Old Mar 25, 2012, 08:02 AM
davidmc36 is offline
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Question
Would two recievers have any use?
I was playing around testing two Rx's that I bought and wondered if you bind them both to the same model memory, will they both work at the same time.
Sure enough they will.
Is there any use for doing this that you could not achieve with "Y' cables. I can't think of any.
davidmc36 is offline Find More Posts by davidmc36
Old Mar 25, 2012, 08:34 AM
S3NFO is offline
Find More Posts by S3NFO
USA, CA, Santee
Joined Jul 2002
A lot of the Giant Scale guys run 2 Rx's. You run the right ail, right elev and rudder on one and the left ail, left elev and throttle on another. Gives you redundancy if one fails, you still (may) have enough control to get the airplane back, and, if you're running multiple servos on control surfaces, such as 3 servos on rudder and 2 servos on ail, running 2 Rx's allows you to run the servo's direct and reduces the power through the Rx's internal power buss.
S3NFO is offline Find More Posts by S3NFO
Old Mar 25, 2012, 10:52 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
OK Iv'e never got into anything huge like that so it never occured to me.
So it could be an alternate way to using one of the big power modules.
Old Mar 25, 2012, 10:59 AM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Also, some people use a second receiver for ground or water steering. In the first case, they have a takeoff dolly with its own steering receiver that gets left on the ground when the model lifts off. In the other case, the water rudder on a float plane is controlled by a separate receiver, thus eliminating the need for either mechanical linkages from the air rudder or a servo cable to the float.
In another application, you can set up a wireless buddy box system by using two receivers (and two transmitters) with a switch in the model. The master radio (instructor) uses an additional channel to determines which radio is in control. I have just set up such a system using the HobbyKing Assan switch. I haven't flown it yet, but it works perfectly on the bench.
EDIT: Flew it this afternoon and it worked exactly as expected.
If either radio loses signal, the switch goes automatically to the other, meaning that you could also use the switch as a redundant setup with one transmitter driving two receivers.
Where to get them:
This is the so-called 8-channel switch (since one channel is needed to operate the switch, only seven are switched between the two receivers);
http://www.hobbyking.com/hobbyking/s...dProduct=18703
Here's the four-channel (which really does have four switched channels):
http://www.hobbyking.com/hobbyking/s...dProduct=20002
Note that you need a package of 10 male-to-male leads like this (or you'll go nuts making your own).
http://www.hobbyking.com/hobbyking/s...0pcs_set_.html OR
Daedalus66 is offline Find More Posts by Daedalus66
Old Mar 25, 2012, 11:18 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Originally Posted by Daedalus66 View Post
Also, some people use a second receiver for ground or water steering. In the first case, they have a takeoff dolly with its own steering receiver that gets left on the ground when the model lifts off. In the other case, the water rudder on a float plane is controlled by a separate receiver, thus eliminating the need for either mechanical linkages from the air rudder or a servo cable to the float....
I like that idea. It could make switching from floats to wheels much simpler. It would not add much weight if you were running a six foot or so airplane since the float battery would not need to be all that large.
Old Mar 25, 2012, 11:42 AM
dickw is offline
Find More Posts by dickw
Grow old disgracefully!
dickw's Avatar
Luton, UK
Joined May 2006
I sometimes fly in competitions for electric gliders where we have to provide a second receiver to be plugged into the scoring system so the scoring system knows if our motor is on or off.
I even have a third receiver that starts a pair of "talking stopwatches" that help me second guess the scoring system!.
I believe some people operating robots use more than one receiver so they don't have to get wiring through 360 degree rotating joints.
The possibilities are endless.
Dick
dickw is offline Find More Posts by dickw
Old Mar 25, 2012, 12:22 PM
jjkupinski is offline
Find More Posts by jjkupinski
TigreJohn
United States, CA, Corona
Joined Aug 2008
Among other things, you may need two receivers when you need a channel mix that is not pre-programmed into your transmitter. I ran into a problem where I had a dual servo situation where I had to use a manual mix. Dual elevator servos where I had to reverse one servo because of the plane construction. Found I had no trim function available on one servo. Solution was to install second receiver which was less expensive than a radio with more channels and functions.
jjkupinski is offline Find More Posts by jjkupinski
Old Mar 25, 2012, 01:39 PM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Originally Posted by dickw View Post
....I believe some people operating robots use more than one receiver so they don't have to get wiring through 360 degree rotating joints....
I sort of thought robot applications because I imagined
folks wanting a lot of servos. The rotating joint solution would sure help make construction easier in a lot of cases. I saw the video of the guy who has been excavating his basement for the last fifteen years or so with RC backhoes and the like. It could allow you to make the platform of a High-Hoe go full circles without reversing.
Old Mar 25, 2012, 01:41 PM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Originally Posted by jjkupinski View Post
....Dual elevator servos where I had to reverse one servo because of the plane construction. Found I had no trim function available on one servo. Solution was to install second receiver which was less expensive than a radio with more channels and functions.
How did you make that work?
Old Mar 25, 2012, 02:07 PM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Not only the redundnacy aspect and safety - but having multiple Rx's can get rid of servo lead extenders that can in fact detract from signal strength ... inductance and all that jazz ..
By having the extra Rx - you can mount it close to location needed.
It used to be a req't of LMA in UK - I assume it's still the case ?
They also req'd back up Rx power systems either in dual active or main with auto switched back-up. I still have an auto switcher called a Battery Backer from my LMA days in UK.
(LMA = Large Model Association)
solentlife is offline Find More Posts by solentlife
Old Mar 26, 2012, 11:14 AM
TigreJohn
Joined Aug 2008
Hate to admit it, I really don't know, I'll have to ask. The guy who sold me the second receiver and servo set it up.
In retrospect, I may been suckered into buying that second receiver. I have since found out you can reverse a servo by switching wires on the pot. I can't see reversing polarity on either second item as the electronics wont work. If so, I should have been able to use just a Y-connector on the two servos with one modified.
Old Mar 26, 2012, 01:47 PM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Inquiring minds would sure like to know
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Mar 26, 2012, 02:46 PM
k2k is online now
k2k
Find More Posts by k2k
k2k
k2k's Avatar
United States, CA, Oceanside
Joined May 2003
The wires on the pot AND the motor have to be swapped.
k2k is online now Find More Posts by k2k
Old Mar 26, 2012, 03:31 PM
pilotpete2's Avatar
Joined Jun 2004
Yes, that's how you can reverse a servo if need be.
The question was in regard to how on earth using another receiver would be of help, since in this case it would amount to no more than an expensive Y harness for all channels
Pete
Old Mar 26, 2012, 04:33 PM
Evan D is online now
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
I have two orange 6ch with satellite receivers in this airplane. It is much easier to do that than run all the extensions and stuff.
It's about 11 years old and flew on two Hitec 555 receivers for years.
Evan D is online now Find More Posts by Evan D
Discussion Anyone have any British Pounds and would like Dollars? RicVaughn Atlanta Area RC 4 Dec 03, 2011 03:55 PM
For Sale Elvis would have used this to learn to fly! Rabid Toast Aircraft - General - Miscellaneous (FS/W) 3 Oct 04, 2011 04:26 PM
Discussion What FPV product would you like to have/use? ssassen FPV Talk 76 Apr 29, 2009 05:38 PM
For Sale I Have Black Heat Shrink For Esc,or About Anything You Would Like To Use It For matthew james Aircraft - General - Miscellaneous (FS/W) 2 May 26, 2006 09:29 AM
Would like to use batts I have on Tipsy Ron D Foamies (Kits) 4 Dec 08, 2001 09:00 AM
