Old Feb 23, 2013, 11:44 AM
T J Gilbert is online now
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
@skipper1
I know that grasping the motor bell on Phantom is difficult due to the Phantom body.
I'd be careful squeezing the motor bell with those padded jaw pliers.
They appear to be giving you quite a mechanical advantage.
That could easily cause you to distort or warp the motor bell.
If you are keen on grasping the motor bell to prevent turning while you tighten props, I'd look into a small hook wrench that would engage one of the fins on the motor bell.
T J Gilbert is online now Find More Posts by T J Gilbert
Old Feb 23, 2013, 11:48 AM
Zbip57 is offline
Find More Posts by Zbip57
Zbip57's Avatar
Canada, ON, Ottawa
Joined Jan 2013
Originally Posted by cargasm View Post
Man! That looks beautiful Zbip57! I am jealous! Wish I was there. Get some good footage while you are there.
I'm looking forward to uploading the videos. I've got a couple of good ones coming...
Originally Posted by hellaskan View Post
Zbip57 - that looks awesome!! How scared were you to fly it over the water?
Terrified, at first. The wind was blowing quite strongly out to sea.
Originally Posted by Bo Lorentzen View Post
Looks like a good time. remember, flying ATTI is typically smoother than GPS... I try to fly ATTI when pushing a shot, then flip to GPS and do HomeLock to get back.
I should have used ATTI mode more, but I was very nervous about the wind taking the Phantom away. I've still only flown this thing less than ten(?) times, but am slowly becoming more confident.
Zbip57 is offline Find More Posts by Zbip57
Old Feb 23, 2013, 11:55 AM
skipper1 is offline
Find More Posts by skipper1
United States, TX, Dallas
Joined Jan 2012
It really takes very little pressure to hold the motor. The plastic is soft enough that it does a great job of hanging on to the motor. I guess if you gave it a gorilla squeeze you'd have some problems.
I have seen those hook wrenches but never knew what they were called or how you would use one. I don't think I would put one on my shinny new motor.
skipper1 is offline Find More Posts by skipper1
Old Feb 23, 2013, 12:10 PM
Empire Support
Joined Feb 2009
Hook Wrench
You've got to be careful with any tool.
Me, I'd reach for a hook wrench before I put a squeeze on it with pliers.
The hook wrench used improperly could distort the motor bell also.
Old Feb 23, 2013, 12:52 PM
HGT is offline
HGT
Find More Posts by HGT
HGT
United States, CO, Parker
Joined Jan 2013
Originally Posted by tanasit View Post
email sent with info.
Tanasit
Can you share the e-mail with me? I have the same interest.
HGT is offline Find More Posts by HGT
Old Feb 23, 2013, 01:02 PM
HGT is offline
HGT
HGT
Joined Jan 2013
Originally Posted by DutchVince View Post
Hmm, when my Phantom is 300 yards out I can't discern prop colours anymore.
I was thinking of adding something highly reflective to the battery door.
Something metallic that reflects the sky or sun very well.
It should really "glare" at you...
DONT FLY what you can't see. It's in the AMA rules...
My Father started teaching me to fly at 11, I am now 53 and teaching my wife to fly these with the assist of the NAZA product line... Use the CL if you cannot get the hang of orientation. I use it for filming all the time. Use HL if you loose orientation until you can clearly see it's orientation.
Unless your flying FPV you shouldn't be flying outside of your visual capabilities that varies for everyone.
Old Feb 23, 2013, 01:05 PM
sidneyw is offline
Find More Posts by sidneyw
United States, NC, Huntersville
AMA rules don't apply in Netherlands
sidneyw is offline Find More Posts by sidneyw
Site Sponsor
Old Feb 23, 2013, 01:07 PM
DutchVince is offline
Find More Posts by DutchVince
DJI Phantom pilot
The Netherlands, GE, Culemborg
Joined Jan 2013
I use the high friction rubber mats that you use to get the lids of jars.
1. You don't hurt your hands
2. You don't damage your Phantom
3. You probably won't over tighten the prop nuts.
DutchVince is offline Find More Posts by DutchVince
Old Feb 23, 2013, 01:17 PM
HGT is offline
HGT
HGT
Joined Jan 2013
Originally Posted by flitelab View Post
Using the black DJI props on one end and the white on the other would probably be the best for that route,
That's what I am doing on my F450 along with landing gear tips and the arms. Black props are invisible once they start rotating.
Old Feb 23, 2013, 01:18 PM
DJI Phantom pilot
Joined Jan 2013
Legislation is very fuzzy here: de Dutch are very good at banning and forbidding things (just in case) and then tolerating it as long as no serious accidents happen.
Apparently the law is enforced here when things go wrong
Hobby fliers can fly in any meadow or park and nobody will bother you.
Professional fliers (aerial photography) wil have to buy a certified drone with fail safes and redundancy etc. And probably will need to get some sort of pilots license etc. etc. They are working on it and it is not looking good I think, but still a lot better than the proposed Oregon ban.
Old Feb 23, 2013, 01:22 PM
DJI Phantom pilot
Joined Jan 2013
Well, I can see the drone at 300 yard, but not the prop colours
HGT is offline
HGT
HGT
Joined Jan 2013
A small tail flag is what some use. One of the small high intensity LEDs/strobes on the door would work as well, they are really easy to spot. HK carries them now for a few bucks and they are 5V so could tap into the power to the NAZA power on the gimbal channel perhaps with a servo lead.
http://www.hobbyking.com/hobbyking/s..._3_3_5_5V.html
Could even add 4, one on each arm to add to the existing LEDs perhaps.
The problem with the green LED is it is nearly identical in flash rate to the status LED.
Old Feb 23, 2013, 01:28 PM
Empire Support
Joined Feb 2009
Grasping Motor
With Phantom, I've just used the stock, DJI props, so I've not had the motor holding dilemma.
I think the posters are having trouble holding the motor with their hand.
If there's room to grasp the motor as you suggest, I'm for it.
On my other DJI multirotors, I use APC props and grip the motors with the friction mats you recommend.
Old Feb 23, 2013, 01:31 PM
sidneyw is offline
Orange color is best ....
Site Sponsor
tanasit is offline
Find More Posts by tanasit
United States, PA, Philadelphia
Joined Dec 2002
I normally use my hand strategically place around the can but I sometime use the surgical glove. Last time I had difficult time with the nuts with fangs, so I used the rubber strap wrench but just to remove not tighten. Now I am happy with my prop modification so I am abandoning the idea of custom can lock tool.
tanasit is offline Find More Posts by tanasit
Discussion DJI Quadcopter Frame BUILD Thread Quad_Addict Multirotor Talk 78 Mar 17, 2014 10:20 PM
Mini-HowTo POSTING VIDEO: How to Upgrade a Gaui 330x quadcopter with a DJI NAZA Lucidity47 Multirotor Talk 5 Jun 07, 2012 12:31 AM
Video Multiwii Quadcopter Dji F-450 frame Updated Video Anda Inc. Electric Heli Talk 1 May 23, 2012 02:51 PM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
