Closed Thread
Old Jul 11, 2012, 10:47 AM
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
loctite 648 for pinion gear?
Is this the only thing that works for holding the pinion gear to the motor shaft? Or has anybody found something else that works from other companies like Permatex.....I am asking cause last night I fired up my first motor and gearbox,and all was fine tell after half throttle,it just made a loud screech,and stopped pulling,so I figure the gear is spinning.Problem now is,I have searched for hours at all the stores (nobody carries the loctite 648) and Esprit Model is out of stock.I am wanting to get this X-Plane in the air this weekend,but would be hard with only having half throttle Any help would be much appreciated.
VooDoo Child is online now Find More Posts by VooDoo Child
Closed Thread
Discussion Gluing pinion on motor shaft with Loctite 638/648 polar bear High Performance 3 May 18, 2012 05:53 AM
Discussion loctite 638 / pinion gear carpetbomb High Performance 10 Oct 25, 2009 03:21 AM
Discussion Pinion gear/Loctite... what kind? DGrant Power Systems 14 Jun 27, 2006 08:08 PM
Getting a "MPjet gearbox" pinion gear off (glued with loctite) a motor shaft Masterpiece Power Systems 7 Jun 26, 2005 05:13 PM
Loosening loctite on pinion gear slunk Power Systems 4 Aug 05, 2004 11:04 AM
