Old Dec 21, 2014, 02:21 PM
Alistego's Avatar
Joined Nov 2007
Hey, now that's looking a lot better already. Good recovery, and before you know it the setback will just be a funny story to tell at the flying field.
Dale
Alistego is offline Find More Posts by Alistego
Old Dec 21, 2014, 04:13 PM
Paul Bonati's Avatar
Buenos Aires, Argentina
Joined Aug 2007
Thanks Dale!!!!!
Paul
Paul Bonati is offline Find More Posts by Paul Bonati
Old Dec 21, 2014, 04:51 PM
Joined Aug 2007
I wasn't please wirh the fuselage....much more like a banana than a plane....
today Itried to re adjusted....
Old Dec 21, 2014, 06:39 PM
a.k.a Maltone
Pat Lynch's Avatar
Australia, NSW, Goulburn
Joined Jan 2005
Good to see you back at it Paul. Getting the fuselage straight is an essential. As each pair of cross pieces are added (I do bottom and top together) the lower longerons are supported on a scrap of balsa to keep it flat and pinned to the plan.90 deg squares are used to get the sides vertical. Don't be tempted to glue the ends together until finished - a rubber band will do. If there is any twist when all the cross-pieces are fitted, the rudder post (fuselage ends) can be twisted a little until they a vertical and centred.
Keep up the good work - Pat
Pat Lynch is offline Find More Posts by Pat Lynch
Latest blog entry: What's Coming up....
Old Jan 11, 2015, 05:46 PM
Joined Aug 2007
After the holidays hee we are again...
I spent some time making some experiments with the covering. I will try to cover the fuselage with this white film (it is similar to mylar, it is white, without cement and it is use for covering parcels/presents) .
I used contact cement and then strch the film with heat....not tu much. Then I will try to adhere the printed japanese tissue with the losange.
It seems to be a light covering.
Old Jan 11, 2015, 05:51 PM
Joined Aug 2007
Thanks Pat for the tip, and for your kind words.
Cheers,
Paul
Build Log Peter Rake's 1/6 Fokker D.VII "Sieben Schwaben" - Now with Video gupi Scale Kit/Scratch Built 254 Jan 14, 2015 03:36 PM
Discussion Peter Rake Fokker D.VII vonJaerschky Scale Kit/Scratch Built 296 Nov 07, 2010 07:11 AM
Cool Peter Rake Fokker D-VIII (IPS version) Steely Dan Scale Kit/Scratch Built 9 Mar 27, 2010 03:05 PM
Fokker D VII by Peter Rake Ian Easton Scale Kit/Scratch Built 158 Dec 21, 2005 12:06 PM
Peter Rake's Fokker D-VIII Jim Drissell Scale Kit/Scratch Built 12 Aug 02, 2002 02:10 PM
