Old Sep 28, 2003, 06:44 AM
Koichi Tanaka is offline
Find More Posts by Koichi Tanaka
Koichi Tanaka's Avatar
Japan
Joined Dec 2002
He can buy LTC 3200-5 with Linear Technology.
Linear Technology
MAX4020 can get a sample by MAXIM.
MAXIM
LM1117 is SOT-223 package.
78L05 regulator can use a 100mA thing.
>Which 4MHz and 6 MHz ceramic resonators? yes.
Koichi
Koichi Tanaka is offline Find More Posts by Koichi Tanaka
Old Sep 28, 2003, 07:20 AM
Dindea is offline
Find More Posts by Dindea
Dindea's Avatar
United States, TX, Fort Worth
Joined Sep 2003
Koichi
I'm sorry, I meant which package are you using of the 78L05, the SOT-223 also?
Thanks!
Dindea is offline Find More Posts by Dindea
Old Sep 28, 2003, 08:09 AM
Japan
Joined Dec 2002
The picture of 78L05.
It can use in other form.
Old Sep 28, 2003, 10:29 AM
Dindea is offline
Dindea's Avatar
Joined Sep 2003
I am so new to electronics! I have only worked with disk and electrolytic!
When I go to Digi-Key to look for a 0.047F capacitor, it asks what type.
1 10F
1 22F
1 0.1F
3 0.047F
What type of smt caps are you using in the Rx?
3 1F
2 0.1F
Old Sep 28, 2003, 10:37 AM
Dindea is offline
Dindea's Avatar
Joined Sep 2003
What I mean to ask is:
I search on smt capacitors and it comes back and asks:
Ceramic (25 items)
Electrolytic (1062 items)
Tantalum (453 items)
Are you using Tantalum in both the Tx and Rx?
Old Sep 28, 2003, 11:03 AM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
small values will tend to be ceramic this is most stuff below 1uF.
You can also get ceramics over 1uF but these are more rare. Murata do some nice ones though and they are the lightest option.
Tanalum are what of the cheaper 1uF+ caps are, they are very good but can be more chunky and heavy.
Electrolytics are generally the large capacitors and not surface mount.
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Sep 28, 2003, 11:37 AM
jberg is offline
Find More Posts by jberg
jberg's Avatar
MSC Rdinghausen, Germany
Joined Feb 2001
Dindea,
if you are searching for capacitors for the DC/DC booster then study the datasheet of the IC you want to use until you understand it completely. At least the Linear Technologies datasheets are excellent. Most probably you will want to use multilayer ceramics capacitors with DC/DC boosters. These are quite new designs. They are available for instance from Kemet or Panasonic, in stock at Digikey. Search for keywords "capacitor", "ceramic", "multilayer", "smt", then probably the Panasonic ones are the cheaper ones. Prefer X5R types, followed by X7R, do not use Y5V ones (these are too much temperature dependent).
Multilayer ceramic types are available in small smt housings like 1812 or 2220 up to 22uF or so. You will need a rated voltage of 10V or better 16V.
Good luck!
Regards, Jochen
jberg is offline Find More Posts by jberg
Old Sep 28, 2003, 07:29 PM
Dindea is offline
Dindea's Avatar
Joined Sep 2003
Thanks!
Thank you all for helping me so much!
Old Sep 28, 2003, 08:24 PM
Japan
Joined Dec 2002
Dindea,
Three capacitors of 0.047uF currently used for the transmitter are very important parts. A polyester film capacitor with high stability is used. It is set to P4589-ND in Digi-Key.
Koichi
Old Sep 28, 2003, 09:11 PM
Dindea is offline
Dindea's Avatar
Joined Sep 2003
The rest of the caps in the tx (the blue ones values 10F, 22F and 0.1F) are they just any regular tantalum cap?
Do you have a good part number for the IR LED's?
Thank you so much!
Old Sep 28, 2003, 09:49 PM
Japan
Joined Dec 2002
18, SLR931A, ???
LED equivalent to SLR931A has come out of many makers.
1, 10F cap,???
1, 22F cap, ???
Even if the capacitor of 10uF and 22uF is not the surely same capacity, it can be used. In Digi-Key, 22uF/16V of P5135-ND, P2040-ND, etc. can be used.
1, 0.1F cap, ???
It is in Digi-Key in large numbers. BC1114CT-ND, BC1139CT-ND, BC1145CT-ND, BC1157CT-ND, BC1084CT-ND, etc.
Old Sep 28, 2003, 10:52 PM
Prashanth is offline
Find More Posts by Prashanth
Bangalore Hindustan, India
Joined Apr 2003
hey dindea
instead of the LTC chip u can use the maxim 1595 chip write to them its free, they will send u 2 of these chips, I also had the same problem sourcing the LTC, i now have the Maxim chips in post...should reach any time
Brgds
Prashanth
Prashanth is offline Find More Posts by Prashanth
Old Sep 29, 2003, 01:53 AM
billystiltner is offline
Find More Posts by billystiltner
billystiltner's Avatar
United States, VA, Clintwood
Joined Nov 2002
The package of the 1595 would be max1595EUA50 8Leg uMax,uSop
Make sure you get the 50 it's the 5 Volt version.
