Old Jun 20, 2010, 02:04 PM
Jacques Flambeau is offline
Find More Posts by Jacques Flambeau
Restful User
Jacques Flambeau's Avatar
Backwoods Alabama
Joined May 2000
Stuffing the stuffing tube
The Springer Tug has about 2-1/2 hours total running time on the clock. I need to get an idea of maintenance intervals and procedures on the grease-filled prop stuffing tube. On this boat the stuffing tube is by Graupner, using plastic (delrin) bushings with a 4mm shaft.
At the club meet we had Saturday I had I ran the boat for about an hour and water leakage through the stuffing tube. There was grease slung out on the inside and it leaked about 3/4oz of water. The stuffing tube was initially filled with white (lithium) grease, and I did have the feeling that I might not have completely filled it with grease when I built the boat. When I pulled the prop shaft this morning, there was significant water with the grease.
I was planning to pull the driveshaft and inspect it after a couple of hours running, anyway.
What should be service interval on the stuffing tbe grease be? I imagine that it needs regular maintenance, I wasn't expecting it after just a couple of hours. Is there way to check the grease quantity, short of disassembly? The stuffing tube has a soldered-on grease tube, but I had trouble squeezing grease into it from the tube on the first try.
What brand/grade of grease? Most folks I've asked suggest lithium (white) grease, but I have some "Super Lube" from Vacu-Boats which seems to have more "body". I have patr of a small tube, and think I can get more at the local Fastenal store.
http://www.super-lube.com/synthetic-...ease-ez-49.htm
--Bill
Jacques Flambeau is offline Find More Posts by Jacques Flambeau
Old Jun 20, 2010, 02:44 PM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
I would call the leak, insignificant...
I typically fill the stuffing tube with white lithium grease, from the
automotive store, then use the propeller shaft to push about three
strokes of grease back out of the tube.
I don't usually have any water in the boat via the stuffing tubes at all, but
I make my own stuffing tubes, and the bearing tolerance might be a bit tighter.
The ships usually go years before I regrease the stuffing tube.
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Jun 20, 2010, 08:21 PM
Restful User
Backwoods Alabama
Joined May 2000
This suprised me because I wasn't expecting a leak or maintenance this soon. Not a big deal, I have a sump around the drive shaft and everything is waterproofed. I'll re-do with a better fill of grease and see how it works. The more I think about it, the more I suspect that I simply didn't have enough grease.
--Bill
Old Jun 21, 2010, 02:30 PM
W.L Upshaw is offline
Find More Posts by W.L Upshaw
Owner of SSY
W.L Upshaw's Avatar
United States, CA, Long Beach
Joined Oct 2005
I always fill the stern tubes in my New Jersey with white lithium greese and when I run the shafts back in I put my finger tip over the opening at the forward end of the tube to minimize the amount of greese that gets pushed out of the tubes.
These tubes are 3/8" dia and are 14" and 17" long. They take a bit of greese. I will pull the shafts and clean out the tubes every couple of years.
W.L Upshaw is offline Find More Posts by W.L Upshaw
Old Jun 21, 2010, 03:01 PM
laser110 is offline
Find More Posts by laser110
Just Limin'
laser110's Avatar
United States, NJ, East Brunswick
Joined Nov 2008
On my recent Jim Wilder build I did the same as others an filled the tube with Lithium Grease. I filled the tube by placing some grease on a popsicle stick and packing it in from both ends. I then smeared grease all over the shaft and when I inserted the shaft some grease came out. So far I haven't had any leaks the grease helps keep the shaft moving freely in the stuffings tube.
Scott
laser110 is offline Find More Posts by laser110
Old Jun 21, 2010, 04:15 PM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
I do almost the same as Lee, I use lith. automotive wheel bearing grease. But I use a Hypodremic body to shoot the grease in. With no neele the hypo fits a 4mm perfectly, but can be used on a 3/16. you know exactly how much your putting in. Then just a finger over the other end when you push the shaft in.
GILL RC is offline Find More Posts by GILL RC
Old Jun 21, 2010, 07:29 PM
Restful User
Backwoods Alabama
Joined May 2000
I re-greased the stuffing tube today. I used compressed air to blow the old grease out and it was clear that there wasn't enough, so I probably didn't completely fill it the first time.
This time I squeezed white lithium grease into the stuffing tube til it ran out the forward end, covered the hole with my finger as I pushed the shaft in. Should work well.
--Bill
Old Jun 21, 2010, 07:32 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
I push some of the grease out, because one time I ran with freshly filled, and
full stuffing tubes, and the cool water of the pond changed the viscosity enough
to cause my boat to run very poorly. Once I had removed some of the grease, the
boat ran fine.
Old Jun 21, 2010, 08:32 PM
Restful User
Backwoods Alabama
Joined May 2000
Some grease did ooze out from the pressure of the inserted prop shaft, I didn't let it ooze freely. Off boating tomorrow, we'll see how it does.
--Bill
Discussion play in stuffing tube richardknox Racing Boats - Electric 10 Feb 08, 2010 04:13 PM
Discussion Equpage Riviera stuffing tube problems Riv Driver Dock Talk 6 Jan 10, 2010 07:38 PM
Discussion Equpage Riviera stuffing tube problems Riv Driver Dock Talk 0 Jan 10, 2010 02:59 PM
Question stuffing tube question dennischaves Scale Boats 8 Oct 06, 2009 09:04 AM
stuffing tube boot JimClark Racing Boats - Electric 3 Apr 04, 2003 02:20 AM
