HobbyKing Ridge Ryder Slope Wing
Includes ballast tubes
A rugged EPO soarer
The Ridge Ryder is a new slope soarer from HobbyKing that features removable ballast tubes that can be fine tuned to adjust weight and center of gravity. This molded EPO wing has built in hand launching grips and pre-installed servos. All you'll need is a transmitter and 2-channel receiver with elevon mixing, and a 4.8 - 6.0 volt receiver battery or 2S 7.4V 800mah Lipo.
CLICK HERE for more info on the HobbyKing Ridge Ryder
Specs:
  • Wingspan: 913mm
  • Length: 500mm
  • Weight: 175g (w/o battery)
Old Jan 21, 2015, 01:54 PM
Objects in mirror are losing
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
I'll give it a shot.
1000MPH is offline Find More Posts by 1000MPH
Old Jan 22, 2015, 12:01 AM
Flying in Area 61
ServiceRep's Avatar
United States, TX, Rosenberg
Joined Oct 2012
Sounds like a great idea. That would be a lot more fun than skeet shooting!
ServiceRep is offline Find More Posts by ServiceRep
Old Jan 23, 2015, 01:32 AM
Burning & Turning
justy g's Avatar
Hong Kong
Joined Jan 2007
Just ordered one.. Looks like some cheap fun, and different to what I usually fly
justy g is online now Find More Posts by justy g
Old Jan 25, 2015, 12:57 PM
GoatZilla's Avatar
Joined Sep 2005
Kind of a silly product. If they were smart, they would have integrated a power system mount with the dead weight mount, and you'd have the best of both worlds.
Typical RC design.
GoatZilla is offline Find More Posts by GoatZilla
Old Jan 25, 2015, 04:13 PM
altitude adjustment
thumbhead's Avatar
USA, CA, Irvine
Joined Mar 2005
I think the goal here was a light weight slope glider.
I don't think there is a shortage of small foam motor gliders.
Mark
thumbhead is online now Find More Posts by thumbhead
Old Jan 25, 2015, 09:05 PM
Pompano Hill Flyers
Rockitglider's Avatar
Pompano Beach, FL.
Joined Aug 2008
Hello,
Just got mine in the mail on Saturday, it looks ok, just a lot smaller than I thought it was going to be, won't be able to fly it until this coming Saturday. I'll let you know how it flies. Looks like it's built ok, I don't like the Styrofoam hinges though, seems like they might not last too long. The other thing is the winglets are supposed to be glued on and I think they would break off easily if any slight midair with anything else, or a hard or inverted landing. I think I will try to make a modification to make them detachable, or break-away type so they can just be put back on without having to make new ones.
Rockitglider
Rockitglider is offline Find More Posts by Rockitglider
Old Jan 26, 2015, 03:16 AM
United States, CA, Walnut Creek
Joined May 2013
Did they at least give it mg servos?
CMA Grant is online now Find More Posts by CMA Grant
Old Jan 26, 2015, 03:31 AM
youtu.be/-BG4w4XMBeE
AndrewID's Avatar
Bat-Yam, Israel
Joined Jan 2009
[QUOTE=Rockitglider;30591889]
Hm, does it came fully assembled, even winglets are glued? Could you show us packing box?
AndrewID is online now Find More Posts by AndrewID
Old Jan 26, 2015, 09:23 PM
U down with EPP? Ya u know me
Aerogance's Avatar
United States, CA, Ventura County
Joined Sep 2008
Should not be difficult to re hinge it
Aerogance is online now Find More Posts by Aerogance
Old Jan 27, 2015, 08:38 AM
Pompano Hill Flyers
Pompano Beach, FL.
Joined Aug 2008
Hello all,
Yes it comes fully assembled except for the wing tips, but it turns out that the glue they supply to install them is like a tacky craft glue, and might not do much damage if forced to pull apart. I can't tell what type of servos are included because they are sealed in the wing, but they do sound like MG servos. The packing is actually quite good. The wing is just under 36" span, overall i like it and am looking forward to flying this weekend.
Rockitglider
Old Jan 27, 2015, 10:28 PM
The Lone Sloper
USA, NY, Orchard Park
Joined Apr 2007
Ridge Ryder
I just got mine yesterday and I like I it a lot. It has a very smooth finish and the decals are micro thin. Looks like it will fly well on small hills . It came in a very large box packed with lots of those balloon packs with a smaller box inside. I am very happy with it, can't wait to fly it.
Frank
zbytekfr is offline Find More Posts by zbytekfr
Old Jan 27, 2015, 11:28 PM
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
I got mine too. Be careful setting up your throws, the elevons barely move before the servos and linkages bind.
It could be fun to fly with Weasels and Alulas if it can keep up. I'm going to try to jeep this a light as possible. I've got other stuff to fly when the wind comes up.
Old Jan 27, 2015, 11:59 PM
Aerogance's Avatar
Joined Sep 2008
Will you flame out your Ridge Ryder?
Old Jan 28, 2015, 08:23 AM
Ronnie - Sheffield UK (G0NJD)
mallettron's Avatar
Sheffield, S. Yorks, UK
Joined May 2007
Take the linkages off and bend the foam backwards and forwards several times, this will loosen it up, I thought something was wrong when the rods started bending!
With a 6v 5xaaa flat pack in the front Ive had to put 7.5g of weight under the canopy, probable due to the fact I taped the winglets on with blenderm
Also if you use the ballast put that in first then the foam, otherwise you might not get the foam out
Cant wait for a decent blow now
mallettron is offline Find More Posts by mallettron
Discussion HobbyKing Ridge Ryder Slope Wing Dogdude Flying Wings 1 Feb 05, 2015 01:43 AM
Discussion HobbyKing Ridge Ryder Slope Wing Dogdude Slope 6 Jan 24, 2015 03:51 AM
Sold RIDGE RAT slope kit By Pierce Arrow Co. bendix1 Aircraft - Sailplanes (FS/W) 1 Jul 31, 2014 07:37 PM
Ridge Runner finished (slope wing) Ben74 Foamies (Kits) 28 Jul 16, 2004 10:47 PM
Question Wing warrior: difference between slope slayer and ridge runner? Ronbo Slope 2 Jun 03, 2002 05:02 PM
