Old Sep 27, 2014, 03:24 PM
Pete Blake
United Kingdom, Crawley
Joined Aug 2014
Frise ailerons
Hi Guys,
As I approach the half-way mark in my dragonfly build,I've come up against the problems posed by this type of ailerons. A search on Wiki whatsits name has given me some conflicting info in that they can be either hinged at the top or the bottom. So my question is , which way is "right" for us modellers ??....and has anyone actually done either way successfully ?
Would love to know how it was done, especially with regard to this particular plane
Rgds, Pete.
Pete Blake is offline Find More Posts by Pete Blake
Old Sep 27, 2014, 04:13 PM
wizard of odd's Avatar
Australia, WA, Kalgoorlie
Joined Apr 2011
The Frise aileron creates extra drag when the aileron goes up, otherwise it would create adverse yaw in the opposite direction to the aileron input.
Here are some diagrams of a Bristol Beaufighter, note the wing cross section in the second picture.
So for your model design, either top hinge, or offset hinge like in the first and third picture
wizard of odd is offline Find More Posts by wizard of odd
Old Sep 27, 2014, 06:25 PM
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
This is the way I did mine.
The red was for the linkages to the top aileron
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Sep 27, 2014, 08:32 PM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
The hinge can be in many different positions depending on the shape of the aileron as long as when deflected up the leading edge is exposed under the wing to great drag to pull the wing in that direction
turbonut is online now Find More Posts by turbonut
Old Sep 28, 2014, 02:50 AM
Joined Apr 2011
Pilatus porter offset hinge, similar to Les' example
Old Sep 28, 2014, 09:10 AM
LesUyeda's Avatar
Joined Dec 2004
I was not about to mess with the complexity of trying to make that inner surface concave:-))))))))))))
Les
Help! How to seal Frise ailerons ChrisS Balsa Builders 9 Oct 30, 2013 06:00 AM
Question ailerons not returning to neutral cmdl Electric Plane Talk 14 Sep 26, 2013 02:23 PM
Discussion Eagletree Y connector for ailerons? T_flyoo4 FPV Equipment 4 Sep 21, 2013 04:28 PM
Question Use full length ailerons as flaps? robodeath Electric Plane Talk 16 Sep 20, 2013 02:43 PM
Discussion frise ailerons/spoilers in foam? Truglodite Foamies (Scratchbuilt) 2 Jul 15, 2008 06:14 AM
