Old Jan 26, 2014, 01:37 PM
Suko is offline
Find More Posts by Suko
Suko's Avatar
United States, WA, Mukilteo
Joined Apr 2013
Question
Waterproof retracts?
So, I went out flying yesterday and upon landing, mud got splashed up onto the underside of my planes. My retracts weren't working right afterwards. I cleaned it off as best I could, and even sprayed a lot of WD40 and compressed air into the housing, but it's still not working 100% right.
My question is; can I use a spray jet of water to try and clean out/dislodge any debris that might be inside the retract's housing? Alternatively, I have a sonic cleaner I would LOVE to just drop these into and let that clean it, but I'm afraid I'll kill the retracts if they aren't water proof.
In case it matter, here's the two retract types/brands I need to clean:
https://www.hobbyking.com/hobbyking/...2pc_29_0g.html
http://www.parkzone.com/Products/Def...ProdID=EFLG100
Suko is offline Find More Posts by Suko
Old Jan 27, 2014, 10:15 AM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
I would say those are most likely not water proof and spraying WD-40 was probably not a good idea. Electrics and water generally dont mix. Not sure what you mean by not working, so I can only assume something may have been bent during the landing.
Edwin
edwin1 is offline Find More Posts by edwin1
Old Jan 27, 2014, 01:31 PM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I'm not sure just how the electric retract works, (I only use the mechanical ones), I would assume there is some sort of travel limit switch, or switches inside to detect the end positions. Again a bit of a guess, but they are just a screw drive ?
I also believe that they automatically shut down if stalled, (wheel jam etc), so any dirt in the rotation area may load the action enough for them to shut down.
If they haven't got good shielding from dirt and water, they probably need a complete strip down to be properly cleaned, spaying anything in there could just push any dirt into the wrong place.
eflightray is online now Find More Posts by eflightray
Old Jan 27, 2014, 02:09 PM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
Best bet is to remove them and use electrical contact cleaner/MAF cleaner. Might even rinse in fresh water and then into a warm oven that is not still turned on to dry.
What ever you do don't power them until complety dry.
If mechanicals are not a option then obviously do not fly when water or mud is present from here on out.
1320fastback is offline Find More Posts by 1320fastback
Sold DJI Phantom V2 w/ Retracts / Futaba T8FG Super /Mini OSD/ Bluetooth/ Waterproof case Lroc130 Aircraft - Electric - Multirotor (FS/W) 1 Dec 26, 2013 02:39 PM
Sold xl5 waterproof esc + traxxas waterproof servo 3d astronaut Cars - Cars and Parts (FS/W) 4 May 25, 2013 10:01 AM
Discussion Waterproof LED's stop working when waterproofing removed. Why??????? panther3001 Night Flying 9 Sep 07, 2012 06:53 PM
Help! how do u make esc waterproof tekin rx8 combo etc and more sytem to make waterproof stampede vxl Off-road Cars 7 Dec 24, 2010 09:32 PM
Discussion waterproof / waterproofing servos? dalbert02 UAV - Unmanned Aerial Vehicles 3 Nov 16, 2009 04:34 PM
