Old Jan 10, 2016, 10:32 AM
RCAV8R12 is offline
Find More Posts by RCAV8R12
RCAV8R12's Avatar
Joined Feb 2015
Help!
eagle tree tracker
Been using the eagle tracker with great results. Only problem is that every once in awhile the P&T servo's will stop working and antenna will drop, then after about 10 sec they will power back on and continue tracking. I am using Hitec servo 5955TG for tilt and a 7955TG for pan, I know they are overkill but they were laying around.
Does anyone have this problem or do they have a solution?
Steve
RCAV8R12 is offline Find More Posts by RCAV8R12
Old Jan 11, 2016, 10:57 AM
JohnET is offline
Find More Posts by JohnET
JohnET's Avatar
United States, NC, Charlotte
Joined Apr 2013
Hello,
The tracker is likely overloading the Eagle Eyes. Be sure your tracker is balanced. You can also power the servos from a separate BEC etc to provide more current. If you can't get it sorted please open a support ticket on our website.
Regards, John
JohnET is offline Find More Posts by JohnET
Site Sponsor
Old Feb 01, 2016, 05:37 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
an other thing that will cause this, is if you set your tracker end points beyond the range of motion of the servo. It causes the servo to push beyond its' ability, and creates a situation where it draws high amps. then as with the example that John gave, it has a thermal "time out".
m_beeson is offline Find More Posts by m_beeson
Article Eagle Tree Antenna Tracker Tutorial - RCGroups FPV Video Review Matt Gunn FPV Talk 15 Oct 29, 2015 12:54 PM
For Sale Eagle tree eagle eyes w/ Power Panel rmrc antenna tracker jminardi FPV Equipment (FS/W) 6 Sep 12, 2014 03:13 AM
Sold Eagle Tree Eagle Eyes GS , RMRC Antenna Tracker, RMRC Patch, etc. Beau0090_99 FPV Equipment (FS/W) 6 Jul 17, 2014 06:25 PM
Sold Eagle Tree OSD Pro + GPS + Eagle Eyes + Data Logger + Power Panel + Sensors + Tracker Borneoben FPV Equipment (FS/W) 6 Dec 21, 2012 11:25 AM
Sold Eagle tree eagle eyes with antenna tracker unit rdarby777 FPV Equipment (FS/W) 8 Nov 20, 2012 01:39 AM
