Old Feb 07, 2013, 06:34 AM
RCLud's Avatar
United States, MI, Holly
Joined Feb 2013
Help!
~Exhaust Deflector~
Question; When I mount the "Exhaust Deflector" Is it a good idea to use a small steel hose clamp, Instead of the tie strap they send with the Exhaust Deflector? I'm thinking it may blow off with the tie strap.... I'm thinking the steel hose clamp will hold the deflector on better.... Your thought's please!!!!
RCLud is offline Find More Posts by RCLud
Old Feb 07, 2013, 06:49 AM
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
It's about 50/50 if one is better....
Having the muffler cleaned of any oil,and dried, before installing the deflector is a big help.
I've used both-and I prefer the steel clamp,myself.-It's very easy to snug it up , on occasion. Just for peace of mind.
epoxyearl is offline Find More Posts by epoxyearl
Old Feb 07, 2013, 07:08 AM
RCLud's Avatar
Joined Feb 2013
OK great thank's... Yes the muffler is new!!!
Old Feb 07, 2013, 07:27 AM
Joined Nov 2012
A small amt if high heat silicone can help stick it there too
Machzx is offline Find More Posts by Machzx
Old Feb 07, 2013, 08:32 AM
United States, MI, Waterford Charter Township
Joined Aug 2008
I've even used thin CA!
ahicks is offline Find More Posts by ahicks
Old Feb 07, 2013, 09:13 AM
surfer_kris's Avatar
Sweden
You can secure it with a thin wire too;
surfer_kris is online now Find More Posts by surfer_kris
Old Feb 07, 2013, 09:16 AM
United States, TX, Weatherford
Joined Dec 2006
If all of the above fail for you, drill a small hole all the way through the stinger and use safety wire that goes through the stinger and the deflector, wrap it around and using pliers twist it on tight. It will not come off.
Chip01 is offline Find More Posts by Chip01
Old Feb 07, 2013, 09:47 AM
DarZeelon's Avatar
Israel, Ramat HaSharon
Joined Nov 2003
Lud,
I suggest you forget the whole thing...
This exhaust deflector wasn't designed to work with your particular engine; and your engine was definitely not designed to run with it.
I still have an engine that the mere installation of this item on its muffler spigot, instantly shaved over 1,000 RPM off its top-end...
This item will not keep your plane clean. You will still need to spray-n-wipe it at the end of the day; maybe just a little less. So, it obviously does serve its intended purpose.
Just forget it; and it you didn't buy it yet, just leave it to rot on the LHS shelf...
As long as you run a glow engine, you'll just have to keep on wiping...
DarZeelon is online now Find More Posts by DarZeelon
Old Feb 07, 2013, 10:56 AM
Master re-kitter
SRQFlyer's Avatar
Sarasota, Florida
Joined Dec 2005
Exhaust deflector
Dar,
Doh, never mind - I thought the diesel in one picture was the OP's.
JIm
SRQFlyer is offline Find More Posts by SRQFlyer
Old Feb 07, 2013, 12:09 PM
The Prez....... again
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
I usually take my Dremel with a cut off wheel and CARFULLY cut a shallow groove around the exhaust outlet. I angle the wheel so I have a 90 degree corner closest to the outlet and it tapers to the muffler. The exhaust deflector material will deform into the groove making it difficult for it to come off. This groove is commonly called a hose barb. Google "hose barb" and you will get a good idea of what you need to do. I've found a singe groove is sufficient for our purposes. It does not need to be very deep. No need to use any sealant, just clean of oil.
Ken
kenh3497 is offline Find More Posts by kenh3497
Old Feb 07, 2013, 12:38 PM
DarZeelon's Avatar
Joined Nov 2003
Originally Posted by SRQFlyer View Post
Dar,
Doh, never mind - I thought the Diesel in one picture was the OP's.
Jim
Jim,
Model Diesels are not so adversely affected as glow engines are, as far as power is concerned...
But the model it is installed on will still be slimy at the end of a flying day... Maybe a bit less slimy, but gooey still.
And, what Diesel is that? It looked like an MVVS 2.5 at first glance, but then I saw it is not...
Old Feb 07, 2013, 05:28 PM
RCLud's Avatar
Joined Feb 2013
Ken
Thank's Ken.. I was thinking about doing this as well... cutting a small grove around the pipe. Then i would use a small steel hose clamp....
Old Feb 07, 2013, 05:31 PM
RCLud's Avatar
Joined Feb 2013
Thank you all for the great suggestion's.. Have a good evening..
slime, slime, slime.......Exhaust deflector? Wingbreaker Fuel Plane Talk 7 Feb 17, 2004 05:08 AM
