Old Dec 06, 2012, 05:24 PM
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Help ID this chip from Hyperion Charger
Can anyone help ID this IC?
I have a FB that was using his Hyperion EOS0615i Duo3 charger and unplugged the battery adapter board from the charger and not the battery from the adapter board.
In doing this one of the 4mm bullets touched the 24V power supply and smoke came out of the charger and the screen went blank. The power supply does NOT have the high side AC ground isolated internally, it is via cardboard... No, this is NOT the way I would do this...
I opened the charger up to find a burned IC on the bottom of the charger. The ID says ST and what appears to be ?8949.
I looked at this under a lab scope and cound not figure out the first letter but the next 4 is either B949 or 8949.
Maybe the # that I need is the top # ?
I ordered some FD8949CT-ND http://www.digikey.com/product-detai...9CT-ND/1217904 from Digi-Key and when I went to remove the orginal from the PCB today I found the underside soldered to the PCB also. The replacement I ordered does not have this.
I have two pictures attached. Don't worry about the uglyness of the PCB after removal, I can fix this "whenever" but will not exert any time/energy into this until I have the correct IC in hand.
Rick
rampman is online now Find More Posts by rampman
Old Dec 07, 2012, 05:27 AM
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
My guess is that it's an L5973D.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Dec 07, 2012, 10:27 AM
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Bruce, thank you. I think that is it and ordered one up.
Rick
Discussion How about this Mosfet Driver chip.... Please help me identify this one gta18 DIY Electronics 12 Aug 05, 2012 05:46 PM
Help! Help ID this old Hurricane? Or P40? kauaicuda Fuel Warbirds 4 Mar 29, 2012 02:24 PM
Discussion Help, can some one ID this fan unit ? V55EVO Electric Plane Talk 2 Mar 26, 2012 09:19 PM
Question Can someone please help ID this Evo engine? madbomber Engines 3 Mar 25, 2012 10:51 AM
