Old May 01, 2006, 08:40 PM
SSG Scott is offline
Find More Posts by SSG Scott
SSG Scott's Avatar
Rapid City, SD
Joined Jan 2006
Originally Posted by Fighting Gravity
Excellent how-to manual.
Thanks alot SSG.
Now I have to try to beat your 17 seconds. You set the bar high but it's something to shoot for. (heck, I'd be thrilled with 10 seconds)
Scott
Well it seemed like it was at least a minute or two at the time but the stop watch only said 17 seconds. When you get it all balanced out - its an amazing little helicoptor!
SSG Scott is offline Find More Posts by SSG Scott
Old May 04, 2006, 08:26 PM
rocknbil is offline
Find More Posts by rocknbil
Just call me crash.
Joined Jan 2006
Well I went though all the stuff in Scott's PDF and the difference is indeed amazing. Being a newbie, all I want is to actually **see** this mythical 2 second hover - unfortunately I still haven't. But I'm getting close . . .
My problem is mostly the newbie pendulum effect, back and forth, to and fro, never stationary. I completely broke down the BCP, worked everything in the head over for smoothness and loose action, balanced until I'm blind, but the first flight today I still had a bad pendulum. It turns out one of my bell-hiller pivots was a little tight, took it in and shaved it a little so it's loosey-goosey, and that in itself was a tenfold improvement.
So in addition to balancing, I learned all the parts must be loose and one side shouldn't have more drag than the other, anywhere.
But it still yo-yo's and still wants to wander, I can keep it in a 3-foot circle and rotate 90 degrees to either side doing so but man it's a lot of work. Can't be a sticky collective because it's a bell-hiller, but **something** must be sticking. Maybe it's my brain.
Here's some pics of my balancer per Scott's instructions, thanks man this is the first big move toward actually flying since I started.
rocknbil is offline Find More Posts by rocknbil
Old May 04, 2006, 09:53 PM
chinlin0924 is offline
Find More Posts by chinlin0924
R.O.C
chinlin0924's Avatar
Taiwan, Republic Of Chopper/Computer/Coaxial/China (R.O.C)
Joined Dec 2005
hi SSG Scott ,
really nice howto!! that is so important to balace and trim the heli.
thank for your contribution!!!
chinlin0924 is offline Find More Posts by chinlin0924
Old May 04, 2006, 10:00 PM
Al P is offline
Find More Posts by Al P
small electrics r BIG FUN
Iowa
Joined Aug 2000
Nice photos rocknbil
Sounds like you're doing quite well. You're right, the balancing really makes a difference.
Al P is offline Find More Posts by Al P
Old May 06, 2006, 11:27 PM
SSG Scott's Avatar
Rapid City, SD
Joined Jan 2006
Wow that sure is a snazzy balancer! You could probably sell those things! Nice Job and well done!
-Scott
Old May 07, 2006, 01:44 AM
shim is offline
Find More Posts by shim
Brunei Darussalam
Joined Mar 2003
Scott,
Is the procedure the same for FP micro heli?
I tried attaching my FP main shaft minus the main blade to the drill and powered it up. The paddle wobbled around a lot.
-shim
shim is offline Find More Posts by shim
Old May 07, 2006, 09:14 PM
SSG Scott's Avatar
Rapid City, SD
Joined Jan 2006
Originally Posted by shim
Scott,
-shim
Yes the proceedure is pretty much all the same. I hven't looked at a FP head in a month or two. Are the pitch links attached to the swash plate? I will have to try to get a look at a head up close to see if I can figure out what might be happening .
-Scott
Old May 08, 2006, 06:36 AM
67flyer is offline
Find More Posts by 67flyer
Joined Apr 2006
I followed the pdf and I still have a little wobble at low rpms but it smooths out at faster rpms. During the procedure I was playing with the pitch links and discovered that if i made the right swashplate link shorter,(the one by the back side of the front servo) it would rub against the front servo. The threads on the link would rub against the screw on the servo cover. Got it adjusted so that it don't rub anymore. I discovered it while i was trying to lower the whole swashplate on the shaft. I was trying this because it don't seem like I have a lot of blade movement when I throttle up.
So any way I got everything balanced and then fired up the bird and at half throttle it lept off the ground straight up, I wasn't expecting it and killed the throttle and it landed with no issues. (it has never left the ground at half throttle before, The balancing helped quite a bit) So I check the blade tracking next and see I need to track it. so I make the adjustments and then power up again and this time it don't come off the ground at half throttle. I need to have it around 75% throttle before it gets lite on the skids and starts to drift left. I don't have a pitch gauge yet, but it would seem that I need to add somemore positive pitch in. Is that correct?
