Old Feb 12, 2011, 10:42 AM
Quadflyer111 is offline
Find More Posts by Quadflyer111
Joined Jan 2011
Align ESC programming for quad?
Is anyone using Align ESC's? I have some align 15 amp esc's and am wondering if I have programmed them correctly.
brake - disabled
timing - mid
battery protection - "mid" (lowest voltage cut off option)
aircraft - normal
throttle response - high
bec output - 5.0v (only using bec from 1 esc)
I notice the instructions don't really give any option to "calibrate" the esc, what are others doing I wonder? I have hovered my quad with these esc's and it seems to hover nicely, but I haven't had a chance to take it outside (20-50mph winds today)
Here is the pdf for the instructions if anyone is curious:
http://video.align.com.tw/mpeg/manua...E-BL15X_en.pdf
Quadflyer111 is offline Find More Posts by Quadflyer111
Old Feb 12, 2011, 10:52 AM
randall1959 is offline
Find More Posts by randall1959
Joined Feb 2004
I'd say you have it pretty well dialed in if it's hovering well. Have you done the throttle calibration? Turn on your tx, run the throttle all the way up. Plug in your quad battery. Listen for the arming tone, then pull your throttle all the way down. I'd leave it be though if it's hovering now.
randall1959 is offline Find More Posts by randall1959
Reply With Quote  (Disabled)
Old Feb 12, 2011, 10:55 AM
Joined Jan 2011
Ok, cool. The method you described puts the esc's into programming mode, but perhaps part of the programming mode IS the calibration as you have to plug in the battery with full throttle, it makes a series of tones, then lower the throttle stick to full low, it makes some more tones, and then starts the programming process.
Old Feb 12, 2011, 11:11 AM
Joined Feb 2004
I'd say you're good to go then. It's easy to make something a lot more complicated than it needs to be with these things.
Old Feb 12, 2011, 11:40 AM
Joined Jan 2011
True...lol. The bad luck I have had so far with the castle creations stuff has made me paranoid!
Help! Help programming the AR6400 for brushless ESC S55 Radios 38 Dec 17, 2013 12:22 PM
Wanted WTT Align 450 heli for quad copter tconners FPV Equipment (FS/W) 1 Jan 11, 2011 01:00 PM
Wanted WTT Align 450 heli for quad copter. tconners Aircraft - Electric - Helis (FS/W) 0 Jan 07, 2011 05:05 PM
Discussion Programming instructions for Ultra Stick 40 quad flaps using DX7 flytivoer Radios 8 Mar 09, 2009 02:07 PM
Discussion Align 35A ESC programming problem Ohio AV8TOR Mini Helis 4 Jan 04, 2006 08:16 AM
