Old Jul 25, 2014, 12:11 AM
stop making sense
hallo's Avatar
Norway
Joined Feb 2014
Yes, I think the only thing you actually need is that dash of epoxy in the front, unless you need or want to lock it from moving vertically inside the fuse if it has a somewhat loose fit.
The balsa bits (5mm sheet) I would recommend if you use lead slugs, in a twisted/hard landing the tube may wreck the rear section behind the wing in a sideways motion.
That's at least with the Fosa because the sections are hollowed out so they don't take much sideways force from the tube.
hallo is offline Find More Posts by hallo
Old Aug 10, 2014, 11:16 AM
Taipei, Taiwan
Joined Jun 2009
F3F 20140714 鐵鉆山 李麥克 Pitbull (1 min 31 sec)
My Pitbull. CG at 96 mm from the leading edge.
Michael
mlee3 is offline Find More Posts by mlee3
Old Aug 10, 2014, 11:48 AM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Looks very smooth, Mike Lee.
R,
Target
target is offline Find More Posts by target
Old Aug 10, 2014, 09:10 PM
concreteman's Avatar
United States, CA, Torrance
Joined Aug 2004
Smooth, Mike.
concreteman is offline Find More Posts by concreteman
Old Oct 09, 2014, 03:25 AM
miki.r's Avatar
Vienna, Austria
Joined Oct 2007
Hi,
I got myself a new toy...
Before starting to build i wanted to be sure about the position of the ballast tube. To have the tube balance at 102mm it has to be placed 3-4mm behind the fuse cutout? Hope i got it all measured right...
CG at 102mm gives neutral flight in a dive test?
miki.r is offline Find More Posts by miki.r
Old Nov 20, 2014, 12:16 PM
Cogito Ergo Zoom
Parallax's Avatar
Calgary, Alberta
Joined Mar 2004
Slim chance I'm sure, before I pull the trigger does anyone have a used Pitbull they would sell?
Parallax is offline Find More Posts by Parallax
Old Jan 06, 2015, 06:09 AM
Phil.T-tailer
Phil.Taylor's Avatar
Devon, UK
Joined Jun 2003
Video of my friend's new Pitbull on 2nd Jan - New Year - new plane - smoooooth landing !
I've been watching these on the F3F circuit last year - very impressive
Phil.
John's Pitbull maiden flight (2 min 59 sec)
Phil.Taylor is offline Find More Posts by Phil.Taylor
Old Jan 23, 2015, 11:01 AM
Joined Aug 2004
So...new for me is battery setup. Not thrilled with the nihm cells ( and alot of nagging by Target), my new setup is all installed and running perfectly. Sanyo 18500 cells, c.c bec and zepsus mag switch. Darn near over did it with the melted lead into subnose cavity! No other lead needed, and cg nailed. Fit is perfect. Constant 5.1v supplied, as verified by graupner tx. The "standard" mks servos are perfectly happy. Stock F3B version weighing in at 73oz. Thanks to Target for the battery build and charging info. What was that middle lead for??? Lol
WD
Old Jan 23, 2015, 10:08 PM
bluffman's Avatar
Joined Sep 2003
Very cool
bluffman is offline Find More Posts by bluffman
Old Jan 30, 2015, 06:48 PM
United States, OR, Tualatin
Joined Apr 2005
Zepsus has a switch / voltage regulator combo that is flat and quite small. Have one on my Energic because of the 7.4V Battery.
TomFlyer is offline Find More Posts by TomFlyer
Old Jan 30, 2015, 07:01 PM
Joined Aug 2004
I have seen those, Tom, that may be the way I go on the next one, which will be shortly.
WD
New Product F3B/F3F Eldorado fly-up85 Multi Task F3X 30 Mar 11, 2014 08:28 AM
FS or Trade: Acacia F3F/F3B/F3J slope racer for heli robdoyle Aircraft - Sailplanes (FS/W) 3 May 12, 2003 07:33 AM
Want to Buy F3F or F3B Dugman Aircraft - Sailplanes (FS/W) 1 May 01, 2003 09:11 PM
F3B and F3F ships - differences ? yclui Thermal 3 Jan 14, 2003 09:13 PM
Wtb: F3b, F3j, F3f g00bd0g Aircraft - Electric - Airplanes (FS/W) 3 Sep 23, 2001 10:15 AM
