Old Nov 20, 2013, 09:29 AM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Yes, it is available. On the prototype page on the web site. As soon as one of them flies it will go into the main portion of the catalog.
charlie
manzano laser works
portablevcb is offline Find More Posts by portablevcb
Old Nov 20, 2013, 12:34 PM
PETERRAKE is offline
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
Jim,
Only the front and rear formers have stringer notches. That avoids the intermediate formers showing through the covering and eliminates the risk of me getting notches in the wrong place to allow nice straight stringer runs. Nothing looks worse than crooked stringers.
Pete
PETERRAKE is offline Find More Posts by PETERRAKE
Old Nov 20, 2013, 01:13 PM
cloud_9 is offline
Find More Posts by cloud_9
Jim in the Desert
United States, NM, Las Cruces
Joined Aug 2007
Originally Posted by PETERRAKE View Post
Jim,
Pete
OK, got it, thanks Pete.
cloud_9 is offline Find More Posts by cloud_9
Old Nov 22, 2013, 08:42 PM
Zephyr41 is offline
Find More Posts by Zephyr41
Zephyr41's Avatar
Malanda, QLD Australia
Joined Jul 2004
charlie
manzano laser works
Working on it! I only have to add registrations and engine cylinders to mine, and take a few photos before the first flight of course...
Zephyr41 is offline Find More Posts by Zephyr41
Old Nov 24, 2013, 06:32 PM
conrad907 is offline
Find More Posts by conrad907
conrad907's Avatar
China, Guangdong, Shenzhen
Joined Feb 2012
Originally Posted by cloud_9 View Post
Thank you for this build thread. Your pictures are excellent and it is very helpful for me that you provide so much detail about your build. I have tried a couple build threads before but they don't provide detail that a beginner like me needs. Hope all is well with you in China. Please let us know how you are doing.
May I ask, what about the left wing being 1/16" longer than plans? That is from the laser cutting right? But it seems not a real problem?
Is it common for there to be small deviations from plans when you build a laser cut kit?
Last question for now, is this a standard kit that Manzano Laser Works offers or did you ask them to cut it from plans for
Thank you, looking forward to seeing the finished plane.
Jim
Hi Jim,
I just got home from the hospital yesterday. The plan, I suspect is affected slightly by humidity as Peter pointed out. It is very humid here in Shenzhen as opposed to where I moved from in Alaska. I allowed the wood to acclimate to the weather here for two weeks before starting the build. The wings build perfectly symmetrical, the cutting is spot on. This kit will not disappoint you, everything is top quality.
I am pretty weak at the moment, but so close to being able to fly this plane, I will continue to get the final things done, and hopefully have it in the air soon.
Zephyr also has a build over in Scale Electric Planes going right now on this plane you should check out.
Conrad
conrad907 is offline Find More Posts by conrad907
Old Nov 24, 2013, 10:22 PM
cloud_9 is offline
Jim in the Desert
Joined Aug 2007
Originally Posted by conrad907 View Post
Hi Jim,
Conrad
Thanks Conrad. Sorry you are feeling weak but I'm sure you are going to be getting stronger now with good care.
My masters graduate student Zhiheng Zhou lives in Shenzhen I believe. He is now applying to PhD programs in the US. Nice and smart person.
Thanks again for the build thread. I have learned a lot from it. Have you ever built from scratch, and if so, is it a lot more work to get things right?
Take care.
Jim
Old Nov 26, 2013, 03:12 AM
Zephyr41 is offline
Zephyr41's Avatar
Joined Jul 2004
Hi Jim,
I'll answer now, hopefully Conrad will feel well enough and have Wi-Fi access to chip in soon...
First of all, 'scratch' depends on where you're from! For Pete and myself it means designing your own model and building it from available materials. For American modellers it seems to mean building from a published plan.
There's no problem in building from a plan, particularly if the plan is as accurately drawn as Peter Rake's CAD plans. If you can cut the parts to reasonably closely match the parts on the plan you will have no trouble assembling a model from your own 'kit' of parts.
You might find some small dimensional discrepancies due to the paper changing shape and also the printer used- they usually distort the plan slightly one way or another. It won't be a problem though, either build to the plan and don't worry or simply build one wing over the plan then spray the same wing on the plan with cooking oil, turn your newly transparent plan over, and build a second wing identical to the first.
