View Poll Results: can you have a smaller rudder on a bype due tothe second wing?
yes 2 16.67%
no 7 58.33%
depends on size of the wing 1 8.33%
I dont know 2 16.67%
Voters: 12. You may not vote on this poll
Old Apr 17, 2014, 08:28 AM
JosephSzczur101 is offline
Find More Posts by JosephSzczur101
Flying>Life
JosephSzczur101's Avatar
Joined Jan 2013
Idea
Concept and Design
Hello everyone,
I have started a new thread on here that is about Concept and Design for F3P and AM indoor planes. On this thread, you can post ideas that have a concept and a design that isn`t a typical for F3P or AM. The main idea for this thread is to use your imagination to come up with a solution for problems such as weight, drag, etc.
Idea 1- Since contas are very expencive, I have an alterative solution. Use a motor in the middle of each wing that spin in oppisite directions.
Positives: eliminates torque
Negitives: can be heavy, 2 motors=2 ESC, needs reinforcement for motor mount
Please share your thoughts and ideas on this type of stuff and make recomandations for these ideas.
Best of luck,
Joseph
JosephSzczur101 is offline Find More Posts by JosephSzczur101
Old Apr 18, 2014, 02:32 PM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
I love the idea of this thread!! I will post here if I have any ideas.
About the contra systems. I have thought about that, but have worried about how your could get airflow to the tail surfaces effectively. I think your biggest problem would be the CoG and the weight of the system. I would love to see someone try it though.
Also, I've made a coaxial system for under $100 including props.
Free
Free is offline Find More Posts by Free
Old Jun 08, 2014, 11:04 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Keep inertia in mind. The more weight you move outside, the more initial (and final) response you take away. You also do not need two ESCs for two motors.
As for rudder size...the rules don't change. And you want your balance of vertical surface area in favor of the rear.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jun 10, 2014, 10:04 AM
awood12345 is offline
Find More Posts by awood12345
Epic Win or Epic Fail!
awood12345's Avatar
Kent, England.
Joined Dec 2001
Just an idea, to increase roll authority with a contra-rotating setup could you use differential torque by slowing one down and increasing the other? Like a contra-rotating heli does.
awood12345 is offline Find More Posts by awood12345
Old Jun 11, 2014, 10:14 AM
Free is offline
Free's Avatar
Joined Jan 2012
I think Kimmo talked about this. He said that it would be a bad idea because it would create p factor as well as torque. THIs is the main reason why people don't do it.
Free
Old Jun 11, 2014, 02:19 PM
Joined Nov 2007
It would be like running a prop in front or directly behind of a wall. Not a good idea.
Old Jun 11, 2014, 08:58 PM
RED_HLG is offline
Find More Posts by RED_HLG
Adam RED Weston
RED_HLG's Avatar
Brier, WA
Joined May 2006
I've got differential speed on my contra set up on my scratch built F3P, it works well... It's particularly useful in doing torque rolls. I've copied Kimmo's set up with two speed controllers, without it, you would have to do a great deal of fiddling to get your front and back motors tuned so they don't produce torque. This is most efficiently done with different throttle curves for each motor. The roll is set up using aileron to throttle mixing.
RED
RED_HLG is offline Find More Posts by RED_HLG
Old Jun 11, 2014, 09:10 PM
RED_HLG is offline
Adam RED Weston
RED_HLG's Avatar
Brier, WA
Joined May 2006
A Little Different Design Aproach
So, I think this will fit on this thread... I came up with this design as I brainstormed how to make a light and stiff structure to compete in F3P. A space truss came to mind as the lightest approach and current designs are adding drag devices, why not use the trusses as structural elements AND drag elements! I call it the Carbon Truss 3D.
That's the concept...now on to execution. I wanted a Mylar surface, and I chose carbon rods to make the structure. I chose a relatively simple design and mirrored some of the parameters from my Vision 3D such as tail volumes and fuselage size. The wing planform started out as a rectangular wing, and morphed later as a added more wing area.
The hardest part of doing a truss is making the junctions between the rods. Another challenge is covering the surface once the truss is built. I used woven Spectra kite string soaked in CA as a joiner. I would scrunch the spectra up so the rods could go down the middle than I would pull the Spectra tight over the rod joint and then soak it in thin CA
the wing is a truss set up to support the Mylar surface. I did some triangles with the rods and Spectra then joined them with some Spectra knots. This continued until I had a full wing.
