Old Sep 14, 2013, 11:57 AM
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
Wow - he's gotta have the last word too ?
scootrb4 is offline Find More Posts by scootrb4
Old Sep 14, 2013, 12:45 PM
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
He's been doing it for years.
When you're always right, you're always right.
TomCrump is offline Find More Posts by TomCrump
Old Nov 25, 2013, 01:56 PM
Joined Sep 2012
Hey everyone been a long time since I posted. I got a new job and relocated and haven't had the time to build the plane until recently. I have started again and will post pictures as usual if I make good progress.
Trey101010 is offline Find More Posts by Trey101010
Old Nov 25, 2013, 02:34 PM
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
A new job and a relocation? Congrats!
Take your time, settle-in. The model building will wait.
EJ
EJWash1 is online now Find More Posts by EJWash1
Old Nov 25, 2013, 02:59 PM
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
gratz on the job, good too hear good news!
glad your back on the plane also!
whiskykid is online now Find More Posts by whiskykid
Latest blog entry: Mig 29/Su37 super flanker
Old Jan 05, 2014, 11:07 PM
Joined Sep 2012
Hey everyone finally got a chance to do some work on the plane. Quick dumb questions before I glue. Does the base that has the formers glued to it install with the formers showing up or with the sheeting side facing up?
[IMG]http://img.photobucket.com/albums/v676/t
rey1010/Mobile%20Uploads/20140105_215152.jpg[/IMG]
Old Jan 06, 2014, 07:07 AM
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
I'm not quite sure what you are asking. Do you want to know where to install the sheet piece that you are holding in the pic ?
If so, look at the cross section of the fuselage formers, on your plan. It should show the location.
From what I can see, the piece looks like the fuselage bottom.
Old Jan 06, 2014, 08:45 AM
Joined Sep 2012
Yes that is what I was asking. Whether or not it was the fuselage bottom or top, for some reason I couldn't figure it out from the plans.
Old Jan 06, 2014, 09:04 AM
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Can you provide pics of the plans, showing the rear formers, from the rear of the wing saddle, back ?
What is the thickness of the piece in question?
Old Jan 06, 2014, 09:43 AM
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
I just realized that this is a Sportster thread. I still have the instruction manual and plans sitting here, from before.
Glue the former/deck base assembly to the top of the fuselage sides. You may find it easiest to flip the fuselage on it's back. This will insure that the deck base is flush with the the fuslage sides. Make sure that the front of the deck base is glued to the rear of bulkhead #3.
Do not glue the fuselage sides together at the rear, at this point.
If you are using medium CA, you can put the assembly together and wick the CA into the joints. It may simplify the process for you.
I'm glad to see that you are getting back to this project !
Old Jan 06, 2014, 10:25 PM
Joined Sep 2012
Thank you so much that is exactly what I was needing to know! I'll try to get some done tomorrow and update! Happy to be working on it again
Old Jan 07, 2014, 07:50 AM
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Good to see you back !
I'm surprised that my wife hadn't "suggested" that I put my plans away. LOL I'll keep them by the computer. They'll be close at hand, if you need any further clarifications during construction.
Old Jan 07, 2014, 09:19 AM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Hey Trey,
Good to see you back at your build. I'm just sitting' back and watching Tom help you along.
EJ
Old Jan 07, 2014, 02:07 PM
Tucson
Joined Nov 2009
This is a nice kit. Go at it with the goal of learning as much as possible about building planes.
The best way to learn is to jump right in!
You can use thin CA for balsa joints that are tight, and medium for balsa joints that have some gap. The medium is easier to handle (not glue your fingers to the wood!). Get a bottle of CA desolver, because you will glue your fingers to the model! I use Allenes Tacky Glue as a white glue. Cheap, and can be thinned and painted on, or left thick and painted on more quickly glue with white glue. Walmarts has it cheaply by the pint.
For $25 or less you can get a straight door core at Home Depot, as a building board. This is worthwhile.
You can get an instructor at an AMA flying club to trim out the Super Sportster, and help you to fly it, if you want help.
wuest3141 is offline Find More Posts by wuest3141
Discussion Beginning my Skywalker x-5 build paulskyone Beginner Training Area (Aircraft-Electric) 41 Feb 20, 2013 06:05 PM
Discussion My First Kit Build Contender build chaos2984 Electric Warbirds 2 Jan 28, 2013 09:29 AM
Help! My First Build - Can Someone Check My Parts List? jelled123 Multirotor Electronics 2 Jan 05, 2013 12:35 PM
Help! About to build my first plane - critique my setup and offer guidance. buffpants24 Foamies (Scratchbuilt) 11 Feb 10, 2009 10:40 PM
Discussion Beginning my first build from plans vwtrey The Builders Workshop 9 Oct 06, 2008 04:24 PM
