Old Mar 27, 2012, 04:55 AM
ryanrcflyer is offline
Find More Posts by ryanrcflyer
Joined Jun 2011
DX8 and Flight Modes
]hi there,
I've had a look through all the threads for DX8 & Flights modes and all I've found is for people wanted to fly gliders my questions is related to flight modes for planes.
Heres my scenario;
Take off, retracts up and trims are all fine, flying perfect. I think about landing and put the flaps down and my plane starts to roll to the right. I quickly have to 'trim out' the roll and plane flies straight again, gear comes down and I land.
After I landed a chap from the club said that I should program flight modes into my TX?? I ask him what he meant and he said that you can have two different flight modes, one for normal flight and one for say plane in landing mode (flaps and gear down) and have individual trims for each?? So with a flick of the switch flaps come down and trims are adjusted automatically.
By the way obviously we know the flaps need to may be adjusted mechanically but this programming or flight mode allows you to trim this out.
My question is how do I do this and is it actually possible on the DX8?
Hope you can help. Thanks in advance
ryanrcflyer is offline Find More Posts by ryanrcflyer
Old Mar 27, 2012, 05:25 AM
socommk23 is offline
Find More Posts by socommk23
always looking for clouds
socommk23's Avatar
Joined Aug 2010
flight mode button is on the top left of the transmitter. flight mode 0-1-2 or 1-2-3.
i use these for my stryker to set different epa for different manouvers. but for each mode trims are seperate too.
so if your glider is set up in flight mode 1 to fly straight and true......flick it to flight mode 2 to do the same....then make the nessessary adjustments for flaps to deploy and trim adjustments needed. then f/m 1 is flying and f/m 2 is landing.
later you can use f/m 3 for some camber as a thermaling setting or reflex for high speed setting.
socommk23 is offline Find More Posts by socommk23
Old Mar 27, 2012, 07:49 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
1- Power on the DX8 while holding down the Roller Menu button to access the System Menu
2- Using the Roller Menu button scroll down to Trim Setup and press the roller menu button to access sub menu
3- Scroll down to Type:Common and press the roller menu button to change it to F Mode.
4- Press Back Button twice to exit system menu
Now All of your TRIMS are independed for each flight mode.
Of course you should address this issue mechanicaly first but now you will be able to trim for different conditions. You could also set the flaps to that switch so all is done with only one switch.
In the Flap System menu you could select the F-Mode switch for flaps. Now when you toggle the Fmode switch for flaps the different trims would kick in. Of course you would need to set the trims once.
freechip is offline Find More Posts by freechip
Old Mar 27, 2012, 09:12 AM
socommk23's Avatar
Joined Aug 2010
what he said! what i meant. lol
Old Mar 27, 2012, 09:47 AM
Joined Jun 2011
BINGO! Thank you both chaps
Help! NAZA Basic and ATTI mode gain question, which one do I use on AUX3 on my DX8 jasper7821 Multirotor Talk 48 Mar 22, 2013 08:33 PM
Sold Real Flight G5.5 Mode 2 Cerus98 Aircraft - General - Miscellaneous (FS/W) 2 Mar 02, 2012 10:30 AM
Discussion Possible to change from mode 2 to mode 8 in flight? DX8 Rooster433 Radios 2 Feb 29, 2012 08:48 AM
Wanted Spektrum dx8 or JR 9503 mode 2 knifeedge63 Aircraft - General - Radio Equipment (FS/W) 10 Oct 20, 2011 06:02 PM
Sold spektrum dx8 mode 2 gmcmanv6 Aircraft - General - Radio Equipment (FS/W) 4 Oct 18, 2011 02:51 PM
