Old May 21, 2003, 11:40 PM
Shawn Davis is offline
Find More Posts by Shawn Davis
Little Rock,AR,USA
Joined Jun 2001
Li-polly charging
My question is what's the difference between li-polly charging and nmh? I race rc cars and have some very good chargers (for cars).They can charge down to .5 of a volt and down to 24mV peek detection on the voltage threshold. Will I be able to use what I have to charge
Li-polly?
Thankx,
Shawn
Shawn Davis is offline Find More Posts by Shawn Davis
Old May 22, 2003, 01:29 AM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
No you wont be able to do that successfully.
http://www.ezonemag.com/pages/efaq.htm#charger5
The problem is that Lithiums need to be charged in a totally different way than NiCd/NiHm, with different charge termination algorithms etc.
Using anything but a specific Lithium charger will ruin your pack.
Haldor is offline Find More Posts by Haldor
Old May 22, 2003, 02:15 AM
Little Rock,AR,USA
Joined Jun 2001
Back in the old days of rc car's before peak chargers we would hook up volt meters and peak them ourselves. I was wondering if you could peak lipo cells by temp and volts?
Old May 22, 2003, 05:39 AM
Capt. Electron is offline
Find More Posts by Capt. Electron
Senior Moment Member
Virginia Beach, Va.
Joined Jan 2002
LiPoly cells "peak" long before the charge is finished.
When the peak voltage (max cell voltage) is reached the charger holds that voltage constant by slowly decreasing the current as the charge progresses. The charger never exceeds the max cell voltage and charging is terminated when current drops to about C/10.
NiCad and NiMh chargers won't hold a constant voltage but keep increasing, watching for it to level off then drop slightly (peak detect) to determine end of charge. There is no way to limit the output voltage to a set level, NiCad/NiMh chargers don't need or have that feature. They are just not designed to provide the constant voltage output Li cells require.
Jimmy
Capt. Electron is offline Find More Posts by Capt. Electron
Lab Test of Li-Poly charging cycles Augusto Batteries and Chargers 24 Feb 21, 2003 11:54 AM
Li-Ion Charging: Parallel or Series? meteor Batteries and Chargers 0 Feb 18, 2003 08:51 PM
Li-Poly charging Rogercar Scratchbuilt Indoor and Micro Models 24 Sep 29, 2002 04:32 PM
Li-ion charging trutter Power Systems 7 Feb 20, 2002 11:18 AM
Li-ion charging Markz Power Systems 10 Oct 06, 2001 12:58 PM
