Old Feb 20, 2015, 08:47 PM
Rockinar is offline
Find More Posts by Rockinar
Joined Aug 2012
Recovering hinge area
I'm new to RC and want to recover my ARF. Don't like the color. How do handle the hinge areas? Do I cut off the hinges and start over? Or do I use a tool to get the covering down into the crack of the control surface?
The videos on Youtube all show people covering planes that don't have control surfaces attached which makes me curious.
Thanks in advance...
Rockinar is offline Find More Posts by Rockinar
Old Feb 20, 2015, 09:20 PM
davidmc36 is online now
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
As long as you have a bit of space to deal with some irons will get into pretty small gaps. Ripping hinges out could make quite a mess.
http://www3.towerhobbies.com/cgi-bin...P?I=LXB365&P=8
davidmc36 is online now Find More Posts by davidmc36
Old Feb 21, 2015, 01:49 AM
Rockinar is offline
Joined Aug 2012
Yeah, that looks to be the route I will go. Messing with the hinges seems to be more of a project than I'm interested in right now. I was just not sure how most people did it.
Old Feb 21, 2015, 08:43 AM
valkrider is offline
Find More Posts by valkrider
United States, NJ, Woodstown
Joined Sep 2011
if you have CA or nylon hinges, it's easier to do a better job of covering if you cut off the hinges. In my opinion, it also saves a decent amount of time since you don't have to fiddle around in cramped areas with a hot iron and worry about sticking the covering together.
Just re-slot adjacent to the old hinges for the new hinges and you'll be good as new.
Good luck...
valkrider is offline Find More Posts by valkrider
Old Feb 21, 2015, 08:57 AM
kw_counter is offline
Find More Posts by kw_counter
United States, CA, Hidden Valley Lake
Joined Aug 2002
I try to avoid cutting the hinges if I can.
I take a piece of my lightest colored covering and cut it 1" wide by the length of the surface I am covering. I then cut 1/2" deep slots where the hinges are. This piece I can then slip into the space between the wing/stabilizer and the control surface. Tack it into place. This allows me to cover the surface up to slot and the wood in the slot is protected. This will have to be done on both surfaces.
Good Luck,
KW_Counter
kw_counter is offline Find More Posts by kw_counter
Old Feb 21, 2015, 09:49 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
The only thing that I might be worried about if you re-cover without cutting hinges off is if it is a wet fuel model you may not be able to get the covering overlapped and that would leave a place where exhaust gasses etc. could get under the covering.
If you are electric, should be no worries.
Cutting hinges off and making new slots sounds like a good idea.
Old Mar 01, 2015, 03:01 AM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
I recovered a set of repaired wings yesterday and, rather than patch them up I stripped them for recovering. Didn't want to rehinge them though, so I left the strip ailerons covered and then just extended the new Oracover over the original covering. It added a fraction of an ounce of weight, I suppose, but it saved a lot of hassle. I slit the covering at the hinge-line underneath, but experimented with leaving a full film hinge on top.
However I didn't like the added resistance, so ended up slitting the top covering as well. My standard covering iron easily got into the hingeline to ensure that everything was well stuck down.
That Profilm/Oracover is great stuff - an absolutely drum tight finish when shrunk with a heat gun, after the ironing on, and tough as old boots.
leccyflyer is offline Find More Posts by leccyflyer
Discussion Recovering a plane and need help with hinges mudbugnla The Builders Workshop 17 Dec 29, 2014 09:18 AM
For Sale Hings,Hings & more Hings lla Aircraft - General - Miscellaneous (FS/W) 1 Mar 09, 2014 06:47 PM
Question Minwax/coating, lead edges and hinge areas cram Painting and Finishing Tips 4 Jan 20, 2013 12:19 PM
Discussion Need help recovering FPV plane near Denver, CO - Plane recovered! Vitamin_J FPV Aircraft 87 Jun 16, 2011 06:16 PM
Discussion Recovering Hinged Areas infodevourer Beginner Training Area (Fuel) 8 Sep 07, 2006 11:19 PM
