12 Sep 17, 2010 02:32 AM
Discussion Y6 from Foxtech - any more details? trappy FPV Talk 8 Jun 28, 2010 05:23 PM
Gallery NEW FPV Video with WOV Y6 500 WOV-Y6-Copter Aerial Photography 0 Apr 17, 2010 05:13 AM
