Old Nov 30, 2014, 10:38 AM
Italy, Tuscany, Grosseto
Joined Feb 2007
Build Log
New from TaftHobby: Valkyrie Jet 90mm
Hello friends!
These is the new jet (scrupulously in EPO) arrived from TaftHobby for the test. Is a new "Valkyriae Jet: original design for a jet with wingspan 1287mm and length of 1439mm; wing area 26.4 Dm2. 90mm Edf with 11 blades "TaftHobby", motor BL3541 KV1450; Esc 80amp Hobbywing and 8amp UBEC; 8 mini servos installed (digital metal gears); electric retract with metal legs. Batteries required minimum 5000mag 6S 30C. Weight in flight 3.2 kg and 6-channel radio request.
The model comes ready to fly and requires no glue but only by fixing screws. In these website my assembler and review thread.
sandrocacciola is offline Find More Posts by sandrocacciola
Old Dec 01, 2014, 08:45 AM
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
Nice. Please supply the URL or link.
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Dec 01, 2014, 09:02 AM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
http://www.rcgroups.com/forums/showthread.php?t=2294411
post #1
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Dec 01, 2014, 01:08 PM
Joined Feb 2007
The model is very easy and faster to assembler. The servo and retract cable is already passed with multy plug (servo for aileron and flap end retract). It's impossible any error...
Old Dec 01, 2014, 01:11 PM
Joined Feb 2007
For try these new jet I did not change anything because I believe that nothing should be changed.
Old Dec 05, 2014, 09:04 AM
Joined Feb 2007
Another immages: the model is very PNP and Taft Hobby, as in the other models, has assembled everything. The EPO finishing is good and there are non imperfections. The color is compact.
Old Dec 12, 2014, 05:30 PM
Joined Feb 2007
Finally the test in fly for Valkyrie jet. Very very good! The model is perfect and flight very well. Take-off is short and the edf have good power. In flight the jet is fast and slow, with flap landig is easy. These new jet is a surprise for me becouse I don't know. In these two movie you can see the quality of these model!
Secondo volo Valkyrie jet TaftHobby (4 min 41 sec)
Ecco cosa si può fare con il nuovo Valkyrie Jet TaftHobby (4 min 18 sec)
Old Dec 12, 2014, 11:30 PM
Kicking Tires
Joined Jan 2014
Slow flight looks nice and stable. Low passes look great! How many mAh did you charge back into your battery after the second video's flight?
Alpha.MotionRC is offline Find More Posts by Alpha.MotionRC
Old Dec 13, 2014, 12:34 AM
Joined Oct 2009
Nice job, i think the slightly frumpy look was required to provide it with the tracking and handling which are both first rate.
Also seems even easier and more docile to fly than the Viper, will make a great edf trainer and also a nice, large relaxing jet to fly for current edf pilots..
nighthawk0077 is online now Find More Posts by nighthawk0077
Old Dec 13, 2014, 11:56 AM
Joined Feb 2007
I charge 3500Mah after second fly.
Old Dec 13, 2014, 11:59 AM
Joined Feb 2007
Yes, it's true. The model is very easy to fly, moore stable and with good power. The Edf set include in the kit it's a good choise. I'm waithing also the new "Quantum Jet" from Taft-Hobby" for tested.
Old Dec 16, 2014, 03:07 PM
Joined Feb 2007
The announcements of TaftHobby are three: the Valkyrie Jet, the "Quantum Jet" and the ''E-Jet Scorpion ". What is the subject of my test is the Valkyrie, aircraft singular conformation of the tailplane positioned on the vertical, but for its lines (and flying characteristics) is very similar to the Viper. The Valkyrie has a wingspan of 1287mm and a length of 1439mm with a wing area of 26.4 Dm2. Mounts a 90mm fan with 11 blades production TaftHobby with an engine from BL3541 1450KV; The model features a 80-amp regulator Hobbywing. and a UBEC from 8Amp. The servos installed are mini digital with metal gears; complete the equipment of the Valkyrie electric retract (already seen the Viper) with metal legs. Batteries required minimum 6S lipo 5000mah and 30C discharge. The weight which showed the model in flight order was 3,240 kg. To fly the Valkyrie requires a radio with only 6 channels.
The model comes in a pack well made and impact test in which are located the fuselage in one piece, the two wing panels, vertical rudder and tailplane. The kit is supplied bayonet carbon wing and a set of screws required for assembly (not absolutely need it the glue).
Old Dec 16, 2014, 03:14 PM
Joined Feb 2007
The assembly of the model is semple and fast: it's sufficient connect the spinet servo rudder vertical and screw it to the fuselage with the four screws, then connect lead and block the tailplane to the vertical with two screws (provided). The wings fit into the fuselage of plastic seats and are locked with two screws each. That's it. The pins of the channels follow have number of the function but I have verified that these number are different ad that I use in my channel's Rx: but never mind, just try every spinet with a servo tester and understand what command corresponds to the model (direction, retract, rudder etc.) and then subsequently connect to the receiver according to the arrangement of the channels that you prefer. Even simple connection to the Rx of wing panels that are equipped with a multi-plug that allows you to connect the controls of ailerons, flaps and retract a single plug that passing in a hole on the rib of the wings comes to the base e fuselage (see photo). Nothing complicated and all the work is finished in twenty minutes at the most.
The electric retract are of standard quality and slightly depreciated with those who have the wing compartment cover fixed to the leg and the nose gear have a door controlled by sequencer included and installed in the kit. The kit also includes winglet that if love can be fixed on the wings in a compartment that Taft sealed with transparent tape if you do not want to install (I have not done, and this is not in any way affect the flight) . To do so is sufficient to drill a small cut in the center of the compartment on the transparent PVC closing and insert the winglets provided. That's it.
The powertrain of the Taft-Hobby 90mm (which is accessed for any need from the lower part of the fuselage after unscrewing the cover), is dimensioned both with regard to fuel consumption and performance. My flights have shown that the average consumption of this fan is around 70amp managing to fly with battery 5000Mah about 5 minutes with sufficient remaining power. It 'still recommended in the first flights of ad hoc measurements after 3 or 4 minutes to understand the performance of the batteries that are used and behave accordingly.
Old Dec 17, 2014, 05:24 PM
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Try taking off on grass with that level of power, that's what a lot of people want to see, taking off sealed runway is easy.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Dec 17, 2014, 05:30 PM
United Kingdom, England, Southampton
Joined Oct 2013
Shame its a foamie. They always fall to bits after a while, being make out of what is basically throw away packing material. One of my EDFs is still going fine after 15 years, though it started with a 90 glow OS VRDF
Mark Powell is offline Find More Posts by Mark Powell
Reply With Quote  (Disabled)
New Product Taft-Hobby Valkyrie 90mm 420flyboy Foamy EDFs 31 Jan 18, 2015 05:27 PM
Discussion HK coming soon new fiberglass sport jet 90mm Tim Wan Electric Ducted Fan Jet Talk 99 Nov 16, 2014 12:13 AM
Wanted HobbyKing™ Diablo 90mm Jet 1250mm OR ViperJet Composite 90mm EDF Jet 1370mm x5heli Aircraft - Electric - Jets (FS/W) 0 Sep 04, 2014 04:20 PM
Sold Servos pulled out from nitroplans 90mm F18 jet nerv Aircraft - General - Radio Equipment (FS/W) 1 Nov 27, 2013 04:44 PM
Sold New Jet Teng JTM 90mm Viper Jet w/TJ90 & Tamjet Retracts Alkaline Aircraft - Electric - Jets (FS/W) 4 Oct 23, 2013 02:44 PM
