Old Oct 22, 2014, 11:46 AM
JetMang's Avatar
San Diego, California, United States
Joined Feb 2002
Build Log
Frankel F4D Skyray Build Thread
Well, I've been debating about posting a thread on this for some time (they can be a lot of work, haha!) and after talking with P.Richards this past weekend at BITW, he inspired me to just go for it.
A while back, I was fortunate enough to acquire a Mark Frankel Skyray kit from the man himself. The design is an exact 1/7 scale which puts the fuselage length at 77.6" and the wingspan at 57.4". Those numbers don't do it justice because it builds into a really large airplane with tons of wing area! The fuse width and volume is huge (you get an idea from the pics). This kit was first designed around glow ducted fan back in the day and flew excellent with that power. According to Mark, he designed it as large as he could while still getting a great flying airplane given the available glow power systems. I've seen video of them flying as low as 16-18 lb up to 24ish lb on glow DF and they flew great, even at 24 lb (TO roll was a bit long, but once on step flew really nicely and didn't appear to fly heavy). With turbine power, the weight and speed increased more and still remained an awesome flying machine! I can only imagine it will continue with EDF power!
My intention is to build a competition scale bird of the same magnitude or greater than the mirage. With the larger size, I can carry the capacity I need which should allow me to get the flight time I need without worrying too heavily about hurting the packs. This is one of the difficulties I've had in competition with the mirage. Plus, seeing the performance of my 20lb NTech jets Panther, the performance should be awesome. My goal is to get the airplane in at 24 lb or less. That may be tough as I plan to build in speed brakes, working tail bumper, tail hook, slats and lights (including AB lights of course!), but I think it can be done (I've been trying to make every gram count!).
So, here we go with the build thread of this cool kit of an awesome delta winged airplane (can anyone tell I love deltas!? ). Those that know me know that I can build sloooooooowww, so bare with me. haha! Building has been underway for a few months, so maybe I can stay far enough ahead that the thread won't bog down too much.
First up are some pics of the kit and the nose gear which I had made by Ed at RCCRafters (the gear is SICK!).
Chris
JetMang is online now Find More Posts by JetMang
Old Oct 22, 2014, 12:36 PM
A10pilot's Avatar
United States, TX, Schertz
Joined Mar 2006
Chris:
I have no doubt it will be an exceptional model when you finish it. Looking forward to the build.
Ed
A10pilot is offline Find More Posts by A10pilot
Old Oct 22, 2014, 01:35 PM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
Now that will be cool. The nose gear looks like you just unbolted it from a full size. Will you use the body flaps also?
turbonut is online now Find More Posts by turbonut
Old Oct 22, 2014, 02:52 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Awesome....I hope this lights a fire to get going on the JHH version....as soon as I get my arm out of a sling from the surgery I had last week.Chris I have you dads research info if you need it.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Oct 22, 2014, 03:06 PM
jefffassbinder's Avatar
United States, CA, Chino Hills
Joined Jan 2011
Very Nice
Chris,
That is a fine looking kit. I wish there were more to be had. But glad at least there are plans out there for the scratch builder.
The nose gear looks very impressive.
I'll subscribe!
jefffassbinder is offline Find More Posts by jefffassbinder
Latest blog entry: Ducting getting wrapped
Old Oct 22, 2014, 05:08 PM
JetMang's Avatar
Joined Feb 2002
Thanks guys! BTW, a must for the build was Mark's book "Killer Rays." It's an enjoyable read and has a lot of nice photos and color profiles in it. Highly recommended if your a fan of the Skyray.
Well, Let the building begin...
I like to start off small usually, so started in with the dorsal (wings require sheeting after fuse bulkheads are installed). First item of business was sheeting. Mark's design incorporates a sub leading edge before sheeting, so that was installed first, then the sheeting done. AFter that, add the trailing edge stock and the tip block and sand to shape...
On my trailing edges, I like to laminate a 1/64" ply strip between two pieces of balsa wood. This helps to create a fine, yet sturdy trailing edge. I did the same on the tip block, but added some ribs also to get a little space between the blocks.
Chris
Old Oct 22, 2014, 06:22 PM
Clear Skies & Contrails
xplaneguy's Avatar
Edwards AFB, CA
Joined May 2009
Chris-Glad to see the build is underway. Mark mentioned that he'd be sending you a Skyray kit earlier this year, while I was assisting him with photo and document gathering for his next book, here at Edwards.
This will be awesome Skyray and I'll be following your exceptional work!
All the best,
Tony
xplaneguy is online now Find More Posts by xplaneguy
Latest blog entry: FMS 980mm Kawasaki Ki-61 Tony
Old Oct 23, 2014, 09:13 AM
Tempest's Avatar
Gaithersburg MD, United States
Joined Nov 2000
I'm definitely signed on Chris. I absolutely love the Skyray and look forward to seeing you work your magic!
Paul
Tempest is online now Find More Posts by Tempest
Old Oct 23, 2014, 10:05 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Where can we get that book?
Old Oct 23, 2014, 10:56 AM
Tempest's Avatar
Joined Nov 2000
Amazon appears to have it in stock. I have the book as well, and it is definitely a great resource.
Paul
Old Oct 23, 2014, 10:57 AM
A10pilot's Avatar
Joined Mar 2006
Roger, here it is.
http://www.amazon.com/s/ref=nb_sb_no...Mark%20Frankel
Ed
Old Oct 23, 2014, 11:40 AM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
Hi Chris,
I have that book and never made the connection to the kit...
Old Oct 23, 2014, 03:43 PM
world's slowest builder
Air-Jon's Avatar
CA
Joined Oct 2006
You were not kidding Chris...this is BIG Ray! I saw the nose gear in person and was blown away by the detail. I can't wait to see the rest of the build...
Air-Jon is offline Find More Posts by Air-Jon
Old Oct 23, 2014, 03:47 PM
Air-Jon's Avatar
CA
Joined Oct 2006
Mass Ford launch...impressive!
F4D Skyray fighter (0 min 17 sec)
Old Oct 23, 2014, 03:55 PM
JetMang's Avatar
Joined Feb 2002
Thanks again guys! Yeah, Mark Frankel the author = Mark Frankel the model airplane designer. He has a new book in the works about the various trainer aircraft the military uses. Also, before the Skyray book, he authored a book about the TT-1 Pinto, but I haven't picked that one up. He's pondered the thought of designing a large TT-1 which would make for a great flying airplane.
Hey Jon, Cool vid! I haven't seen that one before.
This one I like to back to from time to time. Closest I'll get to knowing how to fly the real thing, haha!
Aircraft Familiarization - The F4D-1 Skyray - Operating Procedures (1956) (18 min 32 sec)
Chris
Discussion F4D Skyray Scratch Build jefffassbinder Scratchbuilt EDFs 27 Dec 23, 2014 09:12 PM
Build Log Skyray (F4D-1) Build from Jet Hangar Hobbies jefffassbinder Electric Ducted Fan Jet Talk 272 Oct 19, 2014 04:15 AM
Discussion "FORD" F4D skyray build thread... corsair nut Pusher Prop Jet Models 1950 Nov 22, 2011 05:51 AM
Discussion Official F4d Skyray By 6mm Fly Rc Build Thread corsair nut Pusher Prop Jet Models 944 Aug 12, 2010 01:20 PM
JHH Skyray (F4D-1) Build Thread JetMang Electric Ducted Fan Jet Talk 270 Oct 15, 2007 01:10 PM
