Old Jan 04, 2013, 03:47 AM
alfi666 is offline
Find More Posts by alfi666
Joined Nov 2012
My Scratchbuilt Y6 hexa for AP
Here is my Y6 hexa that I built from square aluminum tubes and glass fiber sheet.
(gimbal is not scratchbuilt)
It's still a work in progress & waiting for maiden flight
AL profiles 15x15mm.. at the base there's two on each other to increase strenght. Base is made from 2.5mm GF sheet.
T-motor 770kV + HK F40A (stock FW).
Controller - Naza+GPS and multiwii for Gimbal.
2x5000mAh 4s battery
Current weight with Panasonic GH2 is over 4kg
alfi666 is offline Find More Posts by alfi666
Old Jan 04, 2013, 04:28 AM
xardinen is offline
Find More Posts by xardinen
Joined Aug 2011
I like it! I love the looks of a Y6 but cant help to think about the slightly lower effiency compared to a hex (Im a duration flyer )
xardinen is offline Find More Posts by xardinen
Old Jan 04, 2013, 05:08 AM
alfi666 is offline
Joined Nov 2012
Thanks, I agree with you on efficiency.
I was planning to build a flat hexa, but after doing some reading it turns out that Y6 has much better redundancy in case of engine/ESC failure....
And for me, redundancy is much more important for such a heavy machine with (sorta) expensive equipment on board.
Old Jan 04, 2013, 10:52 PM
FlyingMcCoy is offline
Find More Posts by FlyingMcCoy
Joined Mar 2010
nice!
FlyingMcCoy is offline Find More Posts by FlyingMcCoy
Old Jan 05, 2013, 05:03 AM
alfi666 is offline
Joined Nov 2012
I didn't even took of yet, but I don't like the gimbal... its too flimsy.. so I don't think I will be getting any useful results with it
Hope someone will put together a kit of working Brushless Direct drive gimbal soon... would like to get a Zenmuse, but price wise its out of my league.
Old Jan 06, 2013, 04:49 PM
Ottomite is offline
Find More Posts by Ottomite
The Ottoman Flyer
USA, TX, Galveston
Joined May 2010
I can vouch for the Y6 redundancy. I have lost a spinner because i had not used locktite and even when loosing a prop the Y6 did not bother. I'll take redundancy over efficiency any day.
Join me at RCGroups Chat!
Ottomite is offline Find More Posts by Ottomite
Old Jan 07, 2013, 06:04 AM
alfi666 is offline
Joined Nov 2012
Thanks Ottomite for sharing your experience. What controller do you use?
Old Jan 08, 2013, 09:22 AM
Ottomite is offline
The Ottoman Flyer
USA, TX, Galveston
Joined May 2010
I was using the KK 2.0
Old Jan 10, 2013, 02:07 PM
rumbey is offline
Find More Posts by rumbey
Speed is Good!
rumbey's Avatar
Chippenham, Wilts
Joined Oct 2005
My Y6 based on DJI 550 centre and Vulcan Aluminium arms
rumbey is offline Find More Posts by rumbey
Old Jan 11, 2013, 04:50 PM
rumbey is offline
Speed is Good!
rumbey's Avatar
Chippenham, Wilts
Joined Oct 2005
Maiden flight video. I was concerned whether the video footage would be vibration free. It exceeded my expectations.
Still need alopt of fine tuining and setting the Naza voltage levels up etc
Y6 Maiden with Naza (4 min 6 sec)
Old Jan 12, 2013, 10:43 AM
alfi666 is offline
Joined Nov 2012
I'm made a maiden today as well... video from gimbal was unusable as it was shaking as hell... I'd be rather off without gimbal at all.
Y6 itself was pretty stable without any tuning.... Like it so far.
Old Jan 20, 2013, 11:32 AM
rumbey is offline
Speed is Good!
rumbey's Avatar
Chippenham, Wilts
Joined Oct 2005
Latest vid . Cold and a bit breezy but happy with the Y6 footage
Quadjunkies on the Plain (5 min 39 sec)
Old Jan 23, 2013, 10:00 AM
alfi666 is offline
Joined Nov 2012
I was having an issue with stability ando I've installed SimonK firmware - which solved the issue!
Unbelievable... these HK F40A ESC's are complete unusable crap without Simon's firmware!
This guy deserves a medal - or at least donating!
So thanks Simon for making this FW... performance difference is like between heaven and hell.
Old Jan 24, 2013, 03:48 AM
Joined Mar 2010
Did you have stabillity issues even in calm days with stock FW?
Old Jan 24, 2013, 04:00 AM
alfi666 is offline
Joined Nov 2012
I haven't had chance to test it too much without a slightest wind, but I'm certain that now is it so much better.
Question Hexa or Y6 for aerial video? And FPV flohio117 Multirotor Talk 42 Oct 15, 2012 08:23 PM
Discussion My new scratchbuilt Hexa TS00 Scratchbuilt Multirotors 7 Oct 15, 2012 02:40 PM
Discussion Opinions on my Semi-Pro Hexa Build for AP benthoms Multirotor Talk 2 Sep 17, 2012 10:23 AM
Question Y6 or Conventional Hexa 6? Pos and Cons? Formosa Multirotor Talk 3 Mar 22, 2012 11:39 AM
Discussion best scratchbuilt first plane for my youngster? stallion explosi Foamies (Scratchbuilt) 3 Mar 18, 2012 09:14 AM
