Old Mar 27, 2015, 07:45 AM
Jrenatomachado is offline
Find More Posts by Jrenatomachado
Joined Aug 2006
Super scale ASW 20 (66%)
Hi there,
I am currently developing a super scale ASW 20 66% scale and I will share the building process with you.
I created a XFLR 5 model to assess the aerodynamic performance and these are the final results:
-HQ/W 2,5 15% root airfoil
-HQ/W 2,5 11% tip airfoil
-Washout: 1.5
-Longitudinal V: 2
-Mass target: 40kg
-Max glide ratio : 37 (without flaps)
-Min sink: 0.36 m/s (without flaps)
I intend to build the fuselage using the XPS frames and planking technique. (Reference : http://www.rckozmodrom.com/RcModely/Blanik.htm)
Next steps:
- Wing Spar;
- Airbrakes ;
- Retract wheel mechanism;
Cheers!!
Renato
Jrenatomachado is offline Find More Posts by Jrenatomachado
Old Mar 27, 2015, 09:14 AM
s2000 is online now
Find More Posts by s2000
so. cal.
Joined Jan 2006
Clearly it's not big enough, 68% is in vogue now. WOW!
s2000 is online now Find More Posts by s2000
Old Mar 27, 2015, 09:35 AM
Joined Aug 2006
Haha Maybe the next one!
Old Mar 27, 2015, 01:21 PM
Larrikin is offline
Find More Posts by Larrikin
Everything's A Compromise
Larrikin's Avatar
Joined Jan 2005
YIKES ... I'll be following this one with great interest.
David
Larrikin is offline Find More Posts by Larrikin
Latest blog entry: The Rubicon
Old Apr 05, 2015, 05:26 PM
Joined Aug 2006
The Retract wheel mechanism is nearly finished
Wheel diameter : 260 mm
Cheers
Renato
Old Apr 06, 2015, 01:08 AM
robdyan is offline
Find More Posts by robdyan
robdyan Rob
Joined Mar 2007
I think you posted three days early by mistake- April 1st would have been a good date.
Wow- its certainly possible but... And how big is your vehicle. Serious truck needed or glider trailer.
Best of luck if you decide to go ahead.
robdyan is offline Find More Posts by robdyan
Old Apr 06, 2015, 10:01 AM
Joined Aug 2006
Lolol
The fuselage will split in half and I will do the same with the each half-wing, so it shouldn't be be too difficult to transport
Cheers!
Old Apr 14, 2015, 06:11 AM
Joined Aug 2006
Spoiler
Hi there,
The spoiler is getting ready as well
Renato
Old Apr 17, 2015, 08:59 PM
davidjensen is online now
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
Have you calculated an AUW? What will tug this up?
davidjensen is online now Find More Posts by davidjensen
Old Apr 19, 2015, 03:59 PM
Joined Aug 2006
Hi David,
The AUW should be around 40kg.
I believe that we can tug this thing with a 120-150cc engine attached to something
I am currently cleaning the workbench and I should start the fuselage soon.
Cheers
Old Apr 26, 2015, 05:18 AM
Joined Aug 2006
A couple of pictures of the fuselage nose section
Cheers!
Found 1/3 Scale ASW-20 by Marks Models gva1956 Aircraft - Sailplanes (FS/W) 5 Sep 23, 2013 06:45 PM
FS: unbuilt 1/3 scale ASW 20 dckemper Aircraft - Sailplanes (FS/W) 8 Nov 08, 2003 09:19 PM
FS: unbuilt 1/3 scale ASW 20 dckemper Aircraft - Electric - Airplanes (FS/W) 0 Nov 02, 2003 10:01 PM
?? - Experience with a 1/3 scale ASW 20 dckemper Scale Sailplanes 1 Jul 21, 2003 07:37 AM
Building best practices for 1/3 scale ASW 20 dckemper Giant Scale Airplanes 0 Jul 19, 2003 07:25 PM
