Old Sep 03, 2012, 08:24 PM
GliderJim is offline
Find More Posts by GliderJim
GliderJim's Avatar
Michigan, USA
Joined Jul 2006
Question
72 MHz antenna question.
I'm putting together a 48" EPP flying wing and the plans show the receiver going in the middle with the antenna running out to one wing tip. Since the antenna is longer than 24" there will be some hanging out the tip.
I could keep the entire antenna within the wing if it were attached to the receiver in the center, in sort of a "Y" configuration.
Anyone know what the ramifications of this are? Or what rules I need to follow?
Jim
GliderJim is offline Find More Posts by GliderJim
Old Sep 03, 2012, 09:01 PM
glidermang is offline
Find More Posts by glidermang
Jim:
I have an Alula, and the antenna on that one goes outboard along the spar, then back in board along the aileron hinge. In my DLGs, when I was still using 72, I let the antenna dangle out the back. Some people wind it around a soda straw inside the fuselage, and I once recieved a little bobbin-like device, and the idea was to wind it around that.
Just don't bunch it up, and you should be fine. Do a range check before flying.
Yours, Greg
glidermang is offline Find More Posts by glidermang
Old Sep 03, 2012, 09:20 PM
lincoln is online now
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
I've flown with part of the antenna near the receiver coiled up like that. Worked fine for me, not clear to me if it matters what receiver so range check of course. I also used a "base loaded" antenna meant for rc cars for some years in an hlg that was often flown pretty far out. No trouble. YMMV
lincoln is online now Find More Posts by lincoln
Old Sep 03, 2012, 09:39 PM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
This won't work.Think of the signal as a standing wave of voltage along the antenna wire. The wire is dimensioned so that the nodes of maximum voltage are at the tips of the wire, at the middle the voltage is zero. You wouldn't get any signal if you connect the rx feed there. It is possible to construct a center-fed antenna, but it will need to be dimensioned differently than a simple dipole. I haven't researched this enough to give any specific design data - if you'd like to try it, I'd recommend asking in the electronics or radios forum.
jkettu is offline Find More Posts by jkettu
Old Sep 03, 2012, 09:42 PM
lesterpk is online now
Find More Posts by lesterpk
lesterpk's Avatar
Australia, WA, Perth
Joined Oct 2003
I just used to run it out toward one tip then back toward the other. Generally with a faomie you are far from stretching the range so worked fine.
lesterpk is online now Find More Posts by lesterpk
Old Sep 04, 2012, 02:53 AM
bjaffee is offline
Find More Posts by bjaffee
Brett
bjaffee's Avatar
So Cal
Joined Apr 2002
I've had a 48" combat wing and an electric flying wing, and set both up similar to what lesterpk's drawing shows. Never had a problem.
bjaffee is offline Find More Posts by bjaffee
Old Sep 04, 2012, 07:08 AM
GliderJim's Avatar
Michigan, USA
Joined Jul 2006
Well alrighty then - looks like I'll just be running it out and back.
Thanks!
Old Sep 04, 2012, 02:50 PM
GliderJim:
What I did with the Alula is almost exactly what lesterpk shows.
I'd say you're good to go.
Yours, Greg
Wanted Base loaded Rec Antenna 72 Mhz partzee Aircraft - General - Radio Equipment (FS/W) 2 Jun 27, 2012 11:40 AM
Sold Corona RS410II 72 MHz Rx and GWS PICO 72 MHz Rx with two micro crystals $18 shipped CitizenKane Aircraft - General - Radio Equipment (FS/W) 2 Jun 08, 2012 09:23 PM
Question Where to put the 72 MHz antenna bwill6 Hand Launch 29 Mar 22, 2012 10:37 AM
Discussion 72 mhz range question mustangflyboy1 Radios 6 Feb 26, 2012 03:19 PM
Sold (5PCS) M-72-LITE 72 mHZ r/c RECEIVER ANTENNA gbagley Aircraft - General - Radio Equipment (FS/W) 2 Jul 02, 2006 10:55 AM
