Old Jun 02, 2006, 11:37 AM
rdeis is offline
Find More Posts by rdeis
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
Question
450XT for a warbird?
Hey, all- I've been researching motors and this esskay/skatty/or whatever one looks like it might be just the ticket for a slightly porky GWS warbird. I've got a 400XT on it now with an 8x6 and I'm just not quite comfortable with the way it flies.
Any of you using a 450XT on your warbirds?
What prop, airplane, and weight?
Thanks!
rdeis is offline Find More Posts by rdeis
Old Jun 02, 2006, 03:36 PM
SKYPILEIT is offline
Find More Posts by SKYPILEIT
did a reversed Immelman..once.
SKYPILEIT's Avatar
Novi, Michigan
Joined Nov 2002
Turbo 450 XT...
Great motors..!!I was so impressed with the test data I bought 2 of 'em and I use one in my 18 oz. SmoothE with 1320 TP Prolites.It produces over 180 watts with a 10X8 GWS hyperdrive prop and it will go verticle for about 200 feet.Well made motor and you should get one,to try on your warbird.I was thinking of installing the other on my Corsair.
SKYPILEIT is offline Find More Posts by SKYPILEIT
Old Jun 02, 2006, 03:47 PM
rdeis is offline
AMA 353531
rdeis's Avatar
Joined Aug 2003
Nice!
I'm hoping to pair it with a 3 blade prop to get a scale appearance. Whatcha think?
Old Jun 03, 2006, 02:21 PM
SKYPILEIT's Avatar
Novi, Michigan
Joined Nov 2002
450 XT with...
a three blader..??Sure,just check the amp draw and keep it below 15-16 amps static and you'll be fine.These motors are waaay powerfull,how much does you GWS warbird weigh..??Glassed ones are usually 22-24 ozs, and the 450XT with make 'em fly fast.
Old Jun 03, 2006, 06:27 PM
rdeis is offline
AMA 353531
rdeis's Avatar
Joined Aug 2003
Mine's 19. I prefer the FKS prop, but I think the draw will be a little high on that one- since a 10x6 hits it just about right, I think a 9x6x3 should do well, look better static, and let me run shorter gear. We'll see!
Old Jun 04, 2006, 01:01 AM
czechyour6 is offline
Find More Posts by czechyour6
überprüfen Sie Ihre sechs
czechyour6's Avatar
Central Utah
Joined Feb 2005
my buddy tried a 3 blade and it did not fly near as nice as the 8x6 prop on the ME109
czechyour6 is offline Find More Posts by czechyour6
Old Jun 05, 2006, 09:57 AM
rdeis is offline
AMA 353531
rdeis's Avatar
Joined Aug 2003
What size 3 blade, and how heavy is the airplane?
Typhoon micro 6 enough for a warbird? KasperE Power Systems 2 Jun 21, 2005 06:11 PM
Looking for Warbird v6focus Fuel Warbirds 11 Dec 26, 2004 12:46 PM
WTT Quick Charger for Warbird TreeCrasher Aircraft - Electric - Airplanes (FS/W) 0 Apr 27, 2004 09:34 AM
whats the best brushed setup for a warbird? annihilator Parkflyers 9 Apr 16, 2004 10:27 PM
where can i get a picture of a mouth for a warbird OzzieFlyer Parkflyers 16 Aug 23, 2003 09:48 PM
