Old Aug 26, 2013, 12:41 PM
orcarmely is offline
Find More Posts by orcarmely
Joined Jul 2013
Motor for Hobbyking YAK 54 EPP
Hi,
I am interested in buying this plane:
http://www.hobbyking.com/hobbyking/s...dproduct=15302
How is this Motor+Prop combination (30A ESC)?:
Motor:
http://www.hobbyking.com/hobbyking/s...dproduct=12920
Prop:
http://www.hobbyking.com/hobbyking/s...idproduct=9845
Also, do I have to get servo extension wires?
Thank you!
orcarmely is offline Find More Posts by orcarmely
Old Aug 27, 2013, 11:15 AM
RAlanBoyle is offline
Find More Posts by RAlanBoyle
Grass stain your plane.
RAlanBoyle's Avatar
United States, IL, Chicago
Joined Feb 2011
That motor needs a 40A ESC. Aside from that it should work fine. You will probably need 2 4" extensions since the tail servos are mounted at the back.
RAlanBoyle is offline Find More Posts by RAlanBoyle
Old Aug 27, 2013, 11:26 AM
ahicks is offline
Find More Posts by ahicks
United States, MI, Waterford Charter Township
Joined Aug 2008
I think that HK 40a recommendation is a misprint? The motors max amperage is 21a, making a 30a ESC more than adequate?
I have the 42" version of this plane and it requires 18" extensions. Thinking 4" may not be enough, but not sure of specifics.
I think your setup looks good, other than maybe the prop? If you look at some of the reviews, they don't think much of them. Check out the "APC style". I've had really good luck with those.
ahicks is offline Find More Posts by ahicks
Old Aug 27, 2013, 09:48 PM
KE Spin is offline
Find More Posts by KE Spin
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
+1 on what Ahicks said. You should be ok with (2) 8" or 12" extensions.
However, the motor is only 50 grams and I think that when you factor in efficiency, you will not really get the 200 watts that is listed.
I have had several planes in the 36" wing span size range and have found that for excellent 3d power you should have a 450 size brushless motor turning a 10 x 4.7 apc slow flyer prop.
KE Spin is offline Find More Posts by KE Spin
Wanted Looking for 3DHS 48" EPP Yak 54 djmoose Aircraft - Electric - Airplanes (FS/W) 7 Jun 12, 2013 11:23 AM
Sold 3dhs 48" EPP Yak 54 airframe for sale LPU only Gainesville, FL jason f Aircraft - Electric - Airplanes (FS/W) 2 Apr 25, 2013 05:39 PM
Sold 3dhs 48" EPP Yak 54 airframe for sale LPU only Gainesville, FL jason f Aircraft - Electric - Airplanes (FS/W) 5 Feb 26, 2013 11:12 AM
Sold 3DHS 48" EPP Yak 54 LPU 7oneWo1f Aircraft - Electric - Airplanes (FS/W) 2 Feb 01, 2013 01:54 PM
Wanted Landing gear for 3dhs yak 54 or extra 300 epp.. yucafrita Aircraft - Electric - Airplanes (FS/W) 1 Jan 05, 2013 05:50 PM
