Old Jul 06, 2014, 07:48 PM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Originally Posted by voxel View Post
A long takeoff is a sign of being overly nose heavy too. Although being tail heavy will cause snap rolls which I did on my Habu yesterday on a humpty bump.
Definately is a drag/ground speed issue; CG is actually a bit tail heavy just to make sure I get good rotation.
When the field is dry/just cut I can get off in half the field. When it is damp from dew and/or ready for cutting, I need just about all of it, even with flaps.
tracknoob is offline Find More Posts by tracknoob
Old Jul 06, 2014, 07:55 PM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Originally Posted by dth7 View Post
So what about the wt penalty on performance?
For me, it was a matter of being able to fly or not fly, so the choice was easy.
What servos did you use for flaps?
I just used some 9G HK HXT900s that I had lying around. Good general purpose servo -- centers well, does not 'groan' or make noise like the HH ones do sometimes.
Did it help the CG?
I don't know that it impacted it at all -- I think those are fairly close to the CG line. What makes the difference in letting you jocky CG to where you need it, is cutting back the foam to let you place the battery way back, as well as using a 3000-ish batteryversus a much larger one.
What kind of AUWs are you guys getting on 4 and 5s with the retracts and flaps installed? Thanks.
Sorry, don't recall mine, but it's nothing exotic -- standard eflite retracts, plus flaps, standard motor, fan, ESC, etc.
Old Jul 06, 2014, 08:03 PM
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
That's what I'll be using on my Flaps also. Great bang for the buck!
Diesel6401 is online now Find More Posts by Diesel6401
Old Jul 07, 2014, 06:50 PM
capt soap's Avatar
dallas tx
Joined Jun 2003
jetson, whats your esc? I asume a 100 amp in the tailcone?
capt soap is offline Find More Posts by capt soap
Old Jul 07, 2014, 07:29 PM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
Originally Posted by kalmon View Post
I'm confused
The stock setup is a 3200kv 5blade, how is a 2600kv 12 blade going to be an improvement? especially when it lists a working amp range of 35-49amps.
more blades = more amps for same power. what you gain is a much better sound. Really you're trading power for sound.
It was the similar performance as stock. It checked at 54amps on the watt meter. Sounded a lot better.
The 14blade setup I have coming for the V2 is 4s/5s.
Old Jul 07, 2014, 08:28 PM
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
capt soap
nick (jetsom) has a ice 100 or ice lite 100 castle (same thing) in the tailcone
jcdfrd is online now Find More Posts by jcdfrd
Old Jul 07, 2014, 10:31 PM
capt soap's Avatar
dallas tx
Joined Jun 2003
Cool, more room up front.
Old Jul 09, 2014, 01:02 AM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
Airframe arrived today
The smile was quickly erased when one of my HK retracts failed during a bench test
Gear go down, gear come up - then gear no come down no more
Old Jul 09, 2014, 04:14 AM
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
That stinks. Sorry to hear that. I haven't tried the returns process with HK, but if you can send the return to their warehouse in WA, awesome. Otherwise, USPS First Class International shipping is relatively cheap, and you can print shipping labels online at USPS.com.
Best,
Josh
jgalexander is offline Find More Posts by jgalexander
Old Jul 09, 2014, 05:10 AM
Aka: Tom Jenkins
ApexAero's Avatar
Palm Beach County, Fl.
Joined Aug 2008
Diesel, before you get all bunched up, try and set the end points on the gear channel up to 105% and check the gear again!
ApexAero is offline Find More Posts by ApexAero
Old Jul 09, 2014, 09:08 AM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
Will check thanks
Update: no fix. Tried different endpoints as well. Submitted RMA.
Sold 2 PNP Parkzone Habu's - willing to ship jgalexander Aircraft - Electric - Jets (FS/W) 16 Mar 29, 2012 09:44 PM
For Sale Brand New in pack ParkZone Habu EDF Jet Painted Wing PKZ7020 zsultan Aircraft - Electric - Airplanes (FS/W) 3 Nov 15, 2011 12:36 AM
For Sale Brand New in pack ParkZone Habu EDF Jet Painted Wing PKZ7020 zsultan Aircraft - Electric - Jets (FS/W) 0 Nov 13, 2011 02:40 PM
Sold Brand New Parkzone Habu EDF Jet BNF zsultan Aircraft - Electric - Airplanes (FS/W) 0 Nov 07, 2011 01:05 PM
Sold Brand New Parkzone Habu EDF Jet BNF. zsultan Aircraft - Fuel - Airplanes (FS/W) 4 Nov 07, 2011 01:04 PM
