Old Oct 13, 2014, 10:52 AM
Hurts so good!
Joined May 2008
I need engine size help
Can you help me with engine sizes? Physical size actually.
I bought another vintage 1/2A racing airplane kit. It will be my next build since I am liking the physical size of these airplanes. Usually around 36" wingspan.
Anyhow, the kit box says .049-.06 engines. So my very first thought was Norvel .61?
Then I see there is a Norvel Big Mig .074?
Now if you are like me you are thinking WOW that's 3/4 of a whole cubic inch!!! What a whopper!! J/k
Well actually I was thinking, I wonder if the .061 and the .074 engines are the same physical size? I have never had a Norvel and know nothing about these 1/2A engines except that I like them :-)
Can you help me choose an engine for this old racer plane? In exchange, I would be more than happy to post pictures here as I build it.
King of Plane is offline Find More Posts by King of Plane
Old Oct 13, 2014, 12:03 PM
Western KY
Joined Sep 2003
Here you go:
Andrew0820 is online now Find More Posts by Andrew0820
Old Oct 13, 2014, 12:21 PM
Hurts so good!
Joined May 2008
Thank you for that Andrew. That answers that. Not the same size physically.
Old Oct 13, 2014, 01:06 PM
surfer_kris's Avatar
Sweden
The Norvel .074 can handle a larger prop (6x4-7x3) without any problems, plus it throttles well and the weight penalty over the .061 is not much to talk about. So the .074 engine is thereby much better suited for most regular sport applications if one uses the throttle sensibly.
The .061 prefers props around 5x3, and although it will easily spin this at around 22krpm, it just doesn't suit all planes.
If your racer really is a "racer" with a thin symmetric wing and low drag fuselage etc, then the .061 will do fine of course. A wingspan of 36" is pretty large though, something around 27-28" is better suited I think, depending on the profile etc too.
surfer_kris is offline Find More Posts by surfer_kris
Old Oct 13, 2014, 01:12 PM
Hurts so good!
Joined May 2008
I wonder which engine would be more suited to the Pilot Ricky Rat racer?
I don't have the kit (which appears as if it has full size plans) in my possession yet.
So my concern is the physical size of the engine due to the box stating .049 - .06
Old Oct 13, 2014, 02:31 PM
toad007's Avatar
United States, UT, Eagle Mountain
Joined Dec 2004
I built one of these way back when also. I used a TD.
I am sure a norvel AME revlite version .061 would be a hoot in it. or any of the current russian combat engines or the VA .049 Vll. If I had the kit the VA would be my first choice then the revlite. Thing was fast on a stock TD. The VA would for sure haul the mail in it.
toad007 is offline Find More Posts by toad007
Old Oct 13, 2014, 02:33 PM
Amp Abuser's Avatar
Joined Dec 2007
Do you have a year date idea when the plane was designed or kit was made?
I would go with the .074 hands down do to span and SQ / IN.
This being your second pylon plane you will want some speed you can always throttle back but if you are tapped out on throttle you can only wish.
Amp Abuser is offline Find More Posts by Amp Abuser
Old Oct 13, 2014, 02:49 PM
Hurts so good!
Joined May 2008
Thanks Toad. I will Google that VA engine you reference (and get that OS engine packaged up for you )
Amp, I don't have the kit yet but will soon enough. When I get it, I will look for any kind of date on the kit/plans. I've never had a Pilot kit before so don't know if they're dated anywhere.
Old Oct 13, 2014, 03:03 PM
Sailaire brethren
United States, KY, Bowling Green
Joined Aug 2013
cox TD .061?
RV Winkle is offline Find More Posts by RV Winkle
Old Oct 13, 2014, 04:07 PM
toad007's Avatar
Joined Dec 2004
Cox didnt make a td .061
I used the .049/.051
The Norvel .074 would fly it too slow in my opinion. you want a higher rev'er, like the REVLITE .061 AME if going with norvel
Old Oct 13, 2014, 06:32 PM
Hurts so good!
Joined May 2008
I'm pretty sure that's the choice I will make. Due to cost alone.
How do you tell the revlite ame from other Norvels? I ask because there a couple norvel .061 r/c engines on eBay right now
Old Oct 13, 2014, 06:56 PM
toad007's Avatar
Joined Dec 2004
the revlite has a black/ dark brown cyl and the fins have a larger dia than the older silver colored ones
the ame version is the higher rpm version. so you want the revlite ame .8 or 1.0 (.049/.061)
they come in rc version with a carb or the c/l version.
Here is a link to my site with a few pics and info on it
www.toadsrc.com/engines.htm
Old Oct 13, 2014, 08:51 PM
Western KY
Joined Sep 2003
You can easily separate the older versions from the newer models by color and fin diameter as noted above. A quick indicator is that the fins are notched for the cylinder hold down screws on the older AAN models; the Big Mig cylinders have no notches -- the screws pass through holes in the fins.
You cannot distinguish the Big Mig models from the AMEs on the R/C versions -- you must count the intake ports; 5 round ports for the Big Mig, 3 larger oblong ports for the AME.
On the C/L version, most Big Migs have the NV slanted back at about a 30 degree angle; AMEs have the NV mounted at 90 degrees to the crank.
Old Oct 14, 2014, 07:08 AM
Sweden
Do you have any other info about the plane, such as wing area, wing profile and thickness, and recommended total weight?
Here are some typical values for "sport-planes" where I have used these engines;
.049-.061; Around 27-28" wingspan, 160-180 square inch wing area, total weight around 10-15 oz.
.074; Around 36-38" wingspan, 230-250 square inch wing area, total weight around 19-22oz.
Old Oct 14, 2014, 08:05 AM
Hurts so good!
Joined May 2008
I will have more info when the model arrives
Question Engine size question , need answers please Turqui Engines 13 Aug 04, 2014 04:30 PM
Help! Need advice on repair, paint type, and engine size on a HK FW190 Composite 1790mm. James Viola Fuel Warbirds 26 Jul 15, 2014 08:27 AM
Help! Need 30-40 inch nitro plane with .25 size engine (can't find one anywhere, HELP!!!) SdpdCadet 3D / Fun Fly Fuel Planes 5 Jan 12, 2012 01:42 PM
Discussion Need Engine Size Help michael7810 Beginner Training Area (Fuel) 3 May 28, 2009 09:37 PM
Discussion Need help with Telemaster engine size raydleoni Fuel Plane Talk 2 Sep 29, 2007 10:01 AM
