Old Jun 05, 2014, 01:01 PM
kin is offline
kin
Find More Posts by kin
kin
Composite factory
Joined Sep 2007
Smartmodel EDF composite ( BaE Hawk /System Hawk for 100-110 mm)
Sorry for guys ! i leave here a year .And say sorry for the "project not finish".In the passed a year . Business finished with Fly Fly and start my own factory ...set up ..tranning ...marketing and 3-D drawing for models. ..have no time update about the new models .Today i post the models become finish is a Bae Hawk for 100-110mm fan , Length is 1520 mm ,Wing span(still thinking ).Because i want a little bit extra long for good flying preformance . This hawk are a little bigger than my old FF system hawk . Because this is BAE hawk , My old Sytem hawk(long nose) is for 90-100mm fan . The fuselage is a little bit biggerthan the FF system hawk , so i let the Bae hawk in 100-110 mm size .
kin is offline Find More Posts by kin
Old Jun 05, 2014, 02:17 PM
bruff is offline
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Looks nice.
Bob
bruff is offline Find More Posts by bruff
Old Jun 05, 2014, 04:02 PM
sam51401 is offline
Find More Posts by sam51401
Fly more Foam
sam51401's Avatar
United States, IN, Sellersburg
Joined Jun 2004
With the success I have had with your FF designs, I look forward to your next offerings under your new name. A larger Hawk is a welcome sight and I have a nice fan that would power it!!
I believe a ETurbax will be just fine!!!!
More pictures as the plane is further developed so keep updating.
Thanks Kin
Good luck with the new bussiness
sam51401 is offline Find More Posts by sam51401
Old Jun 05, 2014, 07:43 PM
delperena is offline
Find More Posts by delperena
Joined Feb 2006
Viggen
Hello Kin,
Glad to see you back.
Is the Viggen still in your "to-do" list?
Del
delperena is offline Find More Posts by delperena
Old Jun 05, 2014, 11:43 PM
SkylineFlyer is offline
Find More Posts by SkylineFlyer
Hawk Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
Thanks Kin
What? He didn't design your foam Hawk Sam. He designed the Hawk 100 fiberglass one that I have. And if this one is done in the same length and a slightly larger wingspan, then you'll be looking at the AMD hawk all over again. Lets hope not though as the hawk is by far my favorite jet and I will need this one too. LOL. It just depends on how scale he makes the intakes.
SkylineFlyer is offline Find More Posts by SkylineFlyer
Old Jun 05, 2014, 11:57 PM
Hawk Fanatic
Joined Jul 2008
FlyFly Hawk Foamie Length - 1465mm / Wingspan - 1365mm
FlyFly Hawk 100 Fiberglass Length - 1500 mm / Wingspan - 1200 mm
Kin's New Hawk Length - 1520mm / Wingspan - TBD
AMD Hawk Length - 1430mm / Wingspan - 1360mm
It appears that the AMD Hawk and the FlyFly Hawk foamie mimic each other in length and wingspan. The FlyFly Hawk 100 does have a higher wing loading, but closer to scale intakes, a thinner wing and unbelievably fast.
I look forward to seeing Kin's new hawk as well. Being that its not the Hawk 100, it will have a shorter nose, yet it will be 20mm longer than the FlyFly Hawk 100. I'm curious KIN as to when you think you might be going into production with this plane.
Your FlyFly Hawk 100 is absolutely beautiful and its my favorite flyer!
Old Jun 06, 2014, 04:23 AM
Nukiwi is offline
Find More Posts by Nukiwi
Now, what does this button do?
Nukiwi's Avatar
Christchurch. NZ
Joined Dec 2009
Please, yes!
Nukiwi is offline Find More Posts by Nukiwi
Old Jun 06, 2014, 10:41 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
it my passed experence and the market power system are going up and be much better power , so the size go a little bigger is need . i will let the size bigger and it can much better preformance than size small . This short nose BAE hawk everything is done now , the mold is done about three month ago , The wing now using this ep-retract gear , (http://www.smartmodel.com.hk/product...0&image=image1 ) and cnc scale retract , the retract gear is same my old FF Systen Hawk 100 . The balsa wing version is come out middle this month , I have finished the wing drawing and chose the airfoil , For the FF hawk experience , the ep retractgear is so hard to fit the FF hawk airfoil , So this time i make the airfoil a little thicker . the airfoil is semi symemtical . The FF system Hawk i use F3b airfoil so it is very fast speed very less drag . This time i make this BAE hawk with choice airfoil a little lower speed but very good in landing and lower speed . i want the preformance more better in slow speed , so i have use thicker airfoil , The second point is let it easy to install the retract gear . This time the scale parts will more than before .especial the tail bottom included the ( landing cable hook ) .and the small fin . the wing information will update tomorrow , Next question the Viggen still good in market ???? it is my important decision , because the mold not cheap
if the market result is not that good future . i afraid the cost return problem . Can you let me some commend about Viggen ,
Old Jun 06, 2014, 11:00 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
How i have busy in a Cessna 3.0 m full composite , after this models mold completed next month . this Bae Hawk( composite wing version ) start to build the wing mold . The following plan is a Vipper Jet -100 -110 mm , F-16 in end of the year , i think Oct-Nov. But in this moment , i let the Bae Hawk come out this month first . I will post the update information . And thinking which colour scheme in first batch ?
Old Jun 06, 2014, 12:12 PM
Mikael is offline
Find More Posts by Mikael
Mikael's Avatar
Sollentuna,Sweden
Joined Sep 2000
Please make the Viggen.
There seem to be allot of interest in the forums when the Viggen is mentioned.
Mikael is offline Find More Posts by Mikael
Old Jun 06, 2014, 01:51 PM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Please NO More Viper Jets! I vote for the Viggen too. Why not do a a T-45 Goshawk like the US Navy uses?
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Jun 06, 2014, 01:55 PM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Yes, the T45! Too many Hawks already...
4stripes is offline Find More Posts by 4stripes
Old Jun 06, 2014, 02:24 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
What ever became of the F-15?
http://www.rcgroups.com/forums/showthread.php?t=1197619
Posts #1 and #4
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jun 07, 2014, 08:11 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
The Goshawk colour is no problem ., i already have the sticker file , just print out for water sticker . very easy .But why not paint a new colour like this ??
Old Jun 07, 2014, 09:41 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Posts #1 and #4
Let see this year have time for F-15 or not , but it is my love one !
Sold BAE Hawk 90mm EDF Composite 1140mm (ARF) kclements Aircraft - Electric - Jets (FS/W) 17 Mar 09, 2014 03:00 PM
Sold BAE Hawk 90mm EDF Composite 1140mm (ARF) kclements Aircraft - Electric - Jets (FS/W) 4 Mar 01, 2014 08:32 PM
Sold BAE Hawk 90mm EDF Composite 1140mm (ARF) kclements Aircraft - Electric - Jets (FS/W) 3 Jan 18, 2014 09:13 PM
Sold CMP BAE Hawk 90mm Composite jet-Ready to fly x3dflyer Aircraft - Electric - Jets (FS/W) 3 Oct 14, 2013 07:05 PM
Sold TF / Smartmodel composite BAE Hawk 70mm Hemikiller Aircraft - Electric - Jets (FS/W) 2 Oct 04, 2012 05:33 AM
