Old Aug 11, 2015, 08:22 PM
Charlescd is online now
Find More Posts by Charlescd
Quebec Aerotow Association
Charlescd's Avatar
Canada, QC, st-jean-sur-richelieu
Joined May 2010
Build Log
Hacker Free with optional Evo Backpack Harness
Hi guys,
I started my RC-Free today and also ordered the Evo Harness in order to install bigger batteries and more weight.
Not much text as it's straight forward. It will be a picture build
All of this is available from Hacker USA.
Here are the goods laid out on the table:
Charlescd is online now Find More Posts by Charlescd
Old Aug 11, 2015, 08:24 PM
Charlescd's Avatar
Joined May 2010
I basically followed the manual and exchanged the regular harness for the Evo harness and the regular metal seat for the Evo metal seat.
Old Aug 11, 2015, 08:25 PM
Charlescd's Avatar
Joined May 2010
to be continued.....
Old Aug 14, 2015, 05:50 PM
Charlescd's Avatar
Joined May 2010
A little bit more done today.
The ESC is fun to install in this harness. It's also on the outside so this gives more room inside to work.
The servos are tested and programmed, wires tucked away and the receiver is installed with the antenna running on the outside.
I tested the harness and I can fit a 3s 5000 mah battery. It's a 155mm long battery
Old Aug 18, 2015, 08:44 PM
Charlescd's Avatar
Joined May 2010
I ordered the correct servo horns in order to install the arm kit. The arm kit goes on very easily.
Then it was the motor and prop and a foam pad at the bottom of the rucksack in order to protect the lipo in case of a hard landing.
The brake lines require a length of 28cm starting from the D-ring so I made a quick measuring tool that you can carry around at the field. It's a simple fishing swivel with a rope that is marked at 28cm. Dead easy to measure every time.
Old Aug 18, 2015, 08:50 PM
Charlescd's Avatar
Joined May 2010
The first flight went very well. It was in 10kmh winds and I had the free at 1.6kg. All I can say is wow !!! What great flight characteristics. The first minute was really bizarre as I never flew a single skin wing before. It's slower than a double skin but reacts more to the wind.
Note to self -- add expo on the radio. (forgot to program it)
Take off (approx 4 minutes into the video )- I could of pushed the motor just a bit more. I was close to the ground. I got up to about 10 feet and tested the left, right , brake, etc.. Everything was dead on thanks to very detailed setup instructions.
At 5 minutes in the video ( we were flying in formation).
I'm used to flying a dual skin -- so excuse the botched landing I was too high at first and then tried to go around -- downwind and missed my brake cue My Stunt 3 with my Trike comes down a lot faster. The Free just floats.
More videos and pictures to come.
We flew the Opale Hybrid, Oxy 1 and the Hacker RC-Free.
RC PARAGLIDER HYBRID 1.8, OXY 1.0, FREE (9 min 26 sec)
Sold DJI Phantom 2, H3-3D, iOSD, FPV setup, Backpack case, optional Black Pearl harrisy Aircraft - Electric - Multirotor (FS/W) 1 Jun 28, 2015 12:07 PM
For Sale Double Y Harness with MPX Connector (Get One Free) FieldofDreamsFlyer Aircraft - General - Radio Equipment (FS/W) 0 Jun 09, 2015 09:47 AM
Sold Evo 46 Alpha nice! with free shipping! flyncrazy Aircraft - Fuel - Engines and Accessories (FS/W) 2 May 20, 2015 09:06 PM
Sold Hacker A20-6 XL 10-Pole EVO +4,4:1 Jaguar22 Aircraft - Sailplanes (FS/W) 2 Apr 29, 2015 08:20 AM
Royal Evo 9 Scanner with Channel Check optional module Grimtooth Hitec/Multiplex USA 3 Jun 18, 2004 06:02 AM
