Old Aug 26, 2015, 07:18 PM
Robishere is offline
Find More Posts by Robishere
Joined Aug 2015
Help!
Transmitter, which one
Looking for a transmitter under $100 that will enable me to controll 6 channel helicopters. At the same time have channel mixing to control delta wings.
Been looking at the dx6i. Anyone know if this will do the correct channel mixing for the eleven?
Thanks.
Robishere is offline Find More Posts by Robishere
Old Aug 26, 2015, 09:34 PM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
Thanks.
Look for a helo radio that has a custom mixing capability of at least two functions. I don't know if that's available on a radio priced at less than one hundred dollars. One option on a Delta planform, not a Chevron, is to use a four servo wing with separate aileron and elevator control surfaces. That does add weight and cost, but would work with a standard helo radio.
DT56 is offline Find More Posts by DT56
Old Aug 26, 2015, 09:53 PM
Joined Aug 2015
I have seen that you can buy a y connector that will mix the channels after the reciever and before the servos.
Old Aug 27, 2015, 06:32 AM
Tim The Pines is offline
Find More Posts by Tim The Pines
United Kingdom, England, Ingleton
Joined Aug 2012
If you want cheap an Orange radio from HobbyKing will do the job,
I am a fan of Tactic radios, a bit dearer but better quality.
Both will do the mixing you require
Tim
Tim The Pines is offline Find More Posts by Tim The Pines
Old Aug 30, 2015, 08:46 AM
dankar04 is offline
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
There are tons of good used DX6i's. Many went to new DX6. It has what you need. H/K or copy of DX6i also but will cost almost the same. clone or real deal up to you. Spend a few bucks and get new DX6i and worry free.
dankar04 is offline Find More Posts by dankar04
Old Sep 01, 2015, 02:39 PM
Charlie P (NY) is offline
Find More Posts by Charlie P (NY)
Gravity is weak but persistant
Charlie P (NY)'s Avatar
United States, NY, Port Crane
Joined Aug 2009
I have a DX6i and like it for my needs, mine has been rode hard and put away wet and I've repaired a broken roller and switch (handling abuse) but I've gotta say my Tactic TTX850 is really impressing me.
It took me less than five minutes to set up my Sonic 64 wing, including dual rates and exponential. It's $180 bucks, a jump from your budget, but is a great Tx at that price. And the six and eight channel dual-antenna receivers are $25 and $40 (vs. $40 & $90 for Spektrum).
Charlie P (NY) is offline Find More Posts by Charlie P (NY)
Question new to multirotos -> which one and which stuff? Seppl Scratchbuilt Multirotors 2 May 05, 2015 03:08 AM
Question new to multirotos -> which one and which stuff? Seppl 3D Printing 1 May 04, 2015 11:05 AM
Discussion Antenna for my RC transmitter. Which one? holaktal3 FPV Equipment 5 Aug 01, 2013 04:51 AM
Discussion Problem w/ Receiver or Transmitter ...which one? mrrg Radios 3 Feb 22, 2007 04:26 PM
Discussion which one which one which one Shayan Coaxial Helicopters 48 Jan 26, 2006 11:33 PM
