Old Apr 17, 2012, 07:12 PM
KenCz's Avatar
USA, MI, Oxford
Joined Apr 2007
How to remove decals that come with H9 ARF
Hello,
I am hoping one of you Scale Guys know the secret to removing decals from the surface of an ARF??
In this case it is a Hangar 9 Giant Scale ARF and the previous owner had installed many decals that come come with the ARF - things like Brand of Radio used, Engine, etc.
I do not believe the ones I want to remove were factory installed -
I think they come in the ARF kit and the choice is up to the owner - I suspect this type comes with adhesive on the back and are NOT ?? water slide.
As always, your help is truly appreciated!
Ken
KenCz is offline Find More Posts by KenCz
Old Apr 18, 2012, 12:58 AM
TigreJohn
United States, CA, Corona
Joined Aug 2008
Your correct, they are probably not water slide decals, They are contact adhesive appliques. They can be removed, but it takes a practiced hand with a heat gun to soften the glue on these "decals" enough to get a knife tip under a corner to begin to peel it without melting the covering its stuck to.
If they are water slide decals, they are usually lacquer based and they can be dissolved with lacquer thinner, MEK, or acetone.
jjkupinski is offline Find More Posts by jjkupinski
Old Apr 18, 2012, 02:18 AM
Augernaut
Wookster's Avatar
United States, KS, Overland Park
Joined Jan 2010
I'm work at a print shop, here's my best advice.
1. soak it with rubbing alcohol, this should soften the adhesive enough to get a corner up on it.
2. try to peel the graphic up slowly. Heat can be your friend, but it can also cause the graphic to leave adhesive on the covering. A perfect 90 angle while pulling on the graphic usually leaves the least amount of adhesive, but you have to pull gently and be patient. A few extra minutes in this step can save hours in cleanup.
3. Apply adhesive remover. Anything that uses orange oil works great. Smells like you just snorted a line of tang, but it works.
4. hit the covering with a covering iron. in the process of pulling you may have pulled some covering off the wood.
Wookster is online now Find More Posts by Wookster
Old Apr 18, 2012, 08:50 PM
I'm a pilot... 100 yrs to late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
I have found adhesive always remains onthe covering... use goop or somethng similar to adhesive removal to get it off. I have picked up the corner with my exacto and started pulling back 180 degrees to remove the sticker.
Thermalin is offline Find More Posts by Thermalin
Old Apr 19, 2012, 03:58 PM
KenCz's Avatar
USA, MI, Oxford
Joined Apr 2007
Thanks to all for the great tips and ideas! Now I start and hope for the best!
Old Apr 20, 2012, 05:53 AM
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
I agree-pulling the decal back over itself as closely as possible avoids the 'lift' of the covering,and that 180 deg. reverse turn seems to help "roll" the adhesive back......but man,do it sloooowwwwly.
epoxyearl is offline Find More Posts by epoxyearl
Old Apr 20, 2012, 11:48 AM
Augernaut
Wookster's Avatar
Joined Jan 2010
takes time. Especially on the side of a McDonalds playplace.
Old Apr 20, 2012, 02:46 PM
epoxyearl's Avatar
Joined Oct 2011
Sounds like the Wookster KNOWS! lol
Old Apr 21, 2012, 07:15 PM
Big Nuts 181's Avatar
Joined Jul 2004
soaking with MEK works a treat too!
Big Nuts 181 is offline Find More Posts by Big Nuts 181
Old Apr 24, 2012, 12:35 AM
Oberst's Avatar
Lacona, NY
Joined Dec 2009
I usually use a hair dryer because I don't have to worry too much about screwing up the Ultracote that Hanger 9 planes use for their covering. Once I get the old stickers warmed up I get a edge of the sticker worked up with my finger nail, then try to grab it with 2 fingers on the same hand and pull or peel the sticker off.
If you have some glue residue left behind by the sticker, use a little Zippo or Ronsonol Lighter Fluid on a old clean rag and wipe the excess off. If you don't have lighter fluid, put a little acetone on the rag and it will work just as good.
Pete
Oberst is offline Find More Posts by Oberst
Old Apr 26, 2012, 03:52 AM
Joined Mar 2012
No foto available
joyanan is offline Find More Posts by joyanan
Reply With Quote  (Disabled)
Help! How do you remove decals from foam? RC_Crazy23 Foamies (Kits) 6 Sep 23, 2013 03:59 PM
Question Question about AR500 rx that comes with PZ Corsair (Corsair now comes with the AR600) njsnel Radios 15 Mar 12, 2012 06:11 AM
Discussion How good is the radio that comes with mSR RTF? miniCAP Micro Helis 3 Jan 07, 2012 01:31 PM
Discussion Will a DX6i work with Walkera heli's that already come with a transmitter? Grifftech Electric Heli Talk 2 Nov 18, 2011 03:07 PM
Discussion How much expo is built into Tx that come with RTF? rwek Power Systems 2 Mar 12, 2011 08:20 PM