More soon...
RED
Old Jun 12, 2014, 11:08 AM
Jim_Marconnet is online now
Find More Posts by Jim_Marconnet
Fly long and land softly
Jim_Marconnet's Avatar
Madison, Alabama USA
Joined Oct 2005
red_hlg Thanks for sharing your photos and construction details. I've been thinking along these lines for some time now. In fact, I bought a Vision 3D kit but I have not begun to build it. It looks like a LOT of building effort. And I'm not sure that I can build it as light a necessary for a really slow, acrobatic airplane without using too much glue weight.
Your joints for the carbon rods looks unique. My earlier attempts to join carbon rods with tow and superglue gave me really stiff, easily breakable joints. So I've thought there must be a better way. In fact, everything I've done with super glue made things so stiff and breakable at the joints.
I like Uhu Creative and Uhu Por for getting flexible glue joints. I don't like the long drying time.
I saw a plane design some time ago which used carbon rods and tiny fuel line to join them. That looked flexible and promising, but perhaps heavy. There also is heat-shrink tubing.
Again, thanks so much for sharing!
Jim_Marconnet is online now Find More Posts by Jim_Marconnet
Old Jun 12, 2014, 10:50 PM
RED_HLG is offline
Adam RED Weston
RED_HLG's Avatar
Brier, WA
Joined May 2006
Thanks... Happy to share, I would love to see some folks take this concept and run with it. The plus side on this construction was it it's so tough, yet light. This plane is a lot stiffer than my EPP and carbon rod Vision 3D, and actually ended up being even more durable and WAAAY more durable than a milled depron plane. I ended up over building it, I used a lot of 0.035" and probably could have made it all out of .020 or even 0.015".
The spectra really makes a great joint, it not brittle, and we'll even stay stuck to the rods if you totally break up the CA. In fact, using it as a control horn was where I first learned about this construction. Fred Mallot made an R/C HLG that had carbon rods for push rods, then at the surface you would score the rod about 3/4" (18 mm) from the end of the rod. Then slide the 1/2" (12.5mm) long woven spectra over score. Then you would disk with CA. Then you would break the carbon where the score was and bend the spectra/CA up until it made about a 45 degree to the control surface.
The downside of the Carbon Truss 3D's construction was it was very slow. I spent 10x longer than my Vision 3d and maybe 20 times longer than a flat foam design. I did end up a little heavier than I wanted, but I could have pulled that out with smaller rods and lighter Mylar. Also, the joints with spectra are a challenge because the carbon rods, even when sharpened, tend to snag on the spectra when you slide the sick over the end.
Some additional thoughts on the joint option I would like to explore are some plastic joiners like T's and X's. I could imagine some 3D printed joiner that has five or six nipples pointing in all the directions necessary to make some of the complex joints.
More later... RED
Old Jun 16, 2014, 08:04 PM
Flying>Life
Joined Jan 2013
Hey Red_HLG,
what was the total weight of your design?
Joseph
Old Jun 18, 2014, 01:51 PM
RED_HLG is offline
Adam RED Weston
RED_HLG's Avatar
Brier, WA
Joined May 2006
Right now, she's at 84g without battery... So sub 100g flying weight. Like I said, I think this truss concept could be much lighter than what I built it at...
RED
Data VTOL RC aircraft concepts, designs and links leadfeather VTOLs 102 Aug 31, 2015 06:27 AM
Discussion Frame Concepts. Can a more efficient frame design add flighttime to Multicopters? izzzzzz6 Scratchbuilt Multirotors 64 Jun 06, 2015 12:03 PM
Build Log CPO's Modified Tricopter Design Concept : Building Around GoPro FOV cpo Scratchbuilt Multirotors 38 Feb 09, 2014 07:57 AM
Discussion Designing for storms - or - "throwing design concepts to see if one sticks" MCarlton Slope 15 Oct 17, 2009 06:28 PM
Counter rotating 3D design concept Nowell York Electric Plane Talk 1 Apr 23, 2003 06:35 PM
