Old Aug 22, 2006, 12:49 AM
los angeles,ca
Joined Jun 2001
Help!
I'm stumped, someone help please
hi,
i am trying to setup my dragonfly going separates following the diagram provided by helihobby's website. i have an astro 010 and a brushed tail with gy240. my tail wont work even if move my gyro around. i tested the gy240 with a servo and it works. can some one help me solve this problem. thanks
bill
billyboy is offline Find More Posts by billyboy
Old Aug 22, 2006, 01:09 AM
registered dub
Central N.H. USA
Joined Dec 2005
what esc are you using for your tail?
what you may have to do is plug in your batt and let the gyro initialize,go full left rudder stick to initiaize the esc.once the tail starts to turn flip the rudder stick left/right 3 times to tell the gyro to go back to center as the rudder stick left hold to initialize the esc will be left in the gyro as a direction change.than all should be good.
make sure you have the "revo mix"turned off in your tx
if all fails plug in your tail esc into the rx (remove the gyro connections) to verify the arming procedure and operation of the tail esc.
ptremb is offline Find More Posts by ptremb
Old Aug 22, 2006, 06:00 PM
los angeles,ca
Joined Jun 2001
i am using the gws ics100 5amp esc for the tail a phx25 for the astro and gy 240. my tail esc does work. just cant figure it out.
bill
Old Aug 22, 2006, 07:03 PM
That'll hold until ...
swatson144's Avatar
Hampton Roads Va.
Setting L rudder limit to 0 usually works fo me.
Steve
swatson144 is offline Find More Posts by swatson144
Old Aug 23, 2006, 11:36 AM
los angeles,ca
Joined Jun 2001
do u mean set my L rudder epa to 0.
Old Aug 23, 2006, 12:22 PM
Vince Herman's Avatar
United States, OH, Strongsville
Joined Nov 2000
I do as ptremb mentioned. I power up, let the gyro initialize, and then hold left rudder until the tail ESC can initialize.
Vince
Vince Herman is offline Find More Posts by Vince Herman
Old Aug 27, 2006, 10:21 PM
swatson144's Avatar
Hampton Roads Va.
Yes. The tail ESC sees center stick as 0 throttle and arms. Main rotor torque takes care of Left yaw and the motor isn't used.
Steve
Help! YF-23 cross sections! Someone help PLEASE!!! Jetset Electric Ducted Fan Jet Talk 109 Oct 01, 2005 11:56 PM
Help! Stumped, Sad, Low confidence... help?..... Please? racingnismo Micro Helis 21 Aug 18, 2004 04:29 PM
Rave Help Please!! I'm trying to hookup a Zagi with no manual!!! mvking Flying Wings 3 Aug 03, 2004 01:14 PM
Someone help me out here, please.... badbill 3D Flying 3 Jul 25, 2004 06:12 PM
GWS ME-109 and Razor 400 on hold till I get an Answer!! Please someone help me. Electriflight Parkflyers 5 Aug 16, 2003 10:09 AM