While you are there you can get the Max4020 also. The
package I think would be 14/SO. 150.
I also had a hard time figuring out which packages but then I studied the package outline documents at Maxim. And it's a bit easier now.
http://www.maxim-ic.com/cgi-bin/packages?Type=Max
It would be nice to have a document with all the parts n packages for the Mini IR TX,IR TX Ver2, IRXA301,IRXA301-2, and Pic Programmer as well as where you can get them for the next DIYers.
I guess Digikey carries everything but the Maxim chips.
Here are some links which might be helpful to learn a little about
SMD.
SMD Code Book
http://www.marsport.demon.co.uk/smd/mainframe.htm
SMT Prototyping Hints and Tips
http://www.geocities.com/vk3em/smtguide/smtguide.htm
This project has put the fun back into electronics for me.
Koichi Tanaka I appreciate you making this information available.
Billy
billystiltner is offline Find More Posts by billystiltner
Old Sep 29, 2003, 02:55 AM
Dindea is offline
Dindea's Avatar
Joined Sep 2003
If there are any errors in the part numbers, let me know and I will make corrections... Thanks!
The order is Quantity, Name, Part# (Digi-Key)
Rx IRXA301 (actuators)
1, PNA4614M (56.9kHz), PNA4614M00XD-ND
1, LTC3200-5, LTC3200ES6-5 or MAX1595EUA50
3, 1F cap, 445-1360-1-ND or PCC2249CT-ND (cheaper)(Only need 2 if using MAX1595)
1, .22F cap, 445-1352-1-ND if using MAX1595
2, 0.1F cap, 399-1167-1-ND
1, PIC12C509A, PIC12C509A-04/SN-ND
1, IRLML2502, IRLML2502CT-ND
Rx IRXA301-2 (actuators)
1, MAX4020, MAX4020ESD
Rx IRXS312 (servos - 1 Lithium Cell)
1, PNA4701M (36.7kHz), PNA4701M-ND
1, 6MHz Ceramic Resonator, 490-1211-ND
1, PIC12F629, PIC12F629-I/SN-ND
1, 33F cap, P11311CT-ND
1, 51 Ohm resistor SMD 0805, 311-51.0CCT-ND
Rx IRXS312B (servos - 2 Lithium Cells)
1, LM1117, LM1117MP-5.0CT-ND
TRANSMITTER (Mini Infrared)
1, 10F cap, P5134-ND
1, 78L05, AN78L05-ND
1, 22F cap, P5135-ND
1, 0.1F cap, BC1114CT-ND
3, 0.047F cap, P4589-ND
1, Joystick, Nobel Miniature from Didel (bottom of the page) or from PS one controller
1, 4.7K resistor, 4.7KQBK-ND
3, 3.3K resistor, 3.3KQBK-ND
1, 10K resistor, 10KQBK-ND
6, 10 ohm resistors, 10QBK-ND
1, PIC16F84A, PIC16F84A-20/P-ND
1, 4MHz Ceramic Resonator, 490-1208-ND
18, Infrared Emitters, LNA2903L-ND
JDM PIC Programmer
1, 10K Resistor, 10KQBK-ND
1, 1.5K Resistor, 1.5KQBK-ND
1, 5.1V/0.5W Zener, 1N5231BMSCT-ND
1, 8.2V/0.5W Zener, 1N5237BMSCT-ND
4, 1N4148, 1N4148FS-ND
1, DB9 connector, 209F-ND
1, 18-pin Socket for PIC, ED3118-ND
1, 100F/25V Capacitor lytic, P5152-ND
1, 22F/16V Cap tantal, 399-1330-ND
2, 2N3904 Transistor NPN, 2N3904D26ZCT-ND (substitued BC547B)
Needed for programming SOIC PIC's
Flat Package Adapter
2, Nylon screws, ???
1, 1.6mm glass epoxy baseplate, ???
1, PCB, PC96-ND
1, 8-pin socket, AE9808-ND
OR
jberg's test clip
1, 8 Pin Gold SMD Test Clip, 923655-08-ND ($11.35 USD)
Old Oct 01, 2003, 06:26 AM
david_dewit is offline
Find More Posts by david_dewit
Australia
Joined Sep 2001
Maxim charge pump uses two 1uF caps and one 0.22 cap.
Dave
david_dewit is offline Find More Posts by david_dewit
airwars "infra-red combat system for planes" Tree_Magnet Power Systems 15 Jan 08, 2008 09:41 PM
Discussion DIY conversion to infra red Tom Harper Aerial Photography 46 Jun 25, 2006 05:43 PM
Infra-Red Thermometer for Helis rscamp Electric Heli Talk 7 Jan 08, 2002 06:11 AM
airwars "infra-red combat system for planes" Tree_Magnet Foamies (Kits) 4 Aug 02, 2001 12:15 AM
Infra red transmitter and receiver for micro size aircraft Ron MIller Power Systems 2 May 28, 2001 09:51 AM