67flyer is offline Find More Posts by 67flyer
Old May 08, 2006, 12:10 PM
SSG Scott's Avatar
Rapid City, SD
Joined Jan 2006
Yes- you are certainly on the right track! Just give both pitch change links a 1 turn adjustment so that it will start coming up into a hover when the throttle is half way up. Thats the easy way to do it with out a pitch guage. The wanting to slide left until the heli is off the ground is normal and is part of the physics of of these little helis (Gryoscopic procession). As soon as your heli rises above the ground, recenter your cyclic controls to maintain the hover in place.
The low speed vibrations are normal as the frame and bearings, landing gear all come in to play at very low rotor RPMs. For those of you who just love math- its all explained by something called differential equations and fourier analysis... Sorry the geek in me sometimes leaks out....
-Scott
Old May 09, 2006, 04:35 PM
Letcraft is offline
Find More Posts by Letcraft
Letcraft's Avatar
Mapleton, Iowa
Joined Feb 2006
I just recently went dual motor on tail of BCP. I used the slick looking blue anodized tail housing and it works beautifully except now I am trying to figure how to get the heli balanced again. With a 1300 lipo as far forward as possible in forward canopy it just barely balances level. When I go to my 900 lipos as far forward as posible it is quite tail heavy. Anybody had this problem and have any suggestions short of leading the nose? thanks!
Letcraft is offline Find More Posts by Letcraft
Old May 09, 2006, 04:51 PM
ThePheonix is offline
Find More Posts by ThePheonix
Chelmsford England
Joined Apr 2002
How about ...
Shorten the tail?
Paul
ThePheonix is offline Find More Posts by ThePheonix
Old May 09, 2006, 05:19 PM
Letcraft is offline
Letcraft's Avatar
Mapleton, Iowa
Joined Feb 2006
Originally Posted by ThePheonix
Shorten the tail?
Paul
Seriously?
Old May 09, 2006, 05:29 PM
P-40 is offline
Find More Posts by P-40
Love them P-40's!
P-40's Avatar
USA, MO, Kansas City
Joined Feb 2004
Well done. Thanks.
P-40 is offline Find More Posts by P-40
Old May 09, 2006, 05:54 PM
SSG Scott's Avatar
Rapid City, SD
Joined Jan 2006
Shorten the tail?
Paul
You can shorten the tail boom, or add more weight to the nose
Or you can try what I did- I used part of a popsicle stick and exended it forward on the battery tray so I could mount the battery way forward (on the outer end of the popsicle stick)in the very nose of the canopy. Do I need pictures to explain this better?
-Scott
Old May 10, 2006, 12:17 AM
Mini-Dub is offline
Find More Posts by Mini-Dub
Mini-Dub's Avatar
Seattle, WA
Joined May 2006
On the super landing gear from heli direct the carbon battery mounting rods are long enough to hang the battery way far forward. I cut the origional battery mount off the stock carbon rods and then slid it on the super landing gear carbon rods infront of the first frame/landing gear interface piece. Make sense ?
Anyways, I had to do that just to get the heli to balance out evenly front to rear, but then the body wouldn't fit over on the CP2 canopy so I ended up cutting out slots on either side of the front of the canopy so the battery corners can stick out. It doesn't look too bad and will probably give a little better cooling to the battery. Has anyone else encountered this problem?
BTW Scott your method for balancing the heli is great, I can't say I've really flown my new cp2 much at all in the air (working on "radds school for rotary flight" right now). But the things is dead smooth while spooling up and doesn't vibrate hardly at all even at the slowest rpms.
I didn't crash once today but I managed to bend my main shaft twice . Apparently you cant pick the heli up by the rotor head too quick or put any sideways pressure on the heli (such as swinging it a little bit while walking) because the main shaft will bend. It took me 2 times to realize why this happened haha. I have to say my preferred method for straightening the main shaft is to completly remove the shaft and use a rubber mallet on glass to pound it straight. The mallet wont damage the bar because its too soft, and the glass is super flat resulting in a very true main shaft. Bending it back as you suggested works just as well for getting it straight but it was much harder for met to do, I liked the cave man method much better .
Mini-Dub is offline Find More Posts by Mini-Dub
How well do your micro heli's fly in the wind? Johnny B Micro Helis 21 Nov 20, 2005 08:10 PM
How much does your micro heli weigh? zman12000 Micro Helis 8 Jan 15, 2005 10:20 AM
WTT: Your Micro Heli for my RC Car Stuff Kiiski Aircraft - Electric - Helis (FS/W) 0 Sep 25, 2004 09:38 PM
FS: Apache Canopy for your Micro-Heli AirMicro Aircraft - Electric - Helis (FS/W) 0 Jun 21, 2004 09:29 AM
Free decals for your Micro-Heli – Get here… born2net Electric Heli Talk 9 Mar 25, 2002 12:46 PM
