Old Dec 20, 2007, 05:51 PM
vintom is offline
Find More Posts by vintom
Joined Jun 2007
SC40 engine doesn't stop with closed throttle
I have a new sc40 engine which has been run with a couple of tankfulls to bed it in. However with the throttle fully closed (the hole in the barrel is completely covered plus a bit of extra movement) the engine continues to run slowly and the throttle cut button on the transmitter moves the barrel a tiny bit further and the servo protests audibly but the engine still runs. I have fitted a fuel line clamp to stop the engine but would appreciate any suggestions as to what I might try to stop the engine with the throttle fully closed.
The engine responds well to the throttle with no hiccups or hesitation although as a relative newcomer to the hobby I cannot say that I haven't missed anything. I have only adjusted the main needle since unpacking the engine from the box.
vintom is offline Find More Posts by vintom
Old Dec 20, 2007, 06:27 PM
rctoyflyer is offline
Find More Posts by rctoyflyer
your gonna snap the wings
rctoyflyer's Avatar
covina CA
Joined Aug 2007
maybe an airleak
check that the carb is all the way down and tight to the crank case.is there an o-ring there .i think that if anything else were loose than your engine would probably not run as good as it does.i dont think that your low speed needle has anything to do with it, maybe somebody will know more regarding your question.thats all i can think of.
rctoyflyer is offline Find More Posts by rctoyflyer
Old Dec 21, 2007, 01:00 AM
turk1 is offline
Find More Posts by turk1
turk1's Avatar
Istanbul, Turkey
Joined Aug 2004
Also seal the carb retainer bolt on two ends.
turk1 is offline Find More Posts by turk1
Old Dec 21, 2007, 03:18 AM
vintom is offline
Joined Jun 2007
Thanks for the input gents. Both suggestions 'tested' but sadly not the answer.
Old Dec 21, 2007, 10:14 AM
Bako is offline
Find More Posts by Bako
BAKO
Bako's Avatar
Tbilisi, Georgia
Joined Jul 2004
funny so u wanna tell that there is no airleak? maby your carburator barrel is worn and it leaks air?
Bako is offline Find More Posts by Bako
Old Dec 21, 2007, 10:46 AM
on pipe is offline
Find More Posts by on pipe
on pipe's Avatar
Omaha Nebraska
Joined Nov 2004
If its not the carb to case, or the backplate leaking air, it has to be too much clearance between the crank and case. There must be a leak somewhere... Ross
on pipe is offline Find More Posts by on pipe
Old Dec 21, 2007, 11:02 AM
Wayne V is offline
Find More Posts by Wayne V
Wayne V's Avatar
London, Ontario, Canada
Joined Jan 2006
Well my TT pro.36 has exactly the same problem, changed the o-ring on the needle, checked everywhere else only culprit seemed to be the front bearing leaking, sent it into ACE hobby and they replaced the crankcase, front bearing, pistonand liner. Got it back, fired it up and it did exactly the same thing, even with my finger over the carb pushing as hard as i could it would still run for about 20-30sec. So for my it's still either the front seal or something else in the carb.
Wayne V is offline Find More Posts by Wayne V
Old Dec 22, 2007, 12:53 PM
vintom is offline
Joined Jun 2007
I'm hoping to borrow another similar carb after Christmas which should narrow down the problem. I'll post the result as soon as there is progress.
Thanks for the input and have a good holiday.
Old Dec 23, 2007, 05:27 AM
Artisan is offline
Find More Posts by Artisan
NM2K
Ringgold, GA, USA
Joined Jan 2006
Follow the advice of the other gentlemen. But don't get upset if the engine still keeps running after following the other gentlemen's advice. Sometimes the way the engine is made will prevent it from being stopped by just closing the throttle. It doesn't happen often, but it does happen occasionally. Good luck.
Ed Cregger
Artisan is offline Find More Posts by Artisan
Old Dec 23, 2007, 10:11 AM
flypaper 2 is offline
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
One method I use on an ugly engine is to put a piece of plastic pipe over the carb intake,snug fit. Put the piston up till it just closes the ex. port. If it's an airbleed carb, stick your finger over the hole.. Take a can big enough for the motor,maybe cut an empty fuel jug, and fill it just over the motor with gas, kerosen, fuel oil, etc. Blow in the carb and it will show where the air leak or leaks is. Takes a bit of time but it's proof positive. One of the methods I used when I ran a small motor shop.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Dec 23, 2007, 02:36 PM
globemaster3c17 is offline
Find More Posts by globemaster3c17
Calm winds and CAVU skies
globemaster3c17's Avatar
Lawton, OK
Joined Jan 2004
Sometimes that I've had that happen, running it wide open for a bit then slamming the throttle back with the kill switch already moved would get them to die. Otherwise just stick a gloved finger over the exhaust hole.
globemaster3c17 is offline Find More Posts by globemaster3c17
Old Dec 23, 2007, 06:14 PM
jg4660 is offline
Find More Posts by jg4660
RCAPA #299
jg4660's Avatar
Joined Sep 2004
As long as you can get the engine idle to an acceptable RPM i wouldn't worry about it too much. There's a lot of guys that would kill for an engine that wouldn't "quit", it's better than the opposite problem.
JG
jg4660 is offline Find More Posts by jg4660
Old Dec 31, 2007, 05:50 PM
pentaxman is offline
Find More Posts by pentaxman
pentaxman's Avatar
Braintree, Essex, UK
I have had the same with my new SC 52.
I have made one adjustment, and that is to unscrew the throttle barrel stop a little more that it was set.
That helped no end, but now with it beginning to bed in properly she will cut nicely on the servo without too many problems.
pentaxman is offline Find More Posts by pentaxman
Old Jan 02, 2008, 06:15 AM
arukum17 is offline
Find More Posts by arukum17
London, UK
Joined Aug 2005
Same problem with my brand new, just broken-in K&B 20 sportster which is running well except for the closed throttle issue. This problem occurs only with only fuel and not with fresh fuel. The mysteries of glow engines...
arukum17 is offline Find More Posts by arukum17
Old Jan 03, 2008, 12:29 PM
pentaxman's Avatar
Mine is being run on fresh fuel so I do not necessarily think that is the cause.
I may fit a new plug to mine since I seem to be suffering one too many cuts in the air but can't stop the thing on the ground at times.
FMS cable doesn't work with XP???? ddoucette GWS (Grand Wing Servo) 13 Sep 20, 2004 08:02 PM
Our club website doesn't work with all ISP's? GregG Webhosting 15 Oct 18, 2003 09:23 PM
FMA M5 doesn't work with Azarr antenna! sblack Radios 16 Aug 12, 2003 08:52 AM
Aiptek video / Doesn't stop ... popop Aerial Photography 3 Apr 07, 2003 02:57 PM
GWS GS-400 ESC doesn't work with RCD 535... why :( harryo Power Systems 2 Feb 28, 2003 07:28 PM
