Old Jun 09, 2015, 12:05 AM
PDX Slope Pilot is offline
Find More Posts by PDX Slope Pilot
Eagle Butte User
PDX Slope Pilot's Avatar
Portland, Oregon
Joined May 2002
IDS - Integrated Drive System
This drive system caught my attention. Any experience out there with IDS and if so, how do you like it? Any pics showing how the horns are installed in the aileron/flap?
http://www.servorahmen.de/index.php?id=112
Regards,
Vic
PDX Slope Pilot is offline Find More Posts by PDX Slope Pilot
Old Jun 10, 2015, 12:56 AM
GER2387 is offline
Find More Posts by GER2387
Markdorf, Germany
Joined Oct 2007
Vic,
I am very happy with this LDS system in my all new Cyclone F3J ship with Futaba S 3174SV. Reliable and low weight. IDS is just a another word for LDS but mainly the same. You may purchase them from Servorahmen.de directly or from skipmillermodels.com. Skip Miller is the Servorahmen Distributor USA. More informations on the German (sorry) page http://www.rc-network.de/forum/showt...ervorahmen-IDS.
Stephan
GER2387 is offline Find More Posts by GER2387
Old Jun 10, 2015, 04:24 PM
TomFlyer is offline
Find More Posts by TomFlyer
United States, OR, Tualatin
Joined Apr 2005
Vic: This is similar to what Doug Boyd has developed and is producing on his CNC equipment. Doug's system is milled out of aluminum, uses an external bearing on the output shaft with a servo output arm that allows 160 (+/-) degrees of servo shaft rotation because of the design of his aluminum servo arm. It that looks more like a crank shaft for the off-set rotation pin that connects the rod eye to the servo arm. Doug's are made for MKS 6125 wing servos.
Tom
TomFlyer is offline Find More Posts by TomFlyer
Old Jun 12, 2015, 11:21 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Curious setup/gizmo.
Does seem more than a bit odd that the Moment arm on servo is same if not arguably larger than that of the flapper.
A Reverse lever ??
Doesn't this place a LOT more reliance on both the Accuracy And Power of the servo ?
Seems IMO as 2 steps forward and 3 steps backwards.
Bare is offline Find More Posts by Bare
Old Jun 13, 2015, 02:22 AM
Aaro is offline
Find More Posts by Aaro
Finland, Central Finland, JKL
Joined Jul 2014
Hi,
I have "semi-installed" two Servorahmen's IDS sets to my Xplorers's flaps. In these I did not use the IDS-horn (on flap side) but all the other parts. The result is very good (rigid and precise).
I'm now building a completely new X to which I will install the complete systems to whole wing.
Aaro
Aaro is offline Find More Posts by Aaro
Old Jun 13, 2015, 10:51 PM
windsinface is offline
Find More Posts by windsinface
windsinface's Avatar
United States, KS, Hays
Joined Jan 2007
Just got a new rotmilian f3f, it has roller drives or an IDS type system. I Need a set for KST servos . Any idea of who makes them? On the rotmilian and midi build they list them but no one has replied to e-mail .the roller type is somewhat different and look like tight install.
windsinface is offline Find More Posts by windsinface
Old Jun 15, 2015, 05:52 PM
mrfski is offline
Find More Posts by mrfski
Martin
USA, CA, Piedmont
Joined May 2005
Talk to Aloft Hobbies they carry KST servos
mrfski is offline Find More Posts by mrfski
Old Jun 17, 2015, 04:17 PM
Bro is offline
Bro
Find More Posts by Bro
Bro
Bro's Avatar
Southern California
Joined Feb 2003
Ids
Howdy,
We have these sets in stock for JR, and MKS.
Not on site, but give us a call...
626 967-6660
Best,
Bob
Bro is offline Find More Posts by Bro
Site Sponsor
Latest blog entry: 2015
Old Jun 20, 2015, 05:38 AM
Aaro is offline
Joined Jul 2014
Hi,
Almost ready with a complete IDS installation. Allthough the installation is finally quite clean, I was not happy with slight differences in paint shades... So I decided to hide the "corrupted" area Pictures show the flap linkage. There was no need to make any gaps to wing surface with the ailerons.
Here is a short video showing the aileron mechanism (before paint job): https://mega.co.nz/#!aFBhnRTB!053dtY...pCb2Uz8eWgYnCg
Aaro
Aaro
Discussion Drive System for Hydro's, etc? krkcdad Racing Boats - Electric 2 May 10, 2015 11:26 AM
Sold TrackStar D-Spec TS4G 2.4GHz 4-Channel Radio System (Gyro Integrated) dumbthumbbum Cars - Accessories (FS/W) 2 Apr 30, 2015 08:49 PM
Build Log Micro burshed Y, 8.5x20 coreless, gear drive, integrated PCB frame/FC Cereal_Killer Tricopters 3 Mar 03, 2015 11:33 AM
Discussion How can I make the drive system for a geared drive multirotor tedbyers Power Systems 12 Nov 30, 2014 10:20 AM
Alert Integration of Civil Unmanned Aircraft Systems (UAS) in the National Airspace System Eddie James UAV - Unmanned Aerial Vehicles 11 Nov 09, 2013 08:56 PM
