Old Apr 16, 2014, 09:39 PM
Balsabird is online now
Find More Posts by Balsabird
Balsadustus Producerus
Escondido, CA USA
Joined Jan 2001
Compressed-air engine mystery
While attending the '14 AMA EXPO January last, I found this in the Swap Shop. Of course, the 'made in Ireland' on the box caught my attention. Upon opening that box, I found this engine inside. The seller, an engine collector, had no idea what it was or what it would be used for. I bought it as I thought "Cool, a compressed-air engine!" As small as it is, it's definitely not a CO2 engine--it's not built strong enough. I think the Tipperary box is a red herring, as the engine is not made of butter though the engine and the restraint surrounding it is a perfect fit. Haven't tried connecting it to air, yet. My thought is going through an air pressure regulator I use for airbrushing, and slowly run up pressure until something happens. For an idea of actual size, that's a Tornado Series 15 7x3 wood prop in last picture.
Any ideas?
Balsabird is online now Find More Posts by Balsabird
Old Apr 17, 2014, 01:33 AM
Reginald is online now
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
You do have an engine that is intended to be run on compressed air indeed. Here are some examples of other engines. The reservoir of air shown here was in fact the fuselage of the airplane and made of very thin copper sheet, in some cases it was wound with thin wire to withstand even more the inside pressure.
Reginald is online now Find More Posts by Reginald
Old Apr 17, 2014, 08:34 AM
Leadchucker is offline
Find More Posts by Leadchucker
AMA7224 LSF1832
Leadchucker's Avatar
United States, DE, Millsboro
Joined Sep 2008
A challenge in some ways, but CA engines can fly. Witness this beautifully executed and flown model at Warminster, PA contest a few years back.
Free-Flight Mauboussin Hemiptere, 1992 (2 min 52 sec)
Leadchucker is offline Find More Posts by Leadchucker
Old Apr 17, 2014, 08:58 AM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
The compressed air engines were the way to go during the early days of model airplane flying. At the time it was hand tossed, rubber band catapult launcher methods, rubber band powered, or compressed air systems. The compressed air motors tended to win most of the contests at that time too. I think they continued to win many championships up into the 1930's too. They even beat out the early model airplane ignition engines too.
It looks like they soldered it together and then nickle plated or chromed it. That tends to have me thinking that the little motor was made in Japan, as they like to spruce things up to make them look good.
earlwb is online now Find More Posts by earlwb
Old Aug 16, 2014, 05:57 PM
bradypodion is offline
Find More Posts by bradypodion
Sweden
Joined Sep 2004
Hi Balsabird, your engine seems very much like an engine referred to in Bert Pond's book "Expansion engine powered model aircraft", p. 69: width 1", cylinder OD .156". That engine was designed and built by Jim Walker of U-control fame. Maybe yours is a replica?
Have you tried to run it?
Cheers,
Johan
bradypodion is offline Find More Posts by bradypodion
Old Aug 20, 2014, 11:40 AM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Thanks for the video, never saw a CA powered model flown before, amazed at power and duration. Was tank filled with a bicycle pump?
E-Challenged is offline Find More Posts by E-Challenged
Wanted Bendix Special and Travel Air Mystery Ship chrispkaiser Aircraft - Electric - Airplanes (FS/W) 1 Mar 09, 2014 05:28 PM
Sold Model engine compression gause DYN2514 $35 shipped Mike Fortune Aircraft - Fuel - Engines and Accessories (FS/W) 1 Nov 14, 2013 10:21 PM
Sold Gas Engine W/ Mag Converted Good Compression gva1956 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Oct 10, 2013 07:20 PM
Video A compressed air engine AZInventor1 Car Talk 9 May 29, 2010 08:41 PM
Brass compressed air engine, Plans,Links appy2day Electric Plane Talk 8 Apr 01, 2003 01:49 PM
