Old Jul 05, 2015, 07:24 PM
Gerry Santos is offline
Find More Posts by Gerry Santos
Manila, Philippines
Joined Jul 2001
Adding external BEC?
I just completed my gws cargotrans and modified using four 10g brushless motors and four turnigy plush 10amp escs from hk:
http://www.hobbyking.com/hobbyking/s...nner_10g_.html
http://www.hobbyking.com/hobbyking/s...ontroller.html
Completing the set up includes 4 9g servos and 2 5g servos and a 2s 1300 mah pack. Control is provided by a 8 channel Frsky rx.
With this set up, do I need to add an external bec?
Appreciate your response.
Gerry Santos is offline Find More Posts by Gerry Santos
Old Jul 05, 2015, 10:43 PM
Wintr is offline
Find More Posts by Wintr
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
The BEC in each ESC is only 2A, and linear, which may be a bit light to power all those servos. To add an external BEC, you would have to disable the BEC in each ESC and connect the external BEC to the receiver, but, since you will have four 2A BECs, you could split the power from them, so each would power some servos, and one the receiver independently. You would have to make a harness that routes the throttle signal and ground to all for ESCs, but isolate the center +5V leads, routing one to the rx and some servos, another to power other servos, which have their +5V leads isolated from the rx. It would take a bit of wiring, but would save another component. Weight-wise, it would probably be a wash
Wintr is offline Find More Posts by Wintr
Old Jul 06, 2015, 08:50 AM
Manila, Philippines
Joined Jul 2001
I plan to make a short distribution cord for the rx side of the esc with the red wire disabled. Hope this works.
Thanks.
Old Jul 06, 2015, 10:17 AM
Xpress.. is online now
Find More Posts by Xpress..
Hitec RCD CSR
Xpress..'s Avatar
United States, CA, Alpine
Joined Oct 2007
The simplest method to provide ample power for all of your servos is just to run an external BEC. Remove the red wire from each of the ESC's receiver leads, then solder in an additional lead for the BEC on the main battery connector- plug your BEC in here and then plug the BEC's receiver out lead into your receive.r Any 10 amp BEC will be plenty of power, such as the Castle Creations 10 amp BEC.
Xpress.. is online now Find More Posts by Xpress..
Discussion External Capacitors for added RX voltage potectiob captain MoMo Radios 11 Jun 28, 2015 05:29 PM
For Sale Align 6A external BEC new! ExecutionKustoms Aircraft - Electric - Power Systems (FS/W) 1 May 01, 2015 10:10 PM
Sold Three HV External BEC's: CC BEC Pro; Western Robotics; Koolflight Ultimate jgalexander Aircraft - Electric - Power Systems (FS/W) 0 Sep 29, 2013 01:10 AM
Sold Four External HV BEC's: CC BEC Pro; Western Robotics; Koolflight Ultimate jgalexander Aircraft - Electric - Power Systems (FS/W) 3 Sep 25, 2013 01:20 PM
Sold Four External HV BEC's: CC BEC Pro; Western Robotics; Koolflight Ultimate jgalexander Aircraft - Electric - Power Systems (FS/W) 0 Sep 19, 2013 03:40 PM
