Old Jan 08, 2013, 01:03 PM
sweatybetty is offline
Find More Posts by sweatybetty
sweatybetty's Avatar
United States, OR, Roseburg
Joined Jan 2012
Help!
twisted fuse
one of the older members of our club gave me this easy sport 60. it is pretty much done except the covering. i finished the covering on the wing and horizontal stab and placed them on the fuse here are some pics
sweatybetty is offline Find More Posts by sweatybetty
Old Jan 08, 2013, 01:07 PM
Joined Jan 2012
so i need to somehow either remove the twist or maybe just re-cut the slot for the stab so it is level with the wing. will the plane fly right with the fuse being twisted if the stab and wing are level?
thanks all
Old Jan 08, 2013, 01:20 PM
kenh3497 is online now
Find More Posts by kenh3497
Goodnight Irene
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
The fuse looks strait enough. Sand the slot where the stab goes in and glue it home. You may have to add a small shim to fill the gap. (top side of the stab) I would worry more about getting the bottom of the stab saddle level with the wing. It will fly fine.
Ken
kenh3497 is online now Find More Posts by kenh3497
Old Jan 08, 2013, 01:27 PM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
It's not possible to see if the fuselage is actually twisted, or the slot is just at fault.
Either way, I would re-cut the slot on one side and use a packing piece to level the stab.
eflightray is online now Find More Posts by eflightray
Old Jan 08, 2013, 06:32 PM
Joined Jan 2012
thats a good point. i never thought to check to see if the fuse is actually twisted, i just assumed it was.
thanks to you both.
Old Jan 08, 2013, 10:02 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
At this point just open up the slot and pack in the open side of the slot once the tail is level. A LOT less trouble than trying to open the fuselage back up and twist it straight.
No one but you us and millions (OK, "hundreds") of RCG readers will ever know that there was an issue at one point.
BMatthews is offline Find More Posts by BMatthews
Old Jan 09, 2013, 11:12 AM
epoxyearl is online now
Find More Posts by epoxyearl
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
Some of the 'free flighters' intentionally mount the stabs oa about that moch of an angle,so the model will glide in large circles.
The previous posters have spoken the truth...Level it shim it,and glue it in place.
epoxyearl is online now Find More Posts by epoxyearl
Latest blog entry: Balsa cowls
Help! Removing a twist in fuse thorbo Thermal 14 Jun 20, 2007 08:23 AM
Discussion Straightening a twisted fuse target Composites Fabrication 25 May 01, 2007 03:32 PM
For Sale Twist NEW Fuse and used wing Chesie2 Aircraft - Fuel - Airplanes (FS/W) 4 Jul 28, 2006 12:20 AM
Twist free fuse KatManDEW 3D Flying 42 Dec 24, 2004 12:01 PM
Anyone notice a twist in the mustang fuse nalondivad Parkflyers 3 Feb 27, 2003 01:10 PM
