Old Mar 23, 2014, 09:24 PM
EZ Money is offline
Find More Posts by EZ Money
EZ Money's Avatar
Nampa Idaho
Joined Jun 2006
Elevator trim changes every flight
I have a PA Katana that flies fine except for the fact that I have to either add or take away elevator trim every time I fly it. Sometimes in the middle of a flight.
I thought it was excessive play in the elevator linkage but I changed all the linkage and added ball links.
I checked the CG between flights to make sure that the battery is in the same place. The elevator servo seems to center, at least on the bench.
Tried everything. Any suggestions?
Thanks in advance.
Ron
EZ Money is offline Find More Posts by EZ Money
Old Mar 23, 2014, 10:05 PM
Doc Austin is online now
Find More Posts by Doc Austin
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I just had a servo that was doing that and after I checked everything with no results, I finally changed the servo and that fixed it.
Doc Austin is online now Find More Posts by Doc Austin
Old Mar 24, 2014, 12:18 AM
camoy is offline
Find More Posts by camoy
I can't fly
camoy's Avatar
United States, CO, Parker
Joined Dec 2006
I agree it sounds like a servo centering issue when it is under load. Is it a digital or analog servo?
camoy is offline Find More Posts by camoy
Old Mar 24, 2014, 12:37 AM
Depronicus is offline
Find More Posts by Depronicus
Altitude is my friend...
Depronicus's Avatar
Southern California
Joined May 2009
I dunno, but it seems like this has to be the arm slipping on the servo output shaft.
Depronicus is offline Find More Posts by Depronicus
Old Mar 24, 2014, 01:12 AM
GPT is online now
GPT
Find More Posts by GPT
GPT
GPT's Avatar
Sydney,Australia
Joined Dec 2004
Other than a dud servo, check that the servo isn't moving in the servo cutout in the fuse, and that there is no cracking in the wood in the servo hole area.
GPT is online now Find More Posts by GPT
Old Mar 24, 2014, 06:54 AM
KE Spin is offline
Find More Posts by KE Spin
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
I had a similar problem and thought it was the servo but found that he control horn had actually come loose and was moving in the slot.
KE Spin is offline Find More Posts by KE Spin
Old Mar 24, 2014, 07:00 AM
C_Watkins is online now
Find More Posts by C_Watkins
This is NOT a TOY?
C_Watkins's Avatar
United States, GA, Atlanta
Joined Jul 2011
Just to make sure:
Go to full deflection, then 'ease' the stick back toward center, and see if it stays deflected some in that direction.
(Don't let the stick bang back to center. Ease it there.)
Then full deflection the other way, and ease back to center again, and see if it stays deflected some in that direction as well.
If it's really coming all the way back to center after each of those, then that's an odd one.
Possibly a dirty/bad/loose pot, either in the servo, or in your gimbal. Or some floating bit of debris, perhaps.
It's also 'possible' though unlikely, that there's some sort of thermal drift happening.
Honestly, I'd just fit a different servo first, and go from there.
Afterthoughts:
Have you given the control horn in the elevator a good wiggle, to make sure it's still secure?
Broken hinge(s)?
Loose/cracked wood in the elevator, or the joiner between the halves?
Solar flares, sunspots, zombie invasion? I dunno. Just brainstorming
Edited to add:
I see someone else had the same thought while I was posting. Definitely seen the 'loose horn' thing before
C_Watkins is online now Find More Posts by C_Watkins
Old Mar 24, 2014, 09:34 AM
EZ Money is offline
EZ Money's Avatar
Nampa Idaho
Joined Jun 2006
Great responses. I will replace the servo and upgrade it to an 85MG.
Thx
Ron
Old Mar 24, 2014, 12:03 PM
GravyRobber is offline
Find More Posts by GravyRobber
I fly. I'm pilot.
GravyRobber's Avatar
United States, TN, Memphis
Joined Oct 2012
I'll second the suggestion the check the control horn. I had the same issue as you, tried everything, and eventually traced it back to a loose control horn. It's worth checking.
GravyRobber is offline Find More Posts by GravyRobber
Old Mar 25, 2014, 05:59 PM
modbuilder is offline
Find More Posts by modbuilder
KJ4WFG
modbuilder's Avatar
United States, SC, York
Joined Dec 2007
Am assuming that the trim changes are needed at the same throttle setting one time to the next ?
modbuilder is offline Find More Posts by modbuilder
Discussion Trimming elevators on a maiden flight AgentSmith27 Beginner Training Area (Aircraft-Electric) 6 Aug 19, 2011 01:27 PM
Discussion Elevator Trim Change when Gear go up or down zoomer02 Hitec/Multiplex USA 3 Mar 31, 2011 02:18 PM
Discussion Trimming after every flight Torch8 Beginner Training Area (Heli-Electric) 7 Aug 09, 2010 07:06 AM
Discussion Trimming Elevator for Slow Flight chadtheguru Beginner Training Area (Fuel) 26 Aug 28, 2006 01:10 PM
Discussion High RPM elevator trim change LilSki Mini Helis 8 Feb 14, 2006 09:00 PM
