Old Nov 09, 2014, 08:37 AM
Joined Jun 2013
HELP F550 loses control but gimbal still is controllable
Strangest thing happened to my F550 today. Connected battery, got 9 satellites clicked record on Go Pro (H3 3D) and as I take off power is totally lost and the F550 falls like a brick (fortunately onto the grass only 1m above the ground!). After clicking back the legs and the dampeners on the gimbal I reconnected the battery (now on 16.7V 4S) and take off,every thing seems fine, I start to fly slowly to the right and and then lose control of the F550, it goes into Failsafe mode and starts to climb to 20m and starts to return home. I could not regain any control, but the strange thing is I was still able to move the gimbal up and down!! And tried switching between modes (GPS, Atti, Failsafe) but nothing changed it! So it eventually lands after 1 scary minutes (as I was next to a river). I called it a day, and have not flown it since? I have had more than 60flights already with no problems?
Does anybody know what could have happened? Radio interference?? Gimbal still worked?? The F550 was never more than 25m away totally in site?Your experience would be greatly appreciated!!!
Check video:
F550 Mystery loss of control but H3 3D gimbal is still controllable (2 min 23 sec)
Setup: JrPropo DS7X, Naza v2, iODS mini, H3 3D, 8000mAh 4S, 5.8GHZ DJI RX/TX, 7"monitor
Paulwest is offline Find More Posts by Paulwest
Old Nov 09, 2014, 08:52 AM
United States, SC, Moncks Corner
Joined Dec 2013
Did you have wifi turned on the Gopro?
Railrode1 is online now Find More Posts by Railrode1
Old Nov 09, 2014, 02:20 PM
Joined Jun 2013
Not that I am aware of? I never used the wifi feature. What I do know is that the GoPro battery was completely flat, as I usually turn the GoPro on before I plug the F550 battery in (so that the gimbal calibrates properly) - so not sure if this is somehow responsible for the first incident where the F550 just shut down - including the GoPro as you can see from the footage.
I like the idea of the WiFi interfering in the second incident, I must add we were pretty much out in the bush, and I have never experienced this type of thing in built up areas where there is a lot of Wifi. I thought the controller does band hopping to avoid interference.
Discussion PLease !! i need help with apm controller already research but found no help jaas75 Multirotor Electronics 8 Nov 03, 2014 12:45 PM
Discussion Maybe this was supposed to be helpful, but still... dll932 Life, The Universe, and Politics 0 Nov 21, 2013 11:34 AM
Question Need help with F550 NAZA gimbal setup chipwich Multirotor Talk 21 Sep 23, 2013 10:01 AM
For Sale Complete AP system: DJI Naza, F550, Gimbal, GPS, Hoverfly controller and Downllink jonnydonut Aircraft - Electric - Helis (FS/W) 0 Dec 03, 2012 03:47 PM
Discussion Ryan - 'If We Compromise Too Far, We Can Win But We Still Lose the Country’ D B Cooper Life, The Universe, and Politics 9 Dec 03, 2011 09:44 AM
