Old Aug 04, 2014, 11:42 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
I 'll gonna make also a prototype, which should be an exact aerodynamic copy, but only smaller and less heavy. The real thing will take half a year to finish, so need to make sure , although the wing planform is not shocking new.., but thats obvious not the project challenge.
vincent123 is offline Find More Posts by vincent123
Latest blog entry: FZ5: design phase
Old Aug 04, 2014, 03:22 PM
iron eagle's Avatar
United States, MA, Middleboro
Joined Jul 2007
What type of size are you thinking for the prototype compared to the actual airframe?
iron eagle is offline Find More Posts by iron eagle
Latest blog entry: The third time is a charm!
Old Aug 05, 2014, 01:11 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
I try to get the cubic wing loading the same for the prototype.
This determines the wing area, and the scale down factor.
The proto will a simple handtrow version, since weight is about 600 gram.
Old Aug 05, 2014, 04:20 PM
iron eagle's Avatar
Joined Jul 2007
That sounds pretty close to the same thing I hope to accomplish with my test model.
600 grams that's pretty lightweight, I take it your thinking of using something along the lines of a 35 mm df unit for it? That should give you a pretty good approximation of scale for power as well.
Old Aug 06, 2014, 11:59 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
Was thinking of using a normal prop.
I know the prop adds stability to yaw, so I ll compensate this with winglet sizing..
Old Aug 06, 2014, 02:45 PM
iron eagle's Avatar
Joined Jul 2007
If you use a prop size the motor so you have about half the power you will use for the DF unit, that will give you an idea of how the performance will be with the DF because they are not as efficient as a prop drive setup.
Old Aug 13, 2014, 02:30 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Wing bones.
Old Aug 16, 2014, 01:59 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Anyone any experience with these kind of hinges?
http://www.geniebuild.com/g2_instructions.html
Are they the only one selling these ?
Old Aug 16, 2014, 06:37 PM
I don't like your altitude
Stupot46's Avatar
Joined Sep 2011
http://www.hyperflight.co.uk/product...ks-rds-adaptor
http://mibomodeli.si/trgovina/index....oducts_id=6712
http://www.topmodel.fr/en/product-de...pmodel-ds6010-
The 1st & 3rd links are just the adapters needed for the servo output.
Stupot46 is offline Find More Posts by Stupot46
Old Aug 17, 2014, 03:26 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
Thanks for the links!
Never installed it, seems a bit of work to get it right.
Old Aug 23, 2014, 06:39 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
Wings connected to fuselage with carbon formers, 2-3mm thick.
Old Aug 25, 2014, 06:20 PM
iron eagle's Avatar
Joined Jul 2007
With the tail pipe shown in the first picture it looks like a rocket ship.
Old Aug 26, 2014, 11:50 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
Looking forward to building it
Old Aug 30, 2014, 05:10 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
Fuselage building tabs added to the model.
Idea is to put them in a building board.
Old Sep 07, 2014, 02:17 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
Still not building a prototype version, should better be doing that
Meanwhile figuring out what the thickness should be of the carbon former.
I tried to calculate the maximum G's the plane could pull with a 2.5mm thickness carbon former, which would be 6.4. Good enough ?
Discussion How well would this canardish jet perform? (just design phase right now) GreenAce92 Foamies (Scratchbuilt) 5 Jan 16, 2009 07:14 AM
More shots with the Depron Dragon and Panasonic DMC-FZ5 CactusJackSlade Aerial Photography 7 Jun 12, 2005 12:46 PM
Yippee! Depron Dragon w/Panasonic DMC-FZ5 - maiden photos CactusJackSlade Aerial Photography 11 Jun 11, 2005 09:37 PM
Depron Dragon's new Panasonic DMC-FZ5 camera set-up - maiden this evening?! CactusJackSlade Aerial Photography 1 Jun 11, 2005 12:30 AM
New A/P Plane - Initial Design Phase Buzz_Man Aerial Photography 4 Apr 21, 2005 12:33 AM
