Old Oct 08, 2012, 09:55 AM
RCHSF is offline
Find More Posts by RCHSF
United States, NC, Dobson
Joined Jan 2007
Help!
Yellow 65A ESC
Any one know how to setup this ESC?
All it says on the bottom is 65A
I got it with a HB3650 1700KV Outrunner, suposed to be for trex 500 heli.
But I was going to use the motor with a e-flite power 25 heli motor, for another bird. And I did not get any instructions with the esc. Got it in a trade.
RCHSF is offline Find More Posts by RCHSF
Old Oct 08, 2012, 11:46 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Looks like a Suppo, so maybe try this: http://www.suppomodel.com/ESC/Normal..._and_above.pdf
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Oct 08, 2012, 12:21 PM
RCHSF is offline
Joined Jan 2007
Thanks Dr Kiwi, I'll give it a try, after I solder up some connections.
Old Oct 08, 2012, 12:50 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
I think suppo always used a contiguous heat shrink with a hole in the top, and I don't think they ever made 65A escs, - but the yellow color is pretty suppoish. I'd suggest also try the SuperSimple programming too... unless that's the same as suppo, which It might be
acetech09 is offline Find More Posts by acetech09
Old Oct 08, 2012, 02:30 PM
RCHSF is offline
Joined Jan 2007
Well I slid the yellow heat shrink off each end and found the ground rx wire loose from ther PCB.
I may remove the BEC and Wire a straight RX Wire to the PCB, and just use it as a Standalone ESC. And use the little bec for a tail step down regulator.
May just use this for testing motors, or somethin.
I soldered a regular rx wire straight to the connections.
And It works, I removed the Red Wire, and Used a LIFE Pack to power the esc.
Sold Fms 65a esc hi2nr Aircraft - Electric - Power Systems (FS/W) 0 Sep 16, 2012 03:59 PM
Sold Turnigy AE-65A esc NIB sgomes Aircraft - Electric - Power Systems (FS/W) 1 Jul 26, 2012 06:16 PM
Sold FMS 65A ESC - New kellymacdaddio Aircraft - Electric - Power Systems (FS/W) 2 May 07, 2012 08:54 PM
For Sale Precision Aerobatics Thrust 50/Quantum 65A ESC combo DontTMACajun Aircraft - Electric - Power Systems (FS/W) 0 Apr 09, 2012 07:15 PM
Sold Thrust 50 + 65A quantum ESC danstah Aircraft - Electric - Power Systems (FS/W) 2 Mar 31, 2012 07:56 PM