I usually pin the spar over the plan, slot the ribs in place, and use the ribs to dictate where the leading and trailing edges will go. If your plan uses a notched spar, that will dictate the rib spacing.
Is it more work? Yes, you have to cut the parts yourself and there might be some minor adjustment needed to get everything lined up just right during final assembly. It's much more satisfying that building from a kit though... If you're thinking of giving it a try, go for it! There's plenty of help available here if you encounter any difficulties.
Cheers
Rich
Old Nov 26, 2013, 04:47 AM
conrad907's Avatar
Joined Feb 2012
Hi Jim,
I cannot say I have done a true scratch build, I have done some kit bashing and enlarged a given kit, requiring me to cut all my own parts. I agree with Rich, a true scratch build would involve say taking a 3 view drawing of an airplane with some profiles and then designing your own plane from the ground up.
The Verville Aircoach is such a high quality and reasonably priced kit, it wouldn't be worth cutting your own parts from just a set of plans, IMO.
My next build will be a kit bash of a 1958 C-45 Beechcraft that was marketed by Eureka Models over 50 years ago. This is a 50" wingspan control line kit designed for two 45-60 IC engines. It is a beautiful kit with spun aluminum engine cowls and many very nice parts, however I will build it as an electric RC. Since the kit is designed for all planked construction, I will need to re-make all the parts and build it as lightweight stringer construction airplane. A very major project for me at my level, but I am sure I can do it. But, this is not what I call a scratch build, just a kit bash with my own characteristics thrown in.
Conrad
Old Nov 26, 2013, 09:02 AM
T_om is offline
Find More Posts by T_om
The Junk Man
Jacksonville, Florida
Joined Jul 2006
True, but then if your definition applied, the only planes you could build from "scratch" are your own designs. And by "designs" I mean from the ground up, not taking a set of three-views or other source and copying the original designers "design".
So you could never scratch build a scale model using your definition since you did not design it in the first place. I prefer ours.
Tom
T_om is offline Find More Posts by T_om
Old Nov 26, 2013, 11:30 PM
cloud_9 is offline
Jim in the Desert
Joined Aug 2007
Thanks Rich and Conrad. I guess I want to get to where I can scratch build American style, cutting my own parts from plans. I hope to get some plans for an Extra 300 or 260, not as classy as the planes you guys build but it's the kind of flying I want to try--IMAC.. There are kits for the size I want (around 80 - 90 inches). But they are very expensive. I don't know if I can get the plans without buying the kit. I'd rather be able to just cut the parts myself and build. Flying a $1000 kit or ARF around doing aerobatics (NOT 3D) makes me nervous. If I built the plane myself from plans, it would just be lost effort if there were an "incident.". Once I can produce the plane or parts as needed I would enjoy it more and I love having planes on my bench though I have yet to build from a kit or scratch build. I could also try different wings.
There is a Carl Goldberg Extra 300 on Ebay but it's pricey. I'm still tempted. I'd have plans for an Extra that is not designed to imitate a helicopter, but rather to fly IMAC. WhiskyKid said the CG 300 was designed for Minimac (cheaper IMAC). Then I could scale those plans as needed, and never touch the kit's parts as it's only 68". But I'd have them as examples. But as I said, it's a bit pricey.
Hopefully I'll find plans somewhere.
Thanks for the info, it's a big help. Sorry to distract from the build. Looking forward to hearing about the maiden.
Jim
Build Log Peter Rake Prototype Pietenpol Air Camper (45") scigs30 Scale Kit/Scratch Built 16 Mar 18, 2013 10:52 AM
Discussion Peter Rake Bristol Scout prototype portablevcb Scale Kit/Scratch Built 30 Jun 05, 2012 12:32 AM
Build Log Peter Rake-designed 30" Verville Air Coach (Prototype Build) Deuce Scale Kit/Scratch Built 58 May 31, 2012 07:10 PM
Build Log Peter Rake 43" FE8 prototype build Pat Lynch Scale Kit/Scratch Built 359 Oct 01, 2011 03:49 PM
Peter Rake 50" Camel prototype wanted AerodromeRC Scale Kit/Scratch Built 8 May 28, 2003 11:36 PM
