Old Dec 30, 2012, 02:01 PM
mtlman is offline
Find More Posts by mtlman
Joined Sep 2011
Another newbie asking advice for first plane
Hi all
I have a RC truck and now got the chance to fly my buddies nine eagles skyrunner trainer. I loved it and now obviousily I need to get one myself =)
I'm really new to planes so Im looking for a fairly cheap, durable and easy enough packet as a first training rc plane. Could you pros help me out on what model to get from eg. hobbyking ?
The skyrunner is OK as it has the rotor on top so I wont have to replace it every time I (crash)land. I would like a bit more power and all 4 channels.
I was looking at this model from HB - any comments ?
http://www.hobbyking.com/hobbyking/s...ft_Radio_.html
Any comments or recommendations would be most appreciated - thanks!
mtlman is offline Find More Posts by mtlman
Old Dec 30, 2012, 02:24 PM
easyrider604 is offline
Find More Posts by easyrider604
Canada, BC, Port Coquitlam
Joined Apr 2012
That bixler should be fine. I will not be impressed by their video, though. They showed a total newb effortlessly fly the bixler....not likely unless he'd done some simulator time
Having had stick time on your friend's trainer, you should be ok with that bixler, IMHO. Just have your friend beside you for maybe a dozen flights, to take over, just in case. Beginners will always get into trouble. I found that trainers of this type are somewhat stable but not as good at self stabilizing as say a high winger with lots of dihedral, like a HobbyZoneSupercub. So you have to apply a touch of counter aileron after completing a turn to return the wings to level.
easyrider604 is offline Find More Posts by easyrider604
Old Dec 30, 2012, 02:38 PM
luka.v is offline
Find More Posts by luka.v
Joined Dec 2012
by the way is the motor for th sky runner ment to be mounted at an angle because on mine it is and i dont know wether it is bad manufacturing or designed like that ,does anybody know?
luka.v is offline Find More Posts by luka.v
Old Dec 30, 2012, 02:45 PM
mtlman is offline
Joined Sep 2011
On my friends plane it is on an angle and I think its supposed to be like that so it revokes the rotary force or something (sorry my bad english).
Old Dec 30, 2012, 03:11 PM
mtlman is offline
Joined Sep 2011
a further question for you pros - I need an additional battery for the plane and cant really find any info on HB what of the suggested lipos will actually fit the plane.
will this for instanse fit & work ?
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
Allso - will I need any connectors for the additional battery ? Thanks again guys for your help.
Old Dec 30, 2012, 03:43 PM
luka.v is offline
Joined Dec 2012
well i would measure the dimentions of the battery compartment and then find a battery that suits the dimentions from hobbyking
Old Dec 30, 2012, 03:45 PM
luka.v is offline
Joined Dec 2012
ohby the way you probably wont need any extra connectors just make sure the battery has the right ones
Old Dec 30, 2012, 03:49 PM
mtlman is offline
Joined Sep 2011
Luka, cant do that since I dont have the plane yet.. I want to of course order the plane & accessories at the same time.
Old Dec 30, 2012, 03:59 PM
C₄H₁₀ is offline
Find More Posts by C₄H₁₀
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
Joined Aug 2009
Yeah, that battery will work fine. Most lipos follow the same general size patterns, so for a given cell count (3S) and capacity (1300mAh) you can be fairly sure that the packs will be very close to the same size.
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Dec 30, 2012, 05:46 PM
1fullbird is offline
Find More Posts by 1fullbird
1fullbird's Avatar
United States, NE, La Vista
Joined Nov 2011
Battery size
The Bixler can hold much larger batteries as long as you get the COG correct. On mine I use 70MM or 2 3/4" from the leading edge of the wing. Even if you use a 1,300 mAh you will need to make sure the COG is correct.
I currently fly with a 2,650 & 2,200 mAh to give you an idea. Velcro on the bottom of the battery and on the inside of the fuselage to keep it from sliding around.
I put the battery in, put the canopy on and then a finger on the COG to see if the fusleage is level. If not move the battery fore or aft until you have the COG correct. A little nose down (very little) is ok--nose high makes it tough to fly. You have to carry a lot of speed to control. (Don't ask me how I know, lets just say it was a learning experience.)
1fullbird is offline Find More Posts by 1fullbird
Old Dec 31, 2012, 01:17 AM
mtlman is offline
Joined Sep 2011
Thanks fullbird thats very helpful! Will have to place my order soon.
How about spare parts, I would think that for the bixler it is fairly easy to get them? ? For RC cars you can find explosion pictures etc and spareparts are super easy to find. I couldnt really find any parts on the HK pages tough ?
Old Dec 31, 2012, 07:50 AM
dazza44 is offline
Find More Posts by dazza44
who put that tree there
dazza44's Avatar
Joined Jun 2010
for spare parts just get add the kit version also to your basket.
prob be cheaper in the long run..
dazza44 is offline Find More Posts by dazza44
Old Jan 01, 2013, 01:45 AM
mtlman is offline
Joined Sep 2011
Thats a good idea will do just that, and the electronics you can obviousily replace..
Old Jan 02, 2013, 11:08 AM
1crazyflyer is offline
Find More Posts by 1crazyflyer
crazyflyer
Joined Jan 2013
The Bixler is a very good trainer.
I fly the original and enjoy it. it flys itself straight and level when set up and trimened properly.
good trainer, but the spar needs beefed up, and you need to hold the wings in place.
I use velcro on 2 points on each wing half.
other than that it is a great plane..
I also use a 3s 2800ms Venom battery without using any change in wt.
It will fly good nose heavy but make sure it is not tail heavy. do this by checking the CG
I wouldn't go over a 3400ms. if you go that big you may have to remove the washers in nose of plane.
1crazyflyer is offline Find More Posts by 1crazyflyer
Question Lipo Fires Are Real![Fantastic Advice!] Can I ask for further help? rcheli1 Batteries and Chargers 83 Feb 19, 2013 09:26 PM
Discussion Help!! newbie needs plane advice RCAddict16 Electric Plane Talk 10 Apr 26, 2012 07:16 PM
Newbie needs advice on first plane bullman Beginner Training Area (Fuel) 7 Aug 29, 2005 01:31 PM
Should have asked for advice first! djwright4341 Batteries and Chargers 5 Apr 29, 2004 06:27 AM
