Old Jan 08, 2015, 04:48 AM
163413fc is offline
Find More Posts by 163413fc
Joined Dec 2012
V-twin cylinder steam engine
This engine is V-twin reciprocating structure, Model Q2, length 67MM, width 102MM, high 103MM. Weight 520G. Bores 10MM, piston stroke 12MM, flywheel diameter 26MM. Output shaft 5MM.Screw fitting is 1/4 "X 40 TPI. Pressure(in psi) is it designed to run at (about 10-50psi) ,Pipeline appropriate 3MM or 4MM.
Its structure is quite compact, The compact V-twin, reducing the vertical dimension.! Throttle switch connected oil cups intermediate layout switching valves And control the speed in both directions.made of metal carefully made of brass and stainless steel. Base increase the performance of two stainless steel bearings enhanced engine.Use stainless steel hex screws, engine seems more retro.
163413fc is offline Find More Posts by 163413fc
For Sale Q2 V-twin cylinder steam engine 163413fc Boats (FS/W) 3 Jan 07, 2015 01:27 AM
Sold 2 cylinder Twin steam engine SAITO Boiler B2F PMR Deserteagle Boats (FS/W) 2 Nov 24, 2014 01:27 AM
Discussion Twin Cylinder Vertical Steam Engine RC Reversing 163413fc Steam Boats 1 Nov 08, 2014 10:46 PM
Question Twin cylinder oscillating steam engine for 1/36 - disabled Steam Boats 18 Aug 10, 2014 03:14 AM
Discussion Twin cylinder steam engine 163413fc Steam Boats 0 Oct 04, 2013 09:16 PM
